Old 07-27-2005, 10:28 PM   #1
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
Subaru Stars Rough Idle
While tuning the E Manage car started to idle rough and misfire at idle. Any changes on the e manage don't seem to help. Car will only stay running with slight throttle. Tried removin the Idle air valve and cleaned it out. narrow band o2 sensor seems to be reading ok. has new plugs and wires 100 miles ago. Any ideas?? EJ20G motor with EJ22T heads, EJ18 ECU.
bugman1964 is offline   Reply With Quote
Old 07-28-2005, 02:28 AM   #2
Aus_RS
Member#: 35441
02 RST
GT2540R
Heated or non-heated narrowband O2? If it's not heated, then you can't really trust what's it's saying. If you're running super rich, the exhaust might not even get the sensor hot enough to be in the operating range. My experience with non-heated narrowband was always that the reading difference between stoch. and rich (at idle) wasn't all that much.
Aus_RS is offline   Reply With Quote
Old 07-29-2005, 02:55 AM   #3
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
it is a heated o2 sensor. but i dont think its the o2.. is there a way to test the iac?
Old 07-29-2005, 03:44 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Plug wires! Stupid idea but often right!
Old 07-29-2005, 11:03 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jacob,
What RPM is the car idling at. I am still thinking along the same lines as Paul, that the throttle cable adjustment may be off.
Old 07-29-2005, 12:11 PM   #6
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Check and make sure all your injectors are plugged in and functioning. I was running on three once upon a time because the injector harnesses weren't spliced correctly....
blaznc is offline   Reply With Quote
Old 07-29-2005, 01:35 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
also - make sure you don't have the anti engine stall map turned on. If unconfigured it will the car to idle poorly and most likely stall everywhere.
Todd
Hitokiri is offline   Reply With Quote
Old 07-29-2005, 08:16 PM   #8
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
humm hitokiri thats an interesting thought i think i have it turned on on my car. cause its not so much a rough idle as much as when i take my foot off the accelorator it stalls. As far as the throttle cable im gonna try to tighten it tonight but it feels tight.
Old 07-29-2005, 10:31 PM   #9
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
well i took off the anti stall that made it a bit better but it still wont idle i even tried cranking up the throttle cable some times it holds it some times it doesnt.
Old 07-30-2005, 11:55 AM   #10
Tats
Member#: 5692
WTF? YES! I am
better than you!
I had a bad vacuum leak that did that to my car.
Tats is offline   Reply With Quote
Old 07-30-2005, 02:21 PM   #11
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
yeah i was just talking to subachad and that was his thinking and mine as well with all my other symptoms.. now i just have to figure out all my vaccum hoses and try to find it.
Old 07-30-2005, 03:51 PM   #12
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
What injectors are you running?
I have the 370's in mine and at idle I'm still too rich. I need to mess with the E-manage a little more to get the idle right. I found this out drag racing. When the car idles too long it fouls out the plugs because its so rich. Once the plugs go, it doesn't idle well.
On the plus side, I'm safely running 11psi.
Chad
subachad is offline   Reply With Quote
Old 07-31-2005, 02:20 PM   #13
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
yeah im runnign the 370's as well maybe ill pull the plugs and check them again but i didnt think it would be that bad this fast since its only been150 miles since i put new plugs in.
Old 07-31-2005, 02:57 PM   #14
Unsung Boxer
Member#: 37196
When did the problem start, when you plugged in emanage?
People will suggest you just start replacing parts, this is the most expensive way to fix this problem. How about some rational thinking and diagnostic steps?
1. Did the car ever run well? if so what changed?
2. If emanage was the last step, check your settings. Having selected the wrong jumper will calibrate emanage for a different type of maf/map sensor and will cause an extreme rough runability/idle.
3. Check spark plugs, are they gassy or white? gassy=too rich, white=too lean.
4. 02 sensor is not used to trim fuel at idle, this is only used for cruising, so a bad o2 sensor is probably not the cause of idle problems.
5. IAC motor can cause rough idle. You should not have to adjust it whatsoever. One way of 'testing it' is tapping it with a hammer/socket extension. If its stuck on a bad winding, this can jolt it. However, this doesnt always work, and if you do it too hard, you could break it.
6. Consider major causes of bad idle:
a. spark wires arcing to ground: let the car idle and spray the wires with a spray water bottle. If you see 'lightning' from the wires, you will know they are bad.
b. bad spark plugs, pull them out, inspect. check for color and gap.
c. bad coil. pull spark plug wires off entirely (w/ car off) turn engine over with key, have someone watch, they should spark to the intake manifold.
d. fuel. are you sure these injectors work? 370cc legacy injectors are very old at this point. you can ohm check them, tehy should all be about the same. you can also disconnect each one individually while the car is running, if one is not firing, you wont notice any difference when you disconnect it.
e. vacuum leak, if you have ANY hoses disconnected, or a leaking ATM BOV, it will cause this. Use propane or (carefully) use carb clean and spray around intake and intake manifold while idling, if idle raises at all, you have a vacuum leak.
-Jake
btw, this crap took a long time to write, i hope you read these because this is actual diagnostic steps, not just random thoughts like many people have given you.
Unsung Boxer is offline   Reply With Quote
Old 08-01-2005, 01:14 PM   #15
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
thanks for your response unsung boxer. the car was idling all be it rough but after one day meesing with the tuning on the emange it just stopped iddling.we reverted all settings to no availe. i have tried most of your above diag tips/tricks,the only thing really left to do is check the plugs again and recheck for a vaccum leak. all thought ive tried using brake clean 3 times ot find a leak to no avail. i am starting to lean towards a bad iac due to when we pulled it out it was all carboned up. we cleaned it but it didnt have any relevance to fixing it.
Old 08-01-2005, 02:26 PM   #16
subachad
Member#: 8488
Teal
Jake, My thoughts weren't random. I'm having similar issues. I still think I have a bad IAC but that's only part of the idle problem. Just after installing the 370cc injectors, the plugs fouled super quick. Realize we are going from 220cc to 370cc injectors which is a huge step.
I notice if I let the car idle for a long time it seems to foul out the plugs. Pulling them reveils some gassy wet plugs. I also think a little more tuning with the emanage will help the rich idle mixture.
Bugman, send me your email address again so I can email my new maps to you. I'm now safely at 11psi though the timing portion of my tune is not quite as tight as I would like. Fueling is pretty good though.
Chad
Old 08-03-2005, 01:08 AM   #17
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
yeah im planning on tryin to pul lthe plugs tomorrow if thats the case i may take your map chad and drop the diel portion to about -40
email sent via pm
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain 11 10-22-2009 11:28 PM
rough idle, misfire, CEL funky high idle carter_wrx Factory 2.0L Turbo Powertrain 1 10-04-2009 02:44 PM
very rough idle lean afr's at idle TDagen Open Source Reflashes 8 07-07-2008 04:28 PM
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain 3 04-09-2007 11:10 PM
Message Board Statistics All times are GMT -4. The time now is 06:54 AM.
