Old 07-24-2005, 08:33 AM   #1
tossty
Member#: 22525
2006 Subaru WRX STI
Default Clutch Fluid Air Bleeding
Ok, I replaced the Clutch line yesterday and did follow the SPT "How to" bleeding process and the clutch pedal still get stuck to the floor when pressed. If there is a trick on that I need to know since I can not get it to work. The clutch was working fine before I replaced the OEM line with a braided one. I am stuck now with this and need some help.
Thanks
tossty is offline   Reply With Quote
Old 07-24-2005, 05:25 PM   #2
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Refill the master cylinder with fresh fluid, have someone press the clutch pedal while you open the bleeder valve, then fluid flows out close the bleeder valve, have your helper release the clutch pedal, rinse and repeat.
eltrouble is offline   Reply With Quote
Old 07-24-2005, 06:19 PM   #3
Eaglesfan2422
Member#: 26445
It helps a lot to pump the clutch a few times before opening the bleeder.
Eaglesfan2422 is offline   Reply With Quote
Old 07-24-2005, 08:48 PM   #4
tossty
Member#: 22525
2006 Subaru WRX STI
Ok, will try that tomorrow to see what happens, thanks for the help.
Old 11-24-2007, 05:26 PM   #5
TheGreenMeadow
Member#: 165050
I'm having a similar problem with bleeding the clutch.
Basically, my lines are FULL of air. And I've had several different people tell me several different methods. (None of which have worked)
The hard way:
1.) open the nipple bleeder.
2.) push in the clutch.
3.) close the nipple bleeder.
4.) pull out the clutch.
5.) repeat.
The problem with that was, when I put my finger over the nipple and opened it, I could feel air being sucked in. Then it was pushed out when I pushed the clutch in. I gave up because I assume thats not supposed to happen.
The other hard way.
1.) Put clear tubing on the nipple.
2.) fill the line with brake fluid, put the other end into a battle of brake fluid.
3.) Proceed to do it the open nipple, push clutch, close nipple, lift clutch method
This didn't seem to work because I saw air bubbles just sitting in the line. So I gave up on that.
As of now I pulled the nipple bleed out completely. Someone told me that eventually, fluid should flow out the other end.
In summary, can someone tell me a fool proof, straight forward method to bleeding the clutch? Or, point out what I'm doing wrong? Any help would be GREATLY appreciated.
TheGreenMeadow is offline   Reply With Quote
Old 11-25-2007, 08:39 PM   #6
kursplat
Member#: 89528
2005 sti
crystal grey
Originally Posted by TheGreenMeadow View Post
I'm having a similar problem with bleeding the clutch...
5.) repeat.
REVERSE steps 1 and 2 and pump it 3x, then hold. get a helper to do the peddle part and don't release the peddle until the bleeder is closed.
good luck
kursplat is offline   Reply With Quote
Old 11-30-2007, 03:29 PM   #7
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
DO NOT open the nipple until the clutch is pushed in. All you are doing is sucking in air.
Fill reservoir.
1) IT's pump clutch 3-5 times and hold the clutch to the floor.
2) open nipple just enough so the fluid it pushed out.
3) close nipple
4) release clutch (may have to reach down and pull it up
repeat 1-4 and pay attention to the master reservoir. Don't let it get low at all. Keep it full at all times.
CoolRex is offline   Reply With Quote
Old 11-30-2007, 10:59 PM   #8
kursplat
Member#: 89528
2005 sti
crystal grey
good luck
Fill reservoir.
3) close nipple
whoops, syntax error. ya when your doing the pumping have the bleeder closed
Old 10-11-2009, 04:57 AM   #9
chilakas
Member#: 210354
2003 Wrx
Default This is how i bleed my clutch fluid
Ok i know some people are going to argue with me about this but this is the way i did it and it worked for me and i was able to do it alone. I had nothing but air when i first started. BEFORE EVERY STEP CHECK YOUR FLUID LEVEL AND ADD AS NEEDED BECAUSE IT WILL GO DOWN AND IF IT GETS TOO LOW U WILL GET AIR IN THE SYSTEM AND U WILL HAVE TO START ALL OVER AGAIN.
1. with the clutch released i loosen the niple on the clutch slave cylinder.
2. goin the car and press down the pedal all the way down and leave it down (it will stay down on its own cause there is no pressure from the fluid. This will push air out of the system)
3. go back to the slave cylinder and tighten the nipple (u can do this with your fingers cause it just has to be tight, dont really need to torque it down)
4. go back inside and slowly very slowly press and release the clutch pedal all the way both pressing and releasing about 5 times and leave it released.
5. repeat step 1 to 4 a couple more times
6. repeat steps 1 and 2(at this point u should be squirting nothing but fluid)
7. repeat step 3 but this time go ahead and use ur wrench for me it was a 8 mm wrench, go ahead and torque it down tight, not too tight though it doesnt need alot of torque just tight enough.
9. go back in the car and keep pressing and releasing very slowly. the pedal should start feeling tighter but be patient this will take some time maybe 10 to 30 times of slowly pressing and releasing all the way. When you start feeling it a little tighter its just a matter of time before its fully stiff and make sure u keep adding fluid as necessary.
Like i said this is what worked for me on my 03 wrx. I have done some cars but if i remember correct the procedure was the opposite of this one, I would have to loosen the nipple as the pedal was pressed down hold it and then tighten the nipple and then release the pedal all the way out. I tried this on my wrx and it just wasnt working so i tried to do the opposite (loosening the nipple while the pedal is completely released and than pressing the pedal all the way down and than tightening the nipple back on, and bingo in a matter of minutes i saw the nipple squirting nothing but fluid so i knew all i had to do is tighten the nipple and keep pumping the clutch pedal) EVEN THOUGH U CANT SEE THE NIPPLE SQUIRTING PURE FLUID BECAUSE YOU ARE INSIDE UR CAR PRESSING THE CLUTCH PEDAL ALL THE WAY, U CAN TELL THAT U ARE SQUIRTING PURE FLUID BECAUSE THE FLUID LEVEL WILL START GOING DOWN SIGNIFANCTLY.
chilakas is offline   Reply With Quote
Old 10-21-2010, 01:03 PM   #10
SLIC VIC
Member#: 187428
2006 WRX Limited
i think every post in this thread is different. can someone clarify?
SLIC VIC is offline   Reply With Quote
Old 10-21-2010, 02:49 PM   #11
SLIC VIC
Member#: 187428
2006 WRX Limited
among all the confusing instructions lol i seemed to bleed my clutch fluid "properly" but its still feeling a little looser than before....i repeated the whole process maybe about 10 times, but clutch pedal is releasing all the way up so i guess its good to go
Old 10-21-2010, 04:10 PM   #12
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
The *real* way to bleed your clutch is to remove the slave cylinder from the tranny and have the nipple pointed perfectly straight in the air as you do this process so you don't leave a bubble in the slave cylinder.
09rexwagon is offline   Reply With Quote
Old 10-24-2010, 01:43 PM   #13
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
any bleeding you NEVER pump the brakes. you are just moving the air back and forth.
5.) repeat.
slow and steady.
indytruckboy is offline   Reply With Quote
Old 09-22-2012, 02:33 PM   #14
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
i just filled the system before i installed it in the car. fool proof and you can get the nipple then at the highest point and level. this is how its done when they build the cars
Swagon_Wagon is offline   Reply With Quote
Old 09-23-2012, 09:08 PM   #15
WhatTurboLag?
Member#: 243992
2006 WRX TR
I thought the master had to be the highest point when bleeding?
WhatTurboLag? is online now   Reply With Quote
Clutch WILL NOT BLEED (WRX Slave RS Master) White 2.5rs Transmission (AT/MT) & Driveline 3 05-29-2007 10:28 PM
No clutch pedal pressure- bleeding problems BigClunke Transmission (AT/MT) & Driveline 14 10-11-2005 12:56 AM
Clutch fluid bleed bwco Vancouver Impreza Club Forum -- VIC 8 02-19-2005 04:07 AM
Bleeding Clutch Fluid? HIHO Legacy Forum 1 04-08-2002 08:16 PM
Bleeding/Replacing Clutch Fluid North Ursalia New England Impreza Club Forum -- NESIC 3 07-01-2001 08:11 PM
