Old 07-27-2005, 03:28 AM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default H6 brake upgrade
Yes i tried searching and all the info i could find was about RS's doing this mod. I have a 99Outback wagon and the brakes are due for a replacement, has any legacy guys done this swap? what kinda money did you spend? worth it?
spdracr00 is offline   Reply With Quote
Old 07-27-2005, 03:28 AM   #2
spdracr00
Member#: 65823
1996 Impreza L
Red
jesus, my grammer in that post was really bad, Sorry folks.....
Old 07-27-2005, 07:10 AM   #3
Kraziken
Member#: 38629
1999 Legacy GT (STI)
You have to search just "brake upgrade" as it won't let you do a 2 character search.
Here's the thread.
http://forums.nasioc.com/forums/show...=brake+upgrade
I've done this upgrade, and it is definately worth it.
Here's the step by step info.
http://www.scoobymods.com/forums/showthread.php?t=814
Kraziken is offline   Reply With Quote
Old 07-27-2005, 10:55 AM   #4
spdracr00
Member#: 65823
1996 Impreza L
Red
Cool, thanks.. I found a ton of posts from impreza guys that had done the swap, just not to many Legacy guys... how much did it cost ya to do the swap?
Old 07-27-2005, 11:44 AM   #5
Kraziken
Member#: 38629
It's been awhile, I can't recall exactly, but I don't think it was very expensive ($300 or less?). If I remember correctly, I got the Rear rotors from E-bay, and I might have got the calipers from a local junkyard.
Miscellaneous parts I needed I got from www.subaruparts.com. They offer a decent discount on new subie parts. Having the part number is critical and the scoobymods link has that information.
Old 07-27-2005, 01:20 PM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
spdracer, doing the "H6" swap on 99 and older Legacys requires changing calipers, caliper brackets, rotors, pads, etc. The whole she-bang, unlike on the 98+ Imprezas/WRXs which just require a caliper bracket and rotor swap. This is because the rear caliper design was changed in mid 98 on the Imprezas/Foresters and 2000 on the Legacy/OBs.
Because the entire rear setup needs to the swapped to get to the 290mm rotor, several of us have gone with either the 02+ JDM B4/GT-B or 05 USDM Leg GT rears(basically the same setup) which also uses a vented rear rotor(290x18mm vs 290x10mm.) It is gonna be a little more expensive(unless you buy the parts at the dealer - then its almost the same price,) but something to think about.
And there are a couple more expensive aluminum 2pot options too.
ss
subysouth is offline   Reply With Quote
Old 12-03-2005, 03:21 PM   #7
98_soobie
Member#: 17071
im going to be doing this swap soon... ill have to let you know how it goes
98_soobie is offline   Reply With Quote
Old 12-03-2005, 07:29 PM   #8
flanders
Member#: 76382
2000 BH
BP Wannabe
boxer4racing sells a kit for this.
flanders is offline   Reply With Quote
FS: WRX/H6 brake upgrade BNIB Drakar VIC Private Classifieds 11 09-29-2008 03:20 PM
H6 Brake Upgrade KKoepp31 Private 'Wanted' Classifieds 1 01-19-2008 12:40 PM
Koni, Whiteline, Perrin, H6 Brake Upgrade mweinst Suspension/Brakes/Handling 23 12-10-2006 11:50 AM
FS: aquamist, 3.90 Dif, axles, H6 brake upgrade DarthChicken Private 'For Sale' Classifieds 25 12-08-2004 09:01 PM
H6 brake upgrade for 02 WRX Brad B. Private 'Wanted' Classifieds 4 11-03-2003 08:19 AM
