Old 07-21-2005, 10:44 PM   #1
gc8impreza00
Member#: 81107
2000 2.5rs
silverthorn/Carbon Fiber
Question Walbro Fuel Pump Question!!
Ok so I just installed the walbro 255lph fuel pump and I started up the car and everythin worked fine but I could here the pump humming while i was at idle. I didnt have the backseat put back together or anythin so i guess im just wonderin is that humming normal? is it because its a larger pump so its louder? or maybe just because I havent put the seat back? I feel like an idiot I guess I just didnt wanna put everythin back if I had to fix somethin ... anyway if anyone has experience with this please let me know if this is normal!!! THANK YOU!!
gc8impreza00 is offline   Reply With Quote
Old 07-21-2005, 10:53 PM   #2
Absubtle
Member#: 85862
Yeap, will be alittle noiser than a stocker fuel pump. Good job on the install.
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 07-21-2005, 10:56 PM   #3
gc8impreza00
Member#: 81107
2000 2.5rs
shaweet dude thanks
Old 08-05-2005, 09:26 PM   #4
AzN121184
Member#: 40943
2003 subaru wrx
aspen white
what's the diff between the 255 pump and the 342 pump? thanks
AzN121184 is offline   Reply With Quote
Old 08-06-2005, 12:53 PM   #5
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
More flow?! That's one concern I have with a bigger pump since naturally an RS-T don't have the circuits to run the pump at different speed.
kgb is offline   Reply With Quote
Old 08-06-2005, 01:56 PM   #6
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Dark Slvr / Crystal Slvr
the sound is perfectly normal, even with seats in you will still here it whining :-P
JessesTalon is offline   Reply With Quote
Walbro Fuel Pump Question Rampage180 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-25-2005 07:33 PM
Walbro fuel pump question Rampage180 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-12-2005 01:29 PM
Walbro fuel pump question Don Arm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-01-2004 02:59 PM
Walbro Fuel pump questions FRWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-20-2003 04:49 PM
('93-'01) Walbro fuel pump question svxr8dr Impreza Forum 2 01-02-2003 11:58 AM
