Old 07-20-2005, 07:31 PM   #1
TrickNipple
moon moon
Member#: 86213
Legacy Hazard problem
I was doing an interior color change and realize my hazard switch light is off, I pulled it out yesterday and I couldnt get the old bulb out. Does anyone have a suggestion on how to get it out or know if I can even get a new one or if I would need a whole new switch?
TrickNipple is offline   Reply With Quote
Old 07-20-2005, 09:49 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I used chewing gum one time to get some of those damn bulbs out. The engineer that designed them needs to be shot in the foot, punched in the nose, and kicked in the family jewels. Not sure about the hazard switch, but if you can find a bulb that comes out...then it must be do-able.
fibuz
fibuz is offline   Reply With Quote
Old 07-20-2005, 09:54 PM   #3
TrickNipple
moon moon
Member#: 86213
The same thing goes for the lights in the switches, same bad design. Whats weird is those you can take out but they dont sell a replacement for them. So I had to steal one out of my cruise control since I never use it. I love a lot of things about Subaru but some are just DUMB.
Old 07-20-2005, 10:01 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Luckily(I guess), most of the switches in subaru's are made and designed by Nissan. Stupid Nissan. Yay Subaru!
fibuz
Old 07-23-2005, 01:02 AM   #5
PowerMatt
Member#: 45549
2008 Impreza 2.5i
On the subject of burned out lights, the entire a/c panel on my '96 has been burned out since I got it (with the exception of the LED's of course), but I'll be monkey's uncle if I can find a good way to get it off other than pulling out the entire dash. I've memorized the layout, so it's not much trouble at night to use. I can live without it being lit up if there's no simple way to do it.
PowerMatt is offline   Reply With Quote
Old 07-23-2005, 02:13 AM   #6
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Yes, there is an Easy way. Pulling the dash won't help you at all because the HVAC Ducts run right behind the AC Mode Panel. There is 8 screws, and you can pull the panel out itself. There is 3 light bulbs that control all of the lighting on that panel. If you need pics on how to do it, I'll take some and make a walk through tomorrow.
Mike
wrx_driver_2002 is offline   Reply With Quote
Old 07-23-2005, 04:44 AM   #7
TrickNipple
moon moon
Member#: 86213
Legacy
Good going hijacking me thread there is a pretty good how to over at scooby mods http://www.scoobymods.com/forums/showthread.php?t=91 that should help you. And one thing that made it easier for me was to unhook the fan controll cable at the other end, its under the glovebox all the way in the center. Once you have the controls out you should be able to see where it goes and its fairly easy to disconnect. You need to unclip it from the metal clip and the just slide it off of the plastic post. Hmmmm now I think I am going to have to take pictures of it to explain.
Old 07-23-2005, 12:57 PM   #8
PowerMatt
Member#: 45549
2008 Impreza 2.5i
Thanks for the info, I've been trying to figure out how that plastic cover comes off. The Haynes manual really does not do a good job of explaining (or illustrating) it.
Old 09-13-2005, 03:42 PM   #9
PowerMatt
Member#: 45549
2008 Impreza 2.5i
Just a small update to this. The Radio Shack bulbs mentioned in the thread that NickLippert linked to are Radio Shack catalog number 272-1092. I don't know if the bulbs have changed since that post was made, but they're slightly smaller than the factory bulbs. They still seem to work just fine (althought the little green rubber thing that covers the bulb will either sit half off the bulb or kind of bunched up). It's not all that difficult to remove the bulbs from the plastic bases and replace them. Only slightly more complicated than changing a christmas tree bulb.
I got all three bulbs changed out and they all seem to be working fine. It is *much* easier to remove the temperature control cable from the fan box than from the controls.
Recurring CEL, yet "no problem codes found". Datalogs included karnick Engine Management & Tuning 4 06-03-2010 09:40 PM
Problem after installing JDM Red Hazard button balzak Interior & Exterior Modification 6 02-01-2010 08:58 PM
JDM Hazard switch & USDM Hazard switch meat_WRX Interior/Dressup/Audio & Security 15 07-03-2008 07:39 AM
strange problem with hazards blinking z Service & Maintenance 3 05-14-2008 10:07 PM
NY- 2007 STI OEM audio-in and hazard button. Limited Red Hazard Button Spin4 Interior/Dressup/Audio & Security 15 04-13-2008 01:25 AM
