Old 07-26-2005, 12:54 AM   #1
hauvis
Member#: 50262
2000 Protege 90whp
Default At what PSI does the Stock STI blow off leak boost?
I am running 20psi in 4th gear with stock turbo.
I am wondering if my stock blow off valve could possible be leaking or even worse causing backpresussre and compressor surge.
The car is running fine to my knowledge but it never hurts to think about these things
hauvis is offline   Reply With Quote
Old 07-26-2005, 09:26 AM   #2
dream
Member#: 37003
2015 WRX
Im running 25+ right now with the stock bov and no leaks.
dream is offline   Reply With Quote
Old 07-26-2005, 12:54 PM   #3
InLoveWithBoost
Member#: 92138
* sl600 z06 supra
cts-v sti 996tt *
I personally like the BOV sound, why haven't you guys upgraded?
InLoveWithBoost is offline   Reply With Quote
Old 07-26-2005, 01:42 PM   #4
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
i'm at 20 with stocker.
i doubt i'm leaking.
when the new perrin one comes out i'll install it and let you know.
boost whore.
DISCOPOPE is offline   Reply With Quote
Old 07-26-2005, 01:48 PM   #5
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
wow I must have of got a bad stock BPV cause mine started to leak at 16 psi with my 20g. The Turbosmart dual port bov solved this issue for me.
fastwrx006 is offline   Reply With Quote
Old 07-26-2005, 01:53 PM   #6
DISCOPOPE
Member#: 43339
2oo4 STi
i've wondered how one determines if his/her bov is leaking...
how did you diaganose this?
not trying to be an ass at all, i'm genuinly interested..
Old 07-26-2005, 02:15 PM   #7
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
When I went to get tuned with my 20g my turner could not even reach 300whp, he told me it would not boost more than 14 - 15 psi till redline. It just would not hold boost. I brought a turbosmart bov that day by chance, I told him about it so we gave it a shot. With the turbosmart bov on we were able to hit over 300whp and hold 18- 19 psi till redline(we could have run more boost but I wanted to run under 20 psi). So I guess it must have been leaking cause we could not hold much boost in any part of the rev range, with the turbosmart on it holds boost rock solid.
Old 07-26-2005, 02:46 PM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
24.65 PSI, get it right biotch!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-26-2005, 02:52 PM   #9
dream
Member#: 37003
2015 WRX
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-27-2005, 08:52 PM   #10
dudical26
Member#: 37934
Does any one know how to determine if their BOV is leaking?
dudical26 is offline   Reply With Quote
Old 10-27-2005, 10:34 PM   #11
wgknestrick
Member#: 32576
04 STI
Pressurize the intake track with a home-made fitting (valve stem drilled into a plumbing cap that is pluged into your intake track). Put a vacuum gauge on the brake booster on the intake manifold to watch the PSIs as you use an air compressor to pres. the manifold to 20 psi. Soap down the BOV for leaks on the valve.
Bubbles, leaking. No bubbles, good.
Be careful of your face/eyes as some hoses could violently pop off at higer pressure.
wgknestrick is offline   Reply With Quote
Old 10-28-2005, 08:57 AM   #12
x99percent
Member#: 27108
2004 STi
2004 A4
My stock STi valve was leaking back into the turbo inlet at ~21-22psi. On the dyno, the charge pipe to the FMIC was *hot*. I switched to a modded valve, and that held the boost (noted by a colder charge pipe and higher whp)... but, on the road, it was usually slow to close after a gearshift.
I am now running a Forge recirculating valve with the next-to-strongest spring and two shims... will be switching to the strongest spring soon (had a couple of "slow to close" incidents).
x99percent is offline   Reply With Quote
At what speed does the STI Spoiler / Roof Vane become usefull. RedefinedTR Interior & Exterior Modification 5 11-24-2007 01:58 AM
WTB stock STI blow off valve jmonty NWIC Private Classifieds 0 09-05-2007 11:56 PM
WTB: Stock STi blow off valve Zero46 Private 'Wanted' Classifieds 0 03-31-2007 10:36 PM
At what PSI does the ECU throw a P0244 Valhakar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2006 10:38 AM
What units does the stock turbo gauge use to measure boost? Sublime5260 Electrical & Lighting 1 02-11-2003 04:34 PM
