Old 07-26-2005, 06:43 AM   #1
EJ20(GDB)
Member#: 85507
1995 WRX STI
Default having trouble of my headlight
hi guys, i am having trouble of my passenger side headlight...all the steam got into it after my frd helped me clear the corner , so now im having trouble, dunno what should i do..... and my plan is try to put it into the oven, but i dunno how long i should put inside the oven for, and dunno what kinda temperatrue i should go for... any suggestion guys?
thank you
EJ20(GDB) is offline   Reply With Quote
Old 07-26-2005, 07:39 AM   #2
EJ20(GDB)
Member#: 85507
1995 WRX STI
and i really need to fix this problem ASAP.. please anyone >_<
anyone done this before?
Old 07-26-2005, 07:41 AM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
If its a warm/sunny day, I bet popping the hood and pulling out the bulbs would get some air in there to evap the water.
also, I heard if you get water in there after clearing them, you most likely didn't seal them good enough.
iamrazor is offline   Reply With Quote
Old 07-26-2005, 07:46 AM   #4
MitchGT
Member#: 73684
2012 4Runner
Take them Apart again and let them sit for a while. I've heard of people also using those little silica gel packets that some things get shipped with, that should help. When you put the lights back together, put a bead of silicone around the seam. I did that with mine and haven't had any problems at all.
MitchGT is offline   Reply With Quote
Old 07-26-2005, 03:37 PM   #5
EJ20(GDB)
Member#: 85507
1995 WRX STI
but i dont know how to unseal them again..have anyone try to put them into oven before?
Old 07-26-2005, 04:07 PM   #6
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
Yeah, you should just be able to put them back in the oven in the same manner as the first time. This is assuming you didn't use any other sealants when you put them back together the first time.
Perdue is offline   Reply With Quote
Old 07-26-2005, 04:19 PM   #7
eclone
Member#: 31567
Same thing happened to my corners.
Take lights off
Get a screwdriver
Get heavy-duty paper towel and use screwdriver to get most of the water.
Stick in oven at 250 with the socket facing upwards so water can evaporate (but don't let the lense rest on hot metal or it may melt) for 5-10mins
Keep pressing the lense and housing together until it's cooled.
Repeat oven process
eclone is offline   Reply With Quote
Old 07-26-2005, 04:41 PM   #8
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
You may want to consider purchasing some black silicone at your local ace and going over the entire seam with it. I did this and not a drop of moisture has penetrated since.
fibuz
fibuz is offline   Reply With Quote
Old 07-26-2005, 05:31 PM   #9
EJ20(GDB)
Member#: 85507
1995 WRX STI
thx alot for the comments guys
Serious (for OT) question: Having trouble brushing my teeth in the morning... brucelee Off-Topic 54 10-11-2007 01:07 PM
I'll have trouble selling my repaired 05 WRX, right? HAL1 General Community 26 03-28-2007 04:54 PM
I have trouble controlling my urge to run up/down stairs.. Fish Off-Topic 27 03-15-2007 06:05 PM
Having trouble with my motorcycle Philsdabom Mid Atlantic Impreza Club -- MAIC 21 07-27-2005 04:23 PM
Having trouble with my TurboXS BOV... Hakaider Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-12-2004 02:55 PM
