Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 07-25-2005, 09:49 PM   #1
GrandpreRS
Member#: 91448
99RS SOHC+COBB EJ257
20G+FMIC+660cc+Hydra2.5
Question EJ257 block with SOHC heads.
In mating SOHC heads with STI EJ257 Block will this change the cylinder compression ratio at all. the stock ej253 compression is 9.1:1 and the STI is 8.1:1. Or if I put Sti pistons and rods in my stock ej253 block with stock heads will this change the compression?
GrandpreRS is offline   Reply With Quote
Old 07-25-2005, 10:35 PM   #2
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
ExecNav is offline   Reply With Quote
Old 07-26-2005, 02:14 AM   #3
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
Just to let you know the Ej253 is 10.0:1 and the EJ257 is 8.2:1. Well I know that for sure in the 05 models at least.
JonzFaSTi is offline   Reply With Quote
Old 07-26-2005, 10:30 PM   #4
GrandpreRS
Member#: 91448
the 99 ej253 is 9.1:1
Old 07-26-2005, 10:38 PM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Uh, try 9.7:1
Wedge is offline   Reply With Quote
Old 07-26-2005, 11:12 PM   #6
ranger5oh
Member#: 77752
5Sti 2005 Sti
eleventy seven : 1
ranger5oh is offline   Reply With Quote
Old 07-27-2005, 10:44 AM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Talk about a bad thread as a reference for CRs.
maxiav is offline   Reply With Quote
Old 07-27-2005, 10:57 AM   #8
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I'm pretty sure this thread could've ended after the first reply.
-Brett
Old 07-27-2005, 12:38 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
-Brett
But then the newbs couldn't argue about known facts and get their post counts up...
Ej257 block with Ej22 heads HiCompwagon Built Motor Discussion 14 02-15-2010 07:26 PM
STI block with SOHC heads sandman25 Engine/Power/Exhaust 4 02-13-2010 03:11 PM
EJ257 block with ported WRX heads and bigger cams wrxfactor Subaru Conversions 6 05-09-2006 11:27 AM
Compression Ratio on EJ257 block with 98 DOHC 2.5 L heads jkjersey Subaru Conversions 0 04-20-2006 11:32 AM
EJ257 block with EJ207 heads. Mas redline? BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-16-2003 05:06 PM
