Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-23-2005, 01:56 PM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default VF39 upgrade tips?
For those of you who have upgraded their Baja's turbo, what special items should I make sure I have before starting?
Here's what I can think of so far:
- downpipe to turbo gasket - got from dealer (Xcell. TBE does not have)
- uppipe to turbo gasket
- uppipe other end gasket
- new studs for uppipe (came with Helix uppipe)
- new studs for turbo
- m10x1.25 x 1.5" <--- is that the correct size? recommended vendor?
- PB Blaster, let it sit over night on all bolts
- anti-seize
- torque specifications?
Any special tools or techniques recommended?
thanks.
02_Forester is offline   Reply With Quote
Old 07-24-2005, 07:01 PM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Vise grips to muckle onto those broken bolts *knocks on wood* and one of those propane soldering torches from the hardware store incase you need some heat for those broken bolts *knocks on wood*
You know if you don't have them then you will need them, and vice versa
Chris N is offline   Reply With Quote
Old 07-26-2005, 09:11 AM   #3
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I picked up the gaskets from the dealer. Scoobymods.com has a nice write-up on installing an uppipe and lists the part numbers:
44022AA170 - Uppipe Gasket (Bottom)
44022AA150 - Uppipe Gasket (Top)
44022AA180 - Downpipe Gasket (DP to turbo)
44022AA020 - Cross pipe, Right side
14038AA000 - Manifold Gasket to the block
44022AA160 - Cross pipe, Left side
It was $70 for all the gaskets, 4 turbo studs (1 extra stud) and two BOV bolts (for the STI TMIC).
08 WRX with VF39 + TMIC - Tips psmBoXer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-11-2009 11:32 PM
VF39 upgrade problems gandapanda Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-11-2007 05:53 PM
Stock WRX turbo to VF39 upgrade questions TurboInduction1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-14-2006 10:36 PM
Deadbolt VF39 Upgrade Shabib67 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 05-11-2006 09:11 PM
ecutek and vf39 upgrade help Benjamin Tang Engine Management & Tuning 3 06-13-2004 04:24 PM
