![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 14987
Vehicle:Gods Speed #57 Lemons/Chump #77 |
I will be tracking a WRX with OEM alignment specs. I would like more front neg. camber. I was wondering if I can just mark the camber bolt (to return it to OEM after the track session) and max out front neg camber? What effect will this have on front toe? Thanks.
#2 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
You should just get an alignment with the bolt full negative and 0 toe, then drive it like that all the time. Its toe that kills tires and not camber. -1.5 camber and 0 toe will not wear your tires unevenly on the street.
Maxing out front camber w/o adjusting toe, will lead to quite a bit of front toe out with will a) eat the insides of the tires and b) might cause some mid corner push. -Tom |
#3 | |
Member#: 14987
I am between track/autoX cars so this WRX will only get tracked a single time. I will not have the time to get an alignment before the event so I was just wondering what a quick and dirty DIY alignment would do. It sounds like I would have to balance the advantages of more neg. camber with the disadvantages of some front toe out. I'm tempted to try it since I know it has around -.5 camber in front right now which= terminal push on all parts of corners (entry,mid, exit).
I guess I could just dial in a little front toe in as well but I am not sure I have the time or inclination to do this.Quote:
#4 |
Member#: 7492
South East
I would toe in just a tad after the camber change. Takes 30 secs a side.
-Tom |
| Thread Tools | |
| Display Modes | |
| Computer nerds - quick tracking cookie question | Chainsaw_Willie | Off-Topic | 0 | 11-24-2009 08:20 PM |
| Quick 07 2.5i Alignment Question | Nitrous | Newbies & FAQs | 6 | 03-18-2008 10:23 PM |
| Quick alignment question | leecea | Service & Maintenance | 5 | 09-08-2003 11:33 AM |
| Quick Alignment question! | GregsblueRex | Brakes, Steering & Suspension | 4 | 07-31-2003 01:15 AM |
| quick alignment question | loreley | Newbies & FAQs | 1 | 05-26-2003 10:19 PM |
