Old 07-20-2005, 02:06 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Impreza GC8 legacy 2.2t internals...
Im in the process of building a 98rs, I plan to utilize my DOHC heads on the 2.2 closed deck legacy block. My question is how reliable are the stock internals such as rods or valves and valve springs, could I run 20psi daily on stock internals with exception of some low compresion pistons?
2.5rsDOHC is offline   Reply With Quote
Old 07-20-2005, 02:34 PM   #2
bmxpunk
Member#: 89599
1995 almost 22B:)
red
If you use the dohc heads on the 2.2 your compression ratio will already drop to like 7.5:1 depending on what head gasket yu use.
bmxpunk is offline   Reply With Quote
Old 07-21-2005, 12:54 AM   #3
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
and to answer your question yes you can run 20 psi daily.
azn2yunr is offline   Reply With Quote
Old 07-21-2005, 02:05 AM   #4
JDM_Scobaru
Member#: 57809
I would get STi heads at least or the JDM ver.8 heads and you would have a crazy setup on your hands. But yes, 20psi will be no problem for that block for everyday driving.
JDM_Scobaru is offline   Reply With Quote
Old 07-22-2005, 03:37 AM   #5
DamienX
Member#: 66331
Don't different heads have different sensors? Kinda like the wrx having less timing marks on the cam gear than a legacy?
DamienX is offline   Reply With Quote
Old 07-25-2005, 01:23 PM   #6
rpmmachine
Member#: 73312
2012 WRX
WRB Wagon
So if i have a stock 2.5rs and its sohc and i but in a 2.2t legacy bottom end i can turbo it with no problem? What kind of power would i expect to get? With stock heads?
rpmmachine is offline   Reply With Quote
Old 07-26-2005, 08:10 AM   #7
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
I'm not sure if the 2.5RS SOHC motor had different dish in the pistons and different cc in the heads or not, if it's 49-50 like the DOHC heads on the 2.0 and EJ25's nowadays, then yeah, it would drop it immensely. with 20psi, I don't have any rough figure that would work dude for estimated power.
20psi at 9:1 is alot different than 20psi at 7.5:1 and of course 30psi at 7:1 is just kick ass.
JonofScio is offline   Reply With Quote
Old 07-26-2005, 09:06 AM   #8
Fernely
Member#: 6824
2008 QSM Leg. spec B
Pastelito Racing/ SFSOC
EJ motor compression calculations this guy did some great calculations on a number of combos just scroll down the page a bit to see the results. BTW I have the 2.2 block on 2.5 heads using a cometic head gasket. I think I'm in the 7.8-8 to 1 ratio.
Fernely is offline   Reply With Quote
Old 07-26-2005, 04:02 PM   #9
dladow
Member#: 70393
I have a justy. It is a 1000 horsepower monster. If you look in any 1990 + Websters Dictionary for the word MONSTER, you will see a pic of my 89 Justy 1.2 Liter NA. BTW I hate Mexicans, they are subhuman rabble! Did you they are so underdeveloped as a race that they can only see in grainy black and white images?
EDIT: I HAVE DYNO CHARTS AND IF ANYBODY WANTS TO GO FOR PINKS ( NON-MEX) BRING IT
dladow is offline   Reply With Quote
Old 07-26-2005, 06:07 PM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question
Scoobyslack1 is offline   Reply With Quote
Old 07-26-2005, 07:36 PM   #11
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
what the hell is with this guy... im thinking ban???
Natoe is offline   Reply With Quote
Old 07-29-2005, 01:37 PM   #12
PowderMan420
Member#: 33737
lol for randon sh!$
PowderMan420 is offline   Reply With Quote
Old 07-31-2005, 12:05 AM   #13
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
wow...education dose really pay off (except spelling of course), ignorant jackasses are really worthless.
josh...just josh is offline   Reply With Quote
Old 08-01-2005, 08:49 AM   #14
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
what was the point of that?
Old 08-02-2005, 03:05 PM   #15
Natoe
Member#: 90353
lol yeah.. 1000hp NA 1.2L eh?
Old 08-03-2005, 01:49 AM   #16
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Ok i see all this great talk about the 2.2T. Where is all the negative stuff about? They kinda change the block design for a reason but why. The 2.2T is a center thrust cranks while i believe after 97 they went rear thrust on all blocks after that. And if anyone else can think of more stuff do share. \
P.S.
i will be assembling a 93 2.2T w/ CP pistons, maybe rods, wrx heads and just want to be more knowledgable if things ever start to go wrong.
mario
EDIT
marios03wrx is offline   Reply With Quote
Old 08-03-2005, 10:00 PM   #17
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Originally Posted by marios03wrx
Ok i see all this great talk about the 2.2T. Where is all the negative stuff about? They kinda change the block design for a reason but why. The 2.2T is a rear thrust cranks while i believe after 97 they went center thrust on all blocks after that. And if anyone else can think of more stuff do share. \
P.S.
mario
2.2t motor has center thrust bearing.
lots of pics of my 2.2t teardown and rebuild
http://www.main.experiencetherave.co.../images/ej22t/
Legacy777 is offline   Reply With Quote
Old 08-04-2005, 12:28 AM   #18
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
Woops thanks for the correction. i had a feeling i wasn't right.
your site, is it down?? i would really like to see those pics. i have mine broken down so i can compare. i'm just missing an oil piston squiter.
So do you know of any neg. things about the 2.2T
mario
Old 08-04-2005, 12:57 PM   #19
Legacy777
Member#: 4800
Site should be up. If you can't get it to work, try this
https://www.mail.experiencetherave.c.../images/ej22t/
Only real neg. thing I know about the ej22t is the heads. They have small valves, and don't necessarily flow as well as the ej20 or ej25 heads.
Old 08-04-2005, 09:43 PM   #20
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
Legacy777
Wow you have been really busy man. i should be there as soon as i have the cash for my pistons, good work. So do you plan on keeping you site up and running for a while? Hope so i'm gonna copy some pics you have there and man where there a lot of them.
thanks
mario
Old 08-05-2005, 01:29 AM   #21
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
They changed the blocks because they cost too much to make. As well as they stopped making the turbo blocks when they stopped making the turbo legacies! Damn those fools!
The stock turbo pistons are still pretty damn nice. I just pulled (two hours or so ago) 4 of em out of my future new motor. They have at least 150,000 miles on them, maybe more. THEY ARE CLEAN! Ok, actually they were kinda oily, dirty and covered in carbon. But.... it was just oil and carbon. They look basically new under the carbon coating. I am currently steam cleaning them in the dishwasher. I will give them a double cycle to make sure my wife doesnt detect an oily taste on the silverware.
Old 08-05-2005, 12:27 PM   #22
Legacy777
Member#: 4800
Legacy777
thanks
mario
Yup, site will be up pretty much indefinitely. When I get done, I'll make a full write-up and move everything over to my main site. Similar to my AWD & 5MT swap. I'll have a redirect, so it should be a seamless transition.
Josh
Need Help 06 legacy 2.5i problem BlobeyeSTi Mid Atlantic Impreza Club -- MAIC 9 06-04-2010 08:53 AM
Parting out '94 Legacy 2.2T wagon AugustusMaximus Private 'For Sale' Classifieds 0 03-15-2006 05:30 PM
WTB: 91-94 Legacy 2.2T block soobyfan Private 'Wanted' Classifieds 0 09-03-2005 04:49 PM
JDM Legacy 2.2t, jdm 2.0t block? AutoSpeedWRX Private 'Wanted' Classifieds 1 09-18-2003 11:35 PM
