Old 07-23-2005, 08:04 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default just parted motor...pics and questions
are those scrape marks normal? my dad said it should be fine, theyre about a thousandth <you can barely feel them> deep and look to have been caused by the rings
looks like the other pic didnt turn out
anyways theres wear marks on the crank bearings, is this normal @ 2500 miles?
should i be worried?
alex
Old 07-23-2005, 08:37 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
As to the picture you posted the crosshatching pattern is normal. I don't really know about the rest of what you said.
ai42 is offline   Reply With Quote
Old 07-23-2005, 09:12 PM   #3
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
is that an ej257?
SubasaurusWrex is online now   Reply With Quote
Old 07-23-2005, 09:12 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
the cross hatching is normal, I think he was asking about those 4 vertical scratches though.
lotusTT is offline   Reply With Quote
Old 07-23-2005, 09:56 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yes its an ej257 im having the crank/rods balanced and then puttin cp pistons in it
Old 07-24-2005, 03:11 AM   #6
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
If you are wanting some CP pistons, we can get them for you
Ben
PDXTuning is offline   Reply With Quote
Old 07-24-2005, 06:02 AM   #7
redwagon
Member#: 2181
2008 SpecB
No, not good. If you can feel those scratches at all, you will have blow-by. It's hard to tell how deep the scratches are from looking at the photo. Ask a machine shop to see if a gentle hone will remove it.
redwagon is offline   Reply With Quote
Old 07-24-2005, 02:56 PM   #8
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
That's a motor that wasn't broken in properly kiddies. At 2500 miles your bearings should look pretty flawless.
no-coast-punk is offline   Reply With Quote
Old 07-24-2005, 03:04 PM   #9
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
the cross hatch pattern is fine as someone else mentioned. however the scratches that run the length of the cylinder are definitely not normal/ok. we cant tell how bad the damage is from a picture so please have it looked at by a professional mechanic/shop in your area. your bearings should also not have any damage so i would probably replace those while you have the motor apart. if in doubt have it checked and re-checked before you re-assemble everything. good luck and please post back to let us know how it turns out.
adeliciouspizza is offline   Reply With Quote
Old 07-24-2005, 04:00 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i check in parts as a job <machine parts>
the scratches are a thousandth deep <you can barely feel them>
of course the motor wasnt broken in properly lol i dont like the idea of a soft break in
but it did have a good 800 miles of low boost/very rich however
ben, i told jarrad to order me some pistons the other day, you guys were supposed to quote me a total price then order them...lol
stay on top of your game
alex
Old 07-24-2005, 07:23 PM   #11
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
here are some more pics
thats how the bearings look
kinda a "fog" over them...but you cant feel anything
alex
Old 07-24-2005, 08:08 PM   #12
no-coast-punk
Member#: 49087
How many miles were on the motor when you first changed the oil? More than 20 by the looks of it.
Did that engine ever sit idling for an extended period during the beginning of life? Or did it ever have the crap rev'd out of it in neutral?
A machine shop might or might not be able to hone that out. There is no great rocket science to honing. Finding a bottle brush style cylinder hone shouldn't be too tricky, get a good electric drill and try it yourself. I don't think they'll hone out though.
Old 07-24-2005, 08:12 PM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah i think i changed it at 50
no i never revved it or let it sit idle more than like 3 min
ill take it to a place my friend w/ a 440whp gvr4 goes <i guess its like the only smart guy in my town >
do those bearings look ok tho?
alex
Old 07-25-2005, 01:00 AM   #14
redwagon
Member#: 2181
2008 SpecB
A scratch a full 0.001" deep is like the Grand Canyon. If you can feel it at all, even with pick or a fingernail, it's too deep. You're not going to luck out and have the new rings fix it for you. Try a hone, but if that doesn't do it, then you need to bore it. Lucky you are getting new pistons anyway.
I don't like the look of the bearings either. For what they cost, just go ahead and replace them. It's not worth putting iffy parts into the motor when you consider how much they cost to replace against the amount of labor and downtime you'll suffer later on.
Old 07-25-2005, 09:03 PM   #15
VTsuby
Member#: 81369
2007 STI
Check how much piston skirt clearance you have
Probably everyone on this board has some sort of scoring, subaru has posted on their website a piston they are developing to fight this. I would definetly get the new pistons moly coated. I wonder if you should put it all back together and get some more miles and the block if you want to bore it. If it was mine I would do the backyard hone job check all the clearances reassemble put some miles on the motor then bore it and put the new stuff in.
VTsuby is offline   Reply With Quote
Old 07-25-2005, 09:29 PM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah the skirts were quite tight....
im most likely getting twe pistons which i believe are coated
im probably just gonna do a hone and hope for the best
Old 07-25-2005, 09:35 PM   #17
VTsuby
Member#: 81369
2007 STI
Remember your peak cylinder pressures are near the top I dought you'll lose anything just clean the heck out of the bores. The should be tight they're cast, its being real loose which is bad (for a street motor).
Old 07-26-2005, 06:46 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's way worse than my Ej257, and mine was driven for 2-3k mi with a blown #4. And I plan on honing mine before I reassemble and sell it. Those bearings are pretty ugly as well. What did I tell you about tuning by detonation?
Old 07-26-2005, 11:29 PM   #19
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You should see my cylinders!
220,000 with a shot valve for the first "rebuild" No honing of course
Then I shot the shiet out of the top of #4 piston and shattered all the ring lands in it as well.
Then I again shattered #4 AND #2. Even broke a ring into about 20 pieces. I scored the top of #2 pretty good with a piece of the ring.
So I just stuck new pistons and rings in again. I only smoke a "tad" right in the morning. Then have no problems or smoke the rest of the day.
So I would say, unless you have the money to tear it down (which you did!) don't do it. But since you did, do it! I would do it, but never really had the time or money.
Doug
Old 07-27-2005, 11:40 AM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
yeah,
but Doug, you are playing at R&D and using $100 junkyard blocks. He bought a brand new Ej257 STi block. His errors have greater consequences...
Old 07-27-2005, 01:02 PM   #21
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
ok matt
i didnt tune by knock
my block had to have been screwed up by the factory
some jackass putting a crank bearing in put a ding in it, i dont believe its on an area where the crank touches it beacuse theres no scaring on the crank but something wasnt right from the beginning of the life of this motor
i also talked to tom @ techworks
he informed me that the clearance on piston to cylinder is -.01 mm to .01 mm
i must have had a tight piston
he said hes seen that many times and that a hone should fix it if not a mild bore will fix it which would probably be more benificial
alex
Old 07-27-2005, 05:09 PM   #22
Matt Monson
Member#: 832
99 2.5RS, '85 911
Old 07-27-2005, 06:29 PM   #23
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
thats not tuning by knock thats me screwing up
stop tryin to have a pissing contest w/ me online its really getting stupid
Old 07-27-2005, 07:00 PM   #24
Matt Monson
Member#: 832
99 2.5RS, '85 911
noone is trying to have a pissing contest with you. But trying to blame the damage in your engine on misassembly makes me laugh. Those pictures don't lie. That's all. Leaving this thread now...
Old 07-27-2005, 07:11 PM   #25
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
tech works said theyve seen that crap all the time
y would they blatently lie to me matt?
did you look up piston specs for clearance?
-.014 to .014
kinda weird you have to press in the piston and thats acceptable
VF23 pics and questions Nettalp Member's Car Gallery 10 04-10-2007 09:11 AM
Broken turbo, pics and questions inside Aleksey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-10-2006 08:21 AM
Broken turbo, pics and questions inside Aleksey Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-09-2006 12:38 PM
my 2.5 motor build, and questions? spoolinred Built Motor Discussion 0 06-08-2006 12:35 AM
04 WRX tranny drain plug - pic and question SIMPFLY Service & Maintenance 8 01-24-2005 01:29 AM
