Old 07-21-2005, 12:38 PM   #1
greysave
Member#: 62395
2005 STI
Default Shaft Play
What exactly is shaft play? How exactly do I check for it? I was pulling up and down on the bolt that goes to the wheel. It moves slightly. I can also move the bolt slightly to the side. I just bought a 20g from this effing snake a$% and it is moving. How do you go about trying to get your money back from someone who jerks you?
greysave is offline   Reply With Quote
Old 07-21-2005, 12:41 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Umm, i'm no expert but i have seen a couple hundred broken turbo's off trucks. Shaft play should be up and down slightly but there should be no movement to the side cause the blades could touch the housing and go kaboom. If its a used turbo your probably screwed. Could probably have it rebuilt though
Old 07-21-2005, 01:12 PM   #3
Depeche
Member#: 33650
3005 Ford
Thundercougarfalconbird
whew, when i read your title i thought something nauty was going on in here
Depeche is offline   Reply With Quote
Old 07-21-2005, 01:15 PM   #4
Funkmonster
Member#: 82114
2004 WRX
^^Yeah a little movement up and down is normal, side to side = bad. Did you get it from someone local? Ebay? You could send it to Deadbolt to find out for sure what's up with it, and I'm pretty sure a 20G is rebuildable.
Funkmonster is offline   Reply With Quote
Old 07-23-2005, 01:07 PM   #5
greysave
Member#: 62395
2005 STI
I bought it off dsmtuners.com...I bought it for a dsm.
Rebuilt turbo, no Shaft play yesterday, shaft play today? NITROS MWSOC Private Classifieds 0 12-22-2007 03:01 PM
fs: td04 with 30.xxx no shaft play! slaterdrew Private 'For Sale' Classifieds 1 03-31-2004 05:31 PM
shaft play? White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-25-2003 01:58 AM
Shaft play specs for VF series turbos? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-14-2003 01:42 PM
SR40 Shaft Play - How much is acceptable? KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-11-2003 12:51 PM
