Old 07-21-2005, 03:16 PM   #1
DRWRX28
Member#: 71431
2005 STi
Default How do you hook up DCCD in a WRX with a USDM tranny?
everyone has told me its way to hard to wire the DCCD up. i have a wrx and im putting in a USDM tranny in it because i cant afford the JDM tranny. is there a way to hook up the DCCD on it so it wont drive like a open diff RS? or is there a wire diagram that i missed when did a serch on it? thanks everyone
josh
DRWRX28 is offline   Reply With Quote
Old 07-21-2005, 03:32 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The RS does not have an open center diff, and the car will not drive as though it does without the DCCD controller- it will remain unadjustable but still function. If you want to hook up the DCCD, there are aftermarket controllers available that are easier to hook up and less expensive than the factory bits.
Brian
Old 07-21-2005, 04:22 PM   #3
DRWRX28
Member#: 71431
2005 STi
what kind of controllers are there in the aftermarket? i have never seen them before can u give me a link to find some? please?
Old 07-21-2005, 04:54 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
are you referring to a six speed? because you cant hook up dccd on a normal wrx tranny since its not an electronic center diff. Just asking because some people have assumed that you can on the 5mt.
Ben
Old 07-21-2005, 05:26 PM   #5
DRWRX28
Member#: 71431
2005 STi
yes a 6spd
Old 07-21-2005, 08:32 PM   #6
ElJefe
Member#: 32968
2002 WRX 6 Speed MT
'05 Evo GSR, 03 ///M3 SMG
First of all the DCCD controller is not hard to wire up for basic manual operation. If you want to run it in auto mode then you will need to hook up a lot more wires and sensors along with an STI ecu. If youre getting a US STi tranny just be sure to get the roller knob and DCCD controller, that way you can control the distribution of torque from 65R/35F to 50R/50F, and some in betweens. I currently have a JDM 6 speed with DCCD controller hooked up and run it 99% of the time in default which is 65R/35F and lock up the center diff whenever I have to, like at the track.
ElJefe is offline   Reply With Quote
Old 07-21-2005, 09:26 PM   #7
DRWRX28
Member#: 71431
2005 STi
is there a instruction pdf somewere? because im having the tech at subaru do the swap for me and he doesnt know how to do it, so i wanted to give him instructions to do it? or somthing along those lines and yes it is a usdm sti tranny. thanks
Old 07-22-2005, 12:45 AM   #8
ElJefe
Member#: 32968
2002 WRX 6 Speed MT
He should have access to an STi manual since he works at Subaru. I will try to find a pdf dccd controller pinout and e mail it to you. Just PM me your e mail adress and I will send it to you as soon as I find it.
how do i hook up AVCS 0n 02 wrx 08 sti block with 06 wrx heads sgiord86 Built Motor Discussion 8 10-05-2009 09:36 AM
PS3 owners, how do you hook up to DVI inputs? MF-DIF Off-Topic 8 11-19-2008 07:32 PM
How do you hook up JDM lights with Hanabi 8000k already in them? samwY Electrical & Lighting 0 01-14-2004 04:39 PM
how do you hook up the hpbc w/a UTEC frdawg Engine Management & Tuning 1 04-17-2003 01:00 PM
how do you hook up a voltmeter up to the front o2 sensor? inpreza kid Normally Aspirated Powertrain 2 06-06-2001 04:38 AM
Message Board Statistics All times are GMT -4. The time now is 10:11 AM.
