Old 07-29-2005, 05:28 AM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default S_AFC VS 550 injectors
I know somme of you like, no-coast-punk or 8Complex, did have ride 15 to 22psi (on RS-T) of boost on street setup with S-AFC, ITC and big injectors like 550cc.
What kind of maping do you have? What do it look like? Do you need somethink more to run that??
I need INFO fast becose I have a set of 555cc STI pink on the table and I want to install it today and have a good maping to begin tuning with!
thank in advance for the info
OB2 is offline   Reply With Quote
Old 07-29-2005, 08:47 PM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
-50% all the way across on both high and low maps.
no-coast-punk is offline   Reply With Quote
Old 07-29-2005, 09:05 PM   #3
Absubtle
Member#: 85862
SO basically you are maxing out the Apexi Super AFC and the rest is for the computer. What about the throttle settings HI/LO/ May only need to take out 10 points at idle, but you have to configure your Throttle setup, so it can adjust fuel control at idle at 0% throttle.
Perhaps, we need better feed-back than that.
But, besides-the-point, every car DOES differ. It may come close, but sometimes on forced induction, it's a bit too far.
The S-AFC will be able to control the extra fuel at idle and cruising, just by taking out points and driving the car. While driving, you are basically trying to drive like it did before these changes.
A wideband oxygen sensor setup w/ read-out, knock read-out, etc would be nice when tuning....and that is truly what you are doing.
The S-AFC has a limited threshold of fuel injector compensation. But should make it drivable w/ those injectors. I always play it safe w/ a piggy-back, especially w/ S-AFC's. Baro differances, air temp, boost pressure, you sneezed while under boost, it can change those settings.
Um, rambling on. I could go on. BUt I am not on the clock. But will help if asked.
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 08-02-2005, 05:27 AM   #4
OB2
Member#: 51500
1999 impreza rs-t
sylver
nobody have more info to give me???
Please Help me
Old 08-02-2005, 08:05 AM   #5
no-coast-punk
Member#: 49087
I've written all there is to write about this topic. Do a search.
-50% across the board is all you need to know.
Old 08-03-2005, 04:43 AM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Yes, what no-coast-punk said, but also realize your gas mileage is going to take a huge dive, and cold start up is going to suck, and overall drivability is probably going to suffer as well. S-AFC is teh suck when it comes to tuning out larger injectors. I felt my car ran significantly better with n/a 2.2 injectors and lower boost vs. legacy turbo injectors tuned out with an AFC and more boost. Just my opinion though.
ChicksDigWagons is offline   Reply With Quote
Old 08-03-2005, 08:14 PM   #7
no-coast-punk
Member#: 49087
I got 30mpg cruising on the interstate and 22 around town on the RS with the SAFC and 555's.
Old 08-15-2005, 12:11 AM   #8
OB2
Member#: 51500
1999 impreza rs-t
sylver
I dont understand why I have to put all my S-AFC at -50%??
I now run 420cc WRX injectors and the lower setup I have is -11%.
The 555cc are 33% biger than the 420cc so I only have to subtract 33% 0f 11% setup. So I will run -15% and no more 11%. And I have to do the same thing for all my NE points??!!
Is it logic or I am wromg???
Old 08-15-2005, 08:17 AM   #9
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Here's my old setup running 10 psis:
S-AFC Settings:
SETTINGS:
1) HI:
1000 -2%
3000 -19%
3500 -24%
4000 -26%
4500 -28%
5000 -26%
6000 -22%
6500 -18%
2) LO:
1000 +10%
3000 -12%
3500 -14%
4000 -15%
4500 -16%
5000 -14%
6000 -12%
6500 -10%
3) TH POINT:
a) LO: 20%
b) HI: 55%
4) NE POINTS:
1000
3000
3500
4000
4500
5000
6000
6500
5) DEC. AIR:
a) THR: 2.0%
b) NE1: 7.0%
c) NE2: 2.0%
Each car setup will require a different fuel curve. Just in case here's also my old setup:
-GT-28 Ball Bearing turbo
-Spearco TMIC
-Greddy BOV (Type S)
-WRX injectors (420cc)
-Supra TT fuel pump
-Vortech FPR (10:1)
-Custom turbo manifold/uppipe/downpipe
-Custom 3" piping (catless)
-HKS exhaust/muffler
-Apexi ITC
-Apexi S-AFC
-Apexi AVC-R (w/8-10 psis)
-NGK Iridium spark plugs (BKR7Eix-11)
-Unorthodox Racing underdrive pulley
Hope it helps a bit....
Mariano is offline   Reply With Quote
Old 08-15-2005, 11:12 PM   #10
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
seriously though, calculations on percenting your fuel settings are nice, but there is no answer here unless you give us a wideband o2 to really determine this. It gets worst when you swap blocks, go figure...
STi-Nismo Dood is offline   Reply With Quote
Old 08-16-2005, 01:17 AM   #11
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
stats are nice too... but get an o2 seriously
+75% sized injectors: ~220c.c. to 360c.c. legacy turbo fuel set @ 40psi
TD04-18t 9psi
Walbro 255lph fuel pump
3" MRT Open Exhuast
2.0 turbo block
NGK-BKR7e011
SAFC
thr% 0.5
ne1% 0.8 1500rpm
ne2% 2.5 2500rpm
don't even worry about referencing other people's fuel curves...
Old 08-16-2005, 02:19 AM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
whoops, my post included a monkey and poop. But in good humor.
Old 08-16-2005, 11:32 AM   #13
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
at least it knows how to use the toilet, mine just throws it at me
Old 03-22-2006, 02:32 PM   #14
OB2
Member#: 51500
1999 impreza rs-t
sylver
Thanks Mariano for your first email and the setup you give me there it realy help.
Did you have the 2th email I send you (more question)???
FS: off V7 spec C: VF30, TMIC, uppipe, 550 injectors pegdrgr Private 'For Sale' Classifieds 24 05-20-2004 09:55 PM
vf30 and sti 550 injectors 4 sale WjRgX Private 'For Sale' Classifieds 14 05-09-2004 03:17 PM
02WRX 550 Injectors Scoty Private 'Wanted' Classifieds 0 01-03-2004 04:18 AM
FS: RC 550 Injectors 02+ WRX, like new Eric1855 Private 'For Sale' Classifieds 1 09-11-2003 04:17 AM
VF22 and 550 injectors with Apexi Power FC DuoMaxwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-12-2003 12:35 PM
