Old 07-23-2005, 09:57 PM   #1
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Default Rubbing on my Kosei K-1 from Tire Rack
Hi,
I've got an '03 WRX wagon.
I bought 17x7 Kosei K1 TS in light grey from the tire rack - they specify 50 mm offset.
The thread in the beginning of this forum also says 50 mm is optimum.
My old Rota Attacks, 17x7 were 48 mm offset - I ran Bridgestone S0-3 225/45 - 17 and almost never rubbed in the rear.
After putting on the Kosei's, I immediately rubbed on easy cornerning and turning into my driveway. I had a 4 wheel alignment done and I still rub. I bought new S0-3's, 215/45-17 and I rub less, but I still rub daily.
What else can I do? I do notice when looking at the relationship of the tire to the edge of the car, these rims are closer, I am assuming this is the difference in 48 and 50 mm offset....
Thanks.
AntiochCali is offline   Reply With Quote
Old 07-23-2005, 10:45 PM   #2
Jon Bogert
Member#: 1133
'02 996 C4S '95 993
'71 911 3.0 '04 STI
No, they should be 2mm farther inboard, not closer to the fender. Something's fishy--look on the wheels and make sure they're 50mm offset.
Jon Bogert is offline   Reply With Quote
Old 07-23-2005, 10:48 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
,....betcha got the wrong wheels.....2mm offset difference shouldn't make that big a difference....not visually, anyway....so if you can 'see' it, you likely have the wrong wheels.
Old 07-23-2005, 11:12 PM   #4
linsavy
Member#: 11620
1997 GF4 -STiV3
Saab 93 TX sportcombi
Try aligning the rear with more negative camber to bring the wheel closer to the strut.
Then remove the fender rubber.
First make sure where it is rubbing...it may not be the fender.
linsavy is offline   Reply With Quote
Old 07-24-2005, 12:22 AM   #5
AntiochCali
Member#: 30185
2003 320 whp
I had to remove the fender rubber on my old Rota Attacks with 225 - actually I didn't remove it by hand, the wheel did it for me....
I can try another alignment with more negative camber, but how much negative camber can I go before either the car has problems or driving becomes less certain?
Old 07-24-2005, 12:50 AM   #6
AntiochCali
Member#: 30185
2003 320 whp
Where do I look on the wheels?
Old 07-24-2005, 01:58 AM   #7
STI4ME
Member#: 6034
It's Soo-BAH-roo
Look at the hub mating face, or the inboard side of the rim face. Might also be on a label that may say something like 17x7.0 JJ ET50. Rota Attacks come only in 17x7.5 ET48. If your Koseis are truly ET50, tehn you should not be rubbing on the fender. If you're passing by Fresno, drop by and I can take a look.
STI4ME is offline   Reply With Quote
Old 07-24-2005, 03:38 AM   #8
pityr
Member#: 31719
Originally Posted by AntiochCali
Hi,
how low is your car?
pityr is offline   Reply With Quote
Old 07-24-2005, 11:04 AM   #9
AntiochCali
Member#: 30185
2003 320 whp
I don't know - I was running V7 pinks, then because of the rubbing I went to Group4 coil overs - I really don't know how low my car is...I think rear is the same but the fronts are lower, never rub in the front...I am on maximum stiffness and I'm tearing my tires apart in the rear.
Will 18" stock subie tires/rims rub on my 2002 WRX wagon? mespinola Tire & Wheel 9 11-14-2009 09:22 AM
HELP, My fenders are rubbing on my back tires.... 1st1 Tire & Wheel 4 03-27-2009 01:22 AM
another: would this tire rub on my current setup Lordhowe Tire & Wheel 5 11-11-2008 05:11 PM
Kosei K1 TS from the Rack who has them? DetroitWRX Tire & Wheel 9 11-23-2006 12:20 PM
rally tires from tire rack rob North West Impreza Club Forum -- NWIC 2 01-19-2001 09:49 PM
Message Board Statistics All times are GMT -4. The time now is 03:43 AM.
