Old 07-28-2005, 08:06 PM   #1
Druche
Member#: 59160
2004 WRX Wagon
Default Some opinions please
Hello all. I have an 04' WRX wagon. The only suspension mods are Whiteline swaybars (22mm) front and rear with solid endlinks and a Whiteline rear strut tower bar. I am going to buy some wheels and tires for the car and I've come down to two choices...Rota Tarmac II or Rota Boost. I want to go with 17" wheels. What size will I need(offset, 17x?)? Will they rub with 225/45/17 Toyo Proxes. Also any feedback about my tire choice will be appreciated. This will be a summer only setup. During the winter I will use the stock wheels and tires. Thanks in advance,Peter.
Druche is offline   Reply With Quote
Old 07-29-2005, 09:35 AM   #2
Druche
Member#: 59160
2004 WRX Wagon
Come on guys!
Old 07-29-2005, 10:17 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
AFAIK the Boost is only available in 17x8 ET48 and the Tarmac in 17 (or 18) x 7.5 ET48
I'm running 225/45R17 Hankooks on 17x7.5 ET48 rims no problem - be aware different manufacturers' nominal 225 section width can vary quite a bit though. Ride height and camber are also factors in whether you rub.
Which Proxes? If you mean the Proxes 4 which are A/S - why? if you have dedicated winter tires/rims then get dedicated summers
UkNuck is offline   Reply With Quote
Old 07-29-2005, 11:53 AM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Even on stock suspension, if you get enough people in the back, you may get some rub in corners with the 225s and +48s. A camber kit may help like UkNuck says.
ss
subysouth is offline   Reply With Quote
some opinions please New to This Newbies & FAQs 8 08-03-2005 03:39 PM
I need some opinions,...please!! nottheliving General Community 2 03-07-2004 10:43 AM
Can I get some opinions please? teamzzyzx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-31-2003 04:49 PM
Heres the plan; Would like some opinions please! joltdudeuc Brakes, Steering & Suspension 12 04-21-2002 05:00 AM
