Old 07-23-2005, 04:12 AM   #1
Hiroki Tada
Member#: 8048
Default Grinding noise at 4-5k
Grinding noise happens when I engine brake and the engine revs down between 4-5k rpm. Im at a loss for what could be the problem. Car seems ok, all fluids have been continually and carefully monitored and nothing is amiss. O2 sensor was replaced about 1k kms ago, currently running a ghetto-style DIY CAI (just an SS pipe from the filterbox to the fender wall), sparks were changed last year and am using OEMs also grounded with DIY stuff. Aside from Mobil 1 synthetics (10w in winter 15w summer) all fluids are OEM.
There are a few known issues that I think are irrelevant but I'll list them here just in case.
-SS CBE has a leak from the joints (pipe between reasonator/2nd cat)
-although only 60K kms, the car is tracked heavily in the summer.
-air filter was changed at 48k (also oem)
so, Que??
Anything I should be really worried about? Is it nothing serious or should I part the Leggy out and get myself an IS300?
Hiroki Tada is offline   Reply With Quote
Old 07-25-2005, 03:15 PM   #2
Hiroki Tada
Member#: 8048
nothing?
maybe a mod can move this over to the engine tech forums?
Old 07-25-2005, 03:18 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Are you sur eit is a grind and not a rattle? Perhaps a heat shield or something? Resonance of the engine at certain RPM's will set of rattles, shakes, hums....mine just started a funky rattle but only at 3-4000RPM and only in 3rd or 4th gear.
tora is offline   Reply With Quote
Old 07-25-2005, 03:50 PM   #4
Teh Legacy
Member#: 9853
to keep your mouth
shut.
That's exactly what it sounds like to me.
Teh Legacy is offline   Reply With Quote
Old 07-25-2005, 04:26 PM   #5
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Yeah my heat shield rattles between 2k and 3k RPMs, especially when engine braking/coasting.
Plays_With_toys is offline   Reply With Quote
Old 08-25-2005, 10:27 AM   #6
ShutterBC
Member#: 70361
2005 LGT ltd wag 5MT
Question
This is *precisely* what happened to my car... now it has progressed to rattles at 3.5 - 4k as well.
I've gone under my car and I can see that corrosion has eaten the clamp securing the tail end of the heatshield on the driver's side. I have a clamp with some metal underneath it, and then a partially rusted heat shield no longer clamped down.
I'm no car mechanic, just a newbie -- could I buy a new heat shield from a junkyard or is there a way to secure the existing one even though the end of it has rusted? I have no intention of performance tuning my 1998 OBS... I just like a quieter car.
ShutterBC is offline   Reply With Quote
Old 08-25-2005, 10:48 AM   #7
EJLsubie
Member#: 59407
2004 Legacy 35th Ann
Mystic Blue
Had the same thing happen round 2500-3000 rpm, usually in second gear and engine braking, it was the heat sheild. went to a muffler shop and they welded it. Bring it to a muffler shop and get it looked at.
EJLsubie is offline   Reply With Quote
Old 08-25-2005, 11:23 AM   #8
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
I donít know if this has been mentioned yet but check the heat shield
It seems to be the culprit for 95% of the rpm related rattles.
bhall is offline   Reply With Quote
Old 08-25-2005, 12:19 PM   #9
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
+another for the heatshild. Mine sounds like a BOV when I shift.
TRH_legacy2k is offline   Reply With Quote
Old 08-25-2005, 12:52 PM   #10
ShutterBC
Member#: 70361
Aha... welding it just didn't occur to me because I don't own a torch, LOL. Thanks, your brain is working much better than mine.
Misfiring in all four cylinders at 4.5k rpm....datalog inside. cheese tits Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-12-2008 03:13 PM
Grinding Noise at Idle on a 04 STi ! viaburn26 Transmission (AT/MT) & Driveline 2 04-23-2008 03:34 AM
Clutch/gear grinding noise at idle? rhinotech Transmission (AT/MT) & Driveline 0 12-13-2007 04:27 PM
hesitation at 4-5k rpm? AmirK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-16-2006 03:44 AM
Speedometer died and rev limiter is at 4.5k yodamonkey64 Normally Aspirated Powertrain 8 03-29-2006 08:25 PM
