Old 08-12-2001, 12:43 AM   #1
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default Autox classification for a j-spec
Any idea what class a j-spec would fall in? The car is originally a '94 Impreza L 5 speed sedan.
Now it's a '95 WRX, ie, turbocharged ('95 WRX's had biggest turbos of all j-specs), intercooled, 17" rims, Eibach prokit (lowering springs), KYB AGX shocks, STi engine/tranny mounts, BOV, turbo timer, ACT clutch, WRX brakes, 3" exhaust.
Does this put me in "Prepared Class C?" http://www.scca.org/amateur/solo2/classes/index.html
Thanks.
annointed is offline   Reply With Quote
Old 08-12-2001, 01:19 AM   #2
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
Unfortunately, I don't think CP is right. I think you end up in E Modified. Since your car isn't listed in the CP list, I don't think its eligible. And the type of modification you've done is (I think) outside the scope of Prepared class rules.
15.10.D.1 - Turbocharging and Supercharging is prohibited except for specific vehicles as listed in Appendix A.
Since your Subaru is listed as a NOC (not otherwise classified) in Appendix A, a turbo is not allowed (if not stock) and your car couldn't run a national event (in E Prepared) even without the turbo (car has to be specifically classed to run nationally in Prepared - NOC doesn't count.) You could run it in A Prepared, but not with the turbo.
However, you are definitely legal in E Modified. We had a ProRally car (Impreza L now running a 2.2L turbo charged engine) run an event in E Modified. Unfortunately, E Mod is a class that is way out of our league. A fully prepped WRC car (tarmac settings) is probably competitive. But why would you bother?
Edit: Oh yeah, almost forgot. It sounds like you have a kick a.... errr.... a great Street Mod car. You'd be much more competitive in Street Mod and the engine rule is just the same manufacturer (Subaru!) and have the car be street legal.
Andrew H.
G Stock #70
adhowe70 is offline   Reply With Quote
Old 08-13-2001, 10:37 AM   #3
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
SM - Street Modified
- Steve
zzyzx is offline   Reply With Quote
Old 08-13-2001, 11:04 AM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Steve is correct, you can run that car in SM. It is materially the same as our domestic Impreza chassis, and next year the "legally registered" part of SM is said to be going away.
ColinL is offline   Reply With Quote
Old 08-13-2001, 11:22 AM   #5
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Talking
This is what drives me nuts about SCCA autocross rules. They are designed for people who read the rulebooks upside down and backwards looking for loopholes, without any consideration for the actual performance of the car in question.
When my Alltrac was undergoing the slow and painful transition from street car to rally car, I autocrossed it a couple of times. Sure enough, I was put in Modified where, after a few classes were consolidated, I found myself running against an F440! A perfect match for my 3200 lb Celica. I think I had enough ground clearance to run over most Modified cars without touching. This was in the days before the new classes, of course.
Heaven forbid you show up with anything innovative or out of the ordinary--you'll be classed with F1 cars and they'll probably protest you, too!
Jon Bogert is offline   Reply With Quote
Old 08-13-2001, 01:17 PM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Yes, the SCCA's Solo2 rules show obvious signs of dating and rules creep over their >25 year history.
They need a major overhaul, maybe that will start in the stock class. Maybe most people are happy even if some are stranded between classes. Your Celica is probably still illegal for SM Jon, assuming it has interior trim pieces removed (like doorskins) or a cage that ties into the front struts through the firewall.
That's technically illegal at least. If you wanted to run it I wouldn't care.
Stupid Autox classification question. paultg Motorsports 8 04-26-2004 09:56 PM
AutoX Classifications? im still confused NRTmotorsports Motorsports 18 03-10-2004 05:22 PM
AutoX classification question Rodan Motorsports 12 11-14-2003 01:52 PM
Question about AutoX classifications NRTmotorsports New England Impreza Club Forum -- NESIC 6 10-22-2003 05:15 PM
Question about AutoX classification VSM EXtasy Mid Atlantic Impreza Club -- MAIC 7 07-14-2003 01:08 AM
