Old 07-22-2005, 11:23 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Will STi Group-N Strut Top Mounts help eliminate clunking on AGX strut?
Right rear strut has been making this clunking noise since the day of installation. Since then I had tried replacing tophat with OEM one, which eliminated the clunking for about 2000 miles. Since then the noise has come back...
I am debating whether I should get a pair of STi Group-N Strut Top Mounts from gruppe-s.com for $160 shipped.
This noise is just driving me crazy so that I'd rather just drive Matrix.
What do you guys think? will it help or make it worse?
Thanks,
Tim
Old 07-22-2005, 11:47 PM   #2
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
When you put on the suspension did you change the 17mm nut that connects the strut to the top hat or did you reuse your old one?
~Leor
WRC1 is offline   Reply With Quote
Old 07-22-2005, 11:47 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
No, I have not replaced the nuts... am I suppose to?
Old 07-23-2005, 01:32 AM   #4
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
yes...
darksands is offline   Reply With Quote
Old 07-23-2005, 04:28 AM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
how can that cause clunking noise?
Old 07-23-2005, 04:33 AM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
what else could cause this clunking noise?
Old 07-23-2005, 04:34 AM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
washer has been installed correctly by the way... wider side facing down.
Old 07-23-2005, 06:01 AM   #8
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
It is most likely that nut. They are self locking nuts, if they are used once you cannot reuse them they will not lock and will loosen. Once it loosens a little that clunk will become louder and louder.
Goto subaru buy all 4 nuts, then goto home depot and buy 4 7/8 inch lock washers. Use the lock washers as and the new nuts sound should go away.
~leor
Old 07-31-2005, 11:01 AM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Aren't nuts used on AGX different from ones used on OEM strut? also, what's the correct orientation of the washer? should side with bigger diameter facing up or down? I believe nuts that came with AGX is coated with gold if I remember correctly...
Old 07-31-2005, 02:42 PM   #10
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
I swapped springs a couple weeks ago and reused the nut. (none of the spring install guides I saw mentioned replacing it.) If I want to put a new one on is it better to replace it with the suspension unloaded, or with the car on the ground, or does it not matter?
Will you be able to get proper torque on it without the strut spinning?
austinpike is offline   Reply With Quote
Old 07-31-2005, 03:46 PM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
This is what I'm going to do. I am going to take off a rear seat and make access to self locking nut available. I will unbolt it and try to replace it with new self locking nut without taking strut apart from the car. Not sure if this method will work, but I see why not...
Old 07-31-2005, 07:05 PM   #12
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question
The KYB should have there own nuts. just put some locktite on them when you tq them down so they won't back off.
John2.5RS is offline   Reply With Quote
Old 07-31-2005, 07:07 PM   #13
John2.5RS
Member#: 1140
'13 F150 Ecoboost
Default oh ya
I'm pretty sure the KYB nuts are bigger than the stock ones so you won't be able to buy them at the dealership. unless they changed them on the newer models.
Old 07-31-2005, 08:05 PM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yes, KYB stuts have their own nuts which are bigger. I do not recall seeing on a manual that you need to replace it eveytime strut is disassembled. I will try using locktite and see what happens...
What do you guys think of my method of removing three nuts at the top and make top strut nut accessible from the not without removing the strut? Would this work nicely?
I just don't want to get another alignment done again.
Old 08-02-2005, 09:49 PM   #15
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I disassembled the strut today. Found out that there was no washer in there... I went to Lowe's to get a washer and put everything back. Also, I put a drop of locktite (med. strength)...
DIY: Front Group N strut top mount install on 02 WRX txl146 Brakes, Steering & Suspension 7 09-18-2010 01:37 AM
KYB AGXs, Eibach springs, Group N Strut top mounts bliu SCIC Private Classifieds 14 01-04-2008 05:52 PM
STI strut Top mount Help! vicdeng Brakes, Steering & Suspension 10 08-12-2007 09:27 PM
Identifiying STI/Group N Strut Top Mounts sierra suby Brakes, Steering & Suspension 16 07-27-2004 10:17 AM
CT - Front Strut Top Mount -STi Group 'N' CTKAG Private 'For Sale' Classifieds 5 09-20-2003 10:19 PM
