Old 07-25-2005, 01:17 AM   #1
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Default Need help finishing S2000 start button, remote cig lighter, turbo timer
I need help finishing mine. Everything is in place now just need the wiring straighened out. I tried to take alot of pics since there is no real WRX how-to that I know of so I was going to write it all up for you guys. I'll post more pics of the remote mounted cigarette lighter after I get it working.
It looks good but I ran into a problem, take look at this next pic. I think I've got the right plug to wire my relay into (the blue one). That normallly goes into the white plug with is part of my HKS turbo timer harness. No my dilemma is connecting the relay the right way.
I've got the 85 and 86 on the relay figured out definately
I tried this:
85 - to start lead from S2000 button
86 - to ground
30 - to the blue switch end of the IG wire
87 - to the HKS harness end of the ST wire
87a - to the HKS harness end of the IG
I then reconnected the remaining wires on the top half of the blue plug to their counterparts on the HKS harness with some short jumpers.
With this setup, it will crank, I can hear the fuel pump priming, and the relay is clicking (working fine) the S2000 button is sitting pretty, yet it won't fire!
Now I'm wondering if the guage of wires I used was too small 14ga or if the turbo timer being wired in is causing a problem, I reconnected it back to normal and it started fine
I was using this for some instruction:
http://www.miata.net/garage/pushstart/
Here's the diagram page 11 is the igniton diagram:
http://www.northursalia.com/m...ingdiagram.pdf
ANY HELP WOULD BE GREATLY APPRICIATED!
Thanks!!!
djerickd is offline   Reply With Quote
Old 07-25-2005, 03:29 AM   #2
Phy6
Member#: 2219
2007 Exige S
Subscribe....I would like to know how this goes...
Sorry I can't give much input right now.
Phy6 is offline   Reply With Quote
Old 07-25-2005, 09:17 AM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Heeeeelp!
Old 07-25-2005, 03:36 PM   #4
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
bump for help!!!
Old 07-25-2005, 06:39 PM   #5
broadfield
Member#: 13847
1992 240sx White
Old: 2004 Sti White
Assuming you are using 12+ for the input on the S2000 start button:
85 Ground
87 12+ constant in the main IGN harness...changes from black/white to white (use heavy gauge, 12 Gauge)
86 From start lead on S2000 button (can use 18 gauge)
30 starter wire in the main IGN harness....changes from black/yellow to white/black (use 12 gauge)
Also, make sure you use a 30 amp fuse in line with the wire connected to pin 87!
That is it! You will still be able to start it with the key also! Also, make sure you have the key all the way on when you push the start button. I assume you knew that though.
Toby
broadfield is offline   Reply With Quote
Old 07-25-2005, 06:45 PM   #6
broadfield
Member#: 13847
1992 240sx White
Old: 2004 Sti White
Also, you will not use 87a!!!!! The way you had it wired, you were interrupting your IGN wire when ever you pushed the start button. The car will not start if it does not see IGN! I am not sure what you were trying to do, but you made it much more complicated than it needs to be.
Toby
Old 07-25-2005, 08:11 PM   #7
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I was thinking it wasn't getting spark, lemme go try this
Old 07-25-2005, 09:28 PM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
broadfield (Toby) you are the man!!! I simply tapped into my HKS harness, wired the 2 wires I was confused on with fuse, put the key to On and pushed the button! I shouted "IT's ALIVE!" when it actually worked! I'm going to do a big write up on my misadventures with alot of pics showing my remotely mounted cig lighter, and the the s2000 button.
Thanks again!
Old 07-25-2005, 09:31 PM   #9
broadfield
Member#: 13847
1992 240sx White
Old: 2004 Sti White
No problem man! I hope you enjoy it!
Old 07-25-2005, 09:35 PM   #10
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
on wire goes to the ign wire in the steering column...on i tapped in the radio for power...the other two wires i taped into the cig lighter for power and ground...
SQUAD_907 is offline   Reply With Quote
Old 07-25-2005, 09:40 PM   #11
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
pic of my install...can still use the key to start the car if i want-
http://forums.nasioc.com/forums/show...&postcount=196
Old 07-25-2005, 09:55 PM   #12
MF-DIF
Member#: 62197
2002 WRX, GTO
SV650N, FZ-09
Pimpers.
MF-DIF is offline   Reply With Quote
Old 07-25-2005, 10:33 PM   #13
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
oh man where did u get those JDM vents??
Old 07-26-2005, 12:58 AM   #14
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
vents in the front? just zerosports cf marker vents...
Old 07-26-2005, 09:06 AM   #15
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
no the A/C vent cupholder thingy...
Old 07-26-2005, 01:05 PM   #16
mkalbarc
Member#: 59427
2005 Legacy GT ltd
Black as night
So you still have to have the key turned on in order to use the button? Whats the point then?
PS. does look sweet though
mkalbarc is offline   Reply With Quote
Old 07-26-2005, 01:09 PM   #17
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
oh the jdm cup/card holder...friend got it for me from japan...helped him out with his car and he got me the part...cup holder portion is useless cuz the stock the turnsignals are in the way...but it's different so i installed it...lots of cutting to get it to fit too...
Old 07-26-2005, 02:00 PM   #18
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yeah I can use either the key or the s2000 button to start the car, the key must be turned to "On" for the button to work. It does look sweet and will match my JDM S203 red hazard button when it arrives
Old 07-26-2005, 02:02 PM   #19
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
oh ok, thanks! Do you have your stock one? wanna sell it?
Old 07-26-2005, 04:17 PM   #20
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
djerickd, where did you get your s2000 starter button, i was thinking about getting one. Can you make it so you can only start the car with the keys on and start button. I dont like the 2 way starting thing (where u can turn the key or press the button).
Jesse00 is offline   Reply With Quote
Old 07-26-2005, 04:27 PM   #21
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yes I think you would just cut the wire that the key start goes to, then it only starts with the button.
broadfield, do you know?
Old 07-26-2005, 04:28 PM   #22
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I got the button off eBay..
Old 07-26-2005, 06:01 PM   #23
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Do you still have to have the clutch pedal down Erick with this?
Hank3 is offline   Reply With Quote
Old 07-26-2005, 08:22 PM   #24
SubieRX
Member#: 16611
05' STi w/ meth inj
Tuned By Harman Motive
And what would happen hypothetically, if the car was running, and some moron (I'm 90% sure this will happen at least once if I do it) pushes the engine start button. Would you get that nasty grinding sound?
SubieRX is offline   Reply With Quote
Old 07-26-2005, 08:22 PM   #25
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yeah you still have to push the clutch in. I could change that tho, where's those wire cutters...
Need some help and some ideas on Boost controllers and turbo timers DK1102 Newbies & FAQs 10 10-27-2007 10:25 PM
can't close door with remote after apexi turbo timer installed. imprezaBlue Car Audio, Video & Security 5 01-23-2007 11:15 AM
Galaxy 5000RS-2W Remote Starter,Alarm,Turbo Timer WRXGSXR Private 'For Sale' Classifieds 0 01-13-2006 09:08 AM
Anyone try to brighten up an S2000 start button djerickd Interior & Exterior Modification 13 11-06-2005 03:12 PM
I need help finishing my turbo kit ursine Normally Aspirated with bolt-on Forced Induction Powertrain 46 04-01-2004 04:08 PM
