Old 08-10-2001, 10:23 PM   #1
iemonslice
Member#: 8882
02 impreza wrx
srp
Default looking to buy jack and jackstands
so what kind of a jack and jackstand should i be looking for? are there any brands i should be paying more attention to?
iemonslice is offline   Reply With Quote
Old 08-11-2001, 12:16 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
AutoZone has a special on 2 ton capacity jackstands right now- $9.99 for a pair of them! I just picked up 2 sets .
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Don't whiz on the electric fence!
Old 08-11-2001, 12:36 AM   #3
rkkwan
Member#: 5596
2010 Honda Fit Sport
I tried getting one of those cheap 2-ton jack and stands kit from Wal-Mart, but discovered that because of the long suspension travel of my WRX, I can't even get the front wheels off the ground when the jack's already at its maximum height.
I don't know what is the minimum height you need, but I can tell you the cheapos won't work.
-Ray
rkkwan is offline   Reply With Quote
Old 08-11-2001, 12:51 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
My major problem is getting the floor jack under the car and having enough room to get it moving- damn lowered suspension . I have to jack one side of the car up a bit to get the floor jack enough room to start moving!
Brian
Old 08-11-2001, 12:59 AM   #5
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Unhappy
Ouch! My local AutoZone doesn't have any sale going on right now: $16 for a pair... so I settled for the $15 ones. Drove 5 miles to get that. Oh well, I am stupid for that $1 difference. Btw, it's made by AC Delco, although I wouldn't mind one made by Prodrive :P
-Alan (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 08-11-2001, 04:05 AM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
jackstands-- just about anywhere
cheap, good quality chinese jacks-- Harbor Freight. you can get really bigguns, and some of them can even fit under very low cars.
ColinL is offline   Reply With Quote
Old 08-11-2001, 05:58 AM   #7
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Had my Wal-Mart jackstands and matching jack for about 6, maybe 8 years now. Good enough to jack up my Nissan 4X4, Ford F150, and various other vehicles I've owned. Hope to be jackin up an RS by year's end. I think I might have paid $20 for the set. I'd say I got my money's worth. Get 4 stands instead of 2. Makes tire rotations and other stuff much easier, and safer.
Streetman is offline   Reply With Quote
Old 08-11-2001, 10:11 AM   #8
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
I bought the companion set from Sears about a year ago. It comes with a 3 ton floor jack (really nice!) and two 3 ton ratchet type jackstands. I had 2 similar jackstands already, so now I have a complete set. The Sears set was on sale for about $100.00. Very high quality.
Fred
Fred Zaplitny is offline   Reply With Quote
Old 08-11-2001, 11:01 PM   #9
Julian
Member#: 1182
MY00 RS
BRP
Concur on the two pairs of jackstands. Also concur on the Sears 3-ton jack...19" max height means I can actually get the wheels off the ground! 2-1/4 ton jacks can BARELY do that, and 2-ton jacks can't.
Another nice feature to look for is one-pump lift...one pump of the handle brings the cradle of the jack up to whatever it's lifting. $10 pairs of jack stands are fine, but don't skimp on the jack. Some things are worth it.
Julian
Julian is offline   Reply With Quote
Old 08-12-2001, 01:14 AM   #10
foxdeman
Member#: 8913
2013 BRZ
WRBP
im not going to skimp on jackstands either, there the only thing keeping the car off my head !!
foxdeman is offline   Reply With Quote
Old 08-12-2001, 02:28 AM   #11
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Ramps are also handy to have around for those items which don't need the wheels removed.
I just bought two sets of the $15 jack stands at autozone.
remarcable is offline   Reply With Quote
Old 08-12-2001, 03:36 AM   #12
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Now here is my question:
Where EXACTLY do I jack up my car with the hydraulic lift? I know the OEM ones, but can't put the jackstands when I already used up that one of four jacking spots described on Owner's Manual. I heard the rear diff. for rear jacking?!
How about the front then? I like those lift better than the OEM one.
Thanks
Old 08-12-2001, 09:36 AM   #13
Porter
Member#: 486
2004 Forester XT
bug spattered
If you want a GOOD long travel floor jack and a set of decent jackstands for hella cheap, go here:
http://www.harborfreight.com
I got a 3 ton long travel hydraulic shop jack and 4 jackstands for around 35 bucks.
Porter is offline   Reply With Quote
Old 08-12-2001, 09:56 AM   #14
dave1rr
Member#: 2826
1996 Impreza Outback
Deep Navy Pearl/Slate
Alan,
When lifting with a floor jack, yes, you do use the differential when lifting the rear. For the front, use the crossmember behind the oil pan. These jack points are those specified in the Subaru manual. I also use a block of wood on the jack when lifting, but is probably not necessary.
As far as locating the jackstands, I place them on the frame just inside the flange at the jack points. I would like to know where others support the car with jackstands.
Dave
Alan, tried to send you a e-mail but it's blocked. e-mail me if you need a hand, you could stop over.
dave1rr is offline   Reply With Quote
Old 08-12-2001, 03:23 PM   #15
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Wow! From Toledo too?
Maybe we can get together for a chat or two in the future then, assuming we both have spare time to spend
Hmmm, is it okay to jack from any point of the rear diff., or the center portion of it?
I think I know where that crossmember is...how come my manual doesn't say it?
Anyway, thanks and nice to meet you dave1rr
Old 08-12-2001, 05:03 PM   #16
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I use the jack that came with the car. I made a drill attachment for speed jacking. I have a trusty log that makes a fine jackstand.
alexs001 is offline   Reply With Quote
Looking to buy in bulk and sell various things - But what to buy? sedagive Off-Topic 31 12-29-2009 08:58 AM
FS: American General 3000lb jack and jackstands - $40/all! wayoutwest SCIC Private Classifieds 5 03-25-2008 01:11 PM
Looking to borrow jack, jackstands, engine hoist, tranny jack, air tools? moss Mid Atlantic Impreza Club -- MAIC 2 06-27-2006 04:14 PM
looking to buy headers and flex joint uppipe wrxsti143 Mid Atlantic Impreza Club -- MAIC 0 05-24-2004 01:22 AM
I am looking to buy springs and a rear brace Ghomer1 Brakes, Steering & Suspension 2 08-04-2001 11:51 PM
