Old 07-27-2005, 04:43 PM   #1
LESLIEx317537
Member#: 35350
2004 Impreza WRX STi
Java Black Pearl/Gunmetal
Question Green Connector under steering dash in 04 STi.
I was looking under the dash of my car today by the steering wheel, behind the intercooler spray button area and noticed a black plug, and then two green plugs that fit together that aren't connected.
I have fog lights and a fog light switch so I know it's not that.
Does anyone know what that green connector is, it only has 1 wire to it.
Can someone look under the dash and tell me if the green plug is connected or disconnected.
Thanks.
LESLIEx317537 is offline   Reply With Quote
Old 07-27-2005, 05:14 PM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
yea, its for diagnostics. Its not suppose to be connected. If you have a accessport, in order to flash base maps or alter the ecu, you would haveto connect the two green connectors and have a special plug for the black plug. Its normal.
Again, those plugs are used for ecu diagnostics and it perfectly normal so no worries
darksands is offline   Reply With Quote
Old 07-27-2005, 06:05 PM   #3
LESLIEx317537
Member#: 35350
Thank you... Now to work ont he fog light / highbeam issue.
Noticed a green connector under the dash disconnected? ret63 Car Audio, Video & Security 8 05-06-2010 08:12 PM
06 sti steering wheel in 04 sti??? BruinsHockeySTI Interior & Exterior Modification 0 11-26-2009 10:01 PM
Green connectors under driverside dash plus a white one tmarcel Engine Management & Tuning 10 03-03-2006 11:15 AM
The unhooked green connector under the dash? fizzak Newbies & FAQs 6 12-22-2005 10:43 PM
green connectors under steering column??? Jon Cox South East Region Forum 13 08-07-2002 01:32 PM
Message Board Statistics All times are GMT -4. The time now is 11:57 PM.
