Old 07-20-2005, 07:26 PM   #1
mybluesubi
Member#: 53526
1997 Impreza
black
Default EJ22 turbo installation
I have an EJ22 in my car and I'm installing a turbo on it but have no clue where to get oil from the engine to the turbo and back.
mybluesubi is offline   Reply With Quote
Old 07-21-2005, 02:13 AM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Well you need to get oil from an area in the engine where the oil is under higher pressure. The most logical place is to get fittings and tap off of the oil pressure sensor (and still keep the oil pressure sensor of course). Oil return you can either return it to the oil pan, or the valve cover.
Any decent speed shop should have the fittings nessecary (I think the fittings are the same needed for Hondas).
ai42 is offline   Reply With Quote
Old 07-21-2005, 02:16 AM   #3
mybluesubi
Member#: 53526
1997 Impreza
black
ok thanx. if I do plug into the top of the block where the oil pressure sending unit is will it actually pump oil through there constantly and will the sending unit read actual pressure in the system? now that I'm looking at it closer I also need a place to run the coolant tube to and from the turbo. (it's a VF10 from an 88 GL wagon). I have a lot more questions if you care to respond and help out. thanx
Old 07-21-2005, 02:23 AM   #4
ai42
Member#: 71348
1999 EJ207 RS.TI
I know there are quite a few of us who are running a tap off the oil pressure sensor with various fittings, myself included. It will give you consistant oil pressure to feed the turbo, and the only ill effect is that I've grounded out the oil pressure sensor a couple of times while tinkering (easy fix of course). And occasionally with I first turn over the engine after it is cold sometimes the oil pressure will throw a light on the dash for about 2-3 seconds.
I'm not sure how/where to tap from coolant. Honestly if you have a VF10, I would get a TD04 (stock WRX) I know for a fact that you can run the TD04 with oil only you just have to be a little careful and run the engine a bit after the turbo has been running hard or get a turbo timer. VF10 you might be able to do without coolant but I'm not really sure it is an older turbo of course so perhaps not.
Old 07-21-2005, 02:28 AM   #5
mybluesubi
Member#: 53526
1997 Impreza
black
lots of help thanx. I just paid 200 bux for the whole car actually and have no use for the rest of it. I'm not looking for goobs of power (just 50 extra hp or so). I know the VF10 will do this and besides, I don't wanna run too much boost cause I would like to keep this engine around a while. as you can tell I'm pretty new to the whole turbo thing and I don't wanna go into this blind and mess things all up being my car is a daily driver.
Old 08-12-2005, 03:40 PM   #6
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
good question on where to get coolant? Coolant temp sensor maybe??
lotus2843 is offline   Reply With Quote
Old 08-12-2005, 04:44 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I don't know about that, but it got me thinking. Many guys have done the coolant bypass mod on the TB. Why not take the coolant feed from the left side of the TB to feed the turbo, and the return, which is right next to the sensor on the crossover tube, as the return.
You would need to enlargen the hose size to meet the turbo, and reduce it back down to the return, but it could be done. Other guys have tapped the heater lines...
Old 08-12-2005, 07:51 PM   #8
mybluesubi
Member#: 53526
1997 Impreza
black
I really just wanna get the car set up with the turbo and have all the exhaust done then I'll switch to a bigger turbo once I get new injectors, reflashed ecu, fuel pump and fuel pressure regulator. Since I can't seem to find a good header I'm gonna keep the one I have and have a local exhaust guy make me an up pipe and downpipe, then straight pipe the rest of the exhaust.
Old 08-12-2005, 08:34 PM   #9
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
I can build anything you need... I have a hydrolic exhaust pipe bender, mig welder, 45 sticks of 10' exhaust pipe from 1.5 inch to 3 inch, and all the tools! pretty soon i plan to produce a "bolt on turbo kit" for the ej22 in an impreza, since im building a turbo kit for one myself i will just make a few copys.
Mike
Old 08-12-2005, 08:40 PM   #10
Tats
Member#: 5692
WTF? YES! I am
better than you!
Coolent: Try splicing into the heater hoses. The AVO kit use the TB for it.
Tats is offline   Reply With Quote
Old 06-23-2007, 01:32 AM   #11
boyleia1
Member#: 141519
1997 OBS
Colbolt Firemist Blue
hey Mybluesubi,
I was reading through this and just wanted to know if you had any success with the turbo on your car.. if so how much boost did/are you giving it and whats does it dyno at. I just picked up a 1997 OBS and i would like to put a ej22t in it next year but for now i would like to turbo the na ej22 just trying to collect some info on what it can handle. Thanks
~Ian
boyleia1 is offline   Reply With Quote
Old 06-23-2007, 01:48 AM   #12
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
zombie thread........ya what ever happened to this car, sounded neat; buy car for $200, throw $2,000 at it and beat $20,000 car in drag race.
~Josh~
Old 06-23-2007, 02:23 AM   #13
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
I got my coolant from the throttle body coolant lines. Simply bypass or tap into the lines and that gives enough for the turbo.
Harenil is offline   Reply With Quote
Old 06-23-2007, 05:09 PM   #14
mybluesubi
Member#: 53526
1997 Impreza
black
I have been slow on the go getting this turbo put in my car. I have a TD05, and all the necessary stuff to put it all together but I'm having issues with a few things. I have to make my own custom up-pipe cause there isn't one for the EJ22 exhust manifold. My biggest factor is she's my daily driver and that makes it hard to do extensive work on her. Also, I've been reading that it's not good to push over 8 lbs on an open deck block. There is a guy here in town that has an RS with the EJ25 phase I motor boosting 10 lbs and doesn't have any issues though. I've seen him at the track and that thing is freakin quick! Now that I'm not working I should have more time to work on the car. I just need to find someone with a welder and I can do the exhaust myself. I will keep posted when I start working on it. I have 316,500 miles on my heads and about 130k on the block so I'm a tad worried about that and how it'll hold up to boost. I guess if worst comes to worst I can just put the EJ25 phase I I have sitting in my garage in the car.
Old 06-23-2007, 10:15 PM   #15
Harenil
Member#: 93071
you could get a mig welder. Generally cost around $150 for a cheap one, sometimes even less.
Old 06-27-2007, 03:51 PM   #16
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
Ok, the open deck motor is not as big a problem as you think - its your n/a ecu and the higher compression pistons that are going to be your main problem.....
You n/a ecu is not capable of supplying the proper amounts of fuel needed, nor is it capable of dialing in the right amount of retard that boost setups need.
The higher compression pistons are going to give you a big headache in the long run.... Pistons are the main reason why most people run VERY low boost on otherwise non-turbo models... On top of that, you are probably going to see some blowby because your piston rings are probably a little tired after 100k. The heads I wouldnt worry about too much....
Your main concern with the open deck block and high psi is probably the head gasket.... As long as you run an ej22t head gasket, you shouldnt have a problem with the cylinders walking.
If you only plan on running 8 psi - I would consider doing the headgaskets and getting some sort of piggyback to control fuel and timing.
If you plan on running more than 8 psi, you are going to need to decrease compression somehow.... DOHC heads or turbo pistons will do....
I actually just rebuilt an ej22 open deck with turbo pistons, dohc heads, sti injectors and a t3 with a tmic. Ran well until a few days ago - electrical issues suck....
gto7419 is offline   Reply With Quote
FS: (NJ) '97 OBS EJ22 turbo kit less turbo Quickkid80 Engine/Power/Exhaust 1 02-15-2010 07:27 PM
EJ22 swap install help drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-01-2005 02:12 AM
are the EJ22 turbo and non-turbo ECUs swappable? JonofScio Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-04-2004 12:49 AM
Feeler: 1994 Turbo Legacy Ej22 Turbo TheWRXMan Private Vehicle 'For Sale' Classifieds 2 02-28-2004 12:42 AM
EJ22 turbo swap questions oldpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-24-2001 10:27 AM
