Old 07-29-2005, 10:45 AM   #1
STiyiyi
Member#: 88067
Default Replacing Bridgestone RE070's.
Trying to choose between the new Toyo T1R's and Yokohama Neova AD07's on my '05 Sti. I'm also going to change the profile a bit and go with a 235/40/17 instead of the stock 225/45/17's. Any thoughts, suggestions?
STiyiyi is offline   Reply With Quote
Old 07-29-2005, 11:55 AM   #2
gregr01
Member#: 49333
04 STi
java pearl black
235/40's shorter than I'd go with... 235/45 is a better size, or 245/40 for the same diameter with a bit wider footprint.
Be sure to check actual measured diameter and width vs. nominal (TireRack has this info for most of its tires). Actual size varies quite a bit from nominal, and the OEM RE070 is wide for its size.
gregr01 is offline   Reply With Quote
Old 07-29-2005, 12:02 PM   #3
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
I am sorry to not be directly replying to your post, but have you considered the Hanhooks? Those are one of the 'hot' summer tires, and they have performance comparable with the RE070s. That, and they are cheap as all getout and come in a variety of sizes.
As far as your sizing issue, I hope you have an installer that can properly install those tires as well. While it shout *not* be an issue, I know I had trouble locally with 'general' tire installation places as they could not install stiff sidewall RE070s or Azenis ST-215s.
Also, as long as you are not concerned about dinging the rim, ride compliance, trammling, or your speedo being slightly off, the 235s arent a bad choice. Personally, I would run 245s daily, but they are going to be slightly louder.
Once my RE070s are gone, I am going 245/40/17s (speedo be damned!)
-dow
dowroa is offline   Reply With Quote
Old 07-29-2005, 12:14 PM   #4
jlp7t
Member#: 46160
2004 WRX STi
COBB DP,AP Stg. 2,Typhoon
245/40/17 is only 1% off the stock size. 235/40/17 is 2.3% off.
use this to look at the differences in tire sizes and how it will affect your speedo / gearing http://www.miata.net/garage/tirecalc.html
jlp7t is offline   Reply With Quote
Old 07-29-2005, 12:18 PM   #5
WimpWgn
Member#: 66580
Sell Me Your Re070
WimpWgn is offline   Reply With Quote
Old 07-29-2005, 03:43 PM   #6
lordzappo
Member#: 67213
04 WRX STi
Java Black Pearl
I've got the Toyo's in 225/45- seems slightly softer than the RE070 sidewall. Not much. Haven't had a chance to try em in the rain yet, but seen a couple magazine reviews that put them 2nd for wet handling.
They are definitely narrower than the 070's, if you want to retain that stock width look i'd go one side wider like you were planning. If i had it to do over again, i'd buy one size wider.
lordzappo is offline   Reply With Quote
Old 07-29-2005, 04:06 PM   #7
STiyiyi
Member#: 88067
Thanks everyone for your info. I will at least go with a 245/40/17 size. With just about an inch more tread width, will there be any problems keeping the added width within the fenderwells? I have the Cusco Zero 2R's lowered to just above the fenderwell now. It looks like I'll pick up about .2 of an inch more clearance over the stock 225/45/17 OEM tires to allow for the added section width.
Old 07-29-2005, 04:39 PM   #8
scottjua
Member#: 2937
2002 WRX Wagon WRB
2006 STi Aspen White
I just got home from getting my Advan Neova AD07s put on... and I LOVE them. Initial impression is awesome. Turn in is crisp, no slop, and they are sticky sticky sticky even brand spanking new. Granted I'm coming from AVS ES100s rather thatn the STi Re070s and I don't have a track times, etc. to lean on as an evaluative measure, BUT, on the road and for my uses they live up to the test results so far.
I noticed that they don't tramline like the tread pattern on the ES100s did, and they are quieter, although ride feels similar. Looks wise, the shoulders seem a little more rounded and they don't look as tall as the ES100s.
Well take it for what it's worth, but I like 'em. ^_^
scottjua is offline   Reply With Quote
Old 07-29-2005, 10:26 PM   #9
STiyiyi
Member#: 88067
I just placed my order with the local America's Tire Center (after they matched The Tire Rack's quote). I'm getting a set of Yokohama Advan Neova's 245/40/17's. They should be here by Thursday. The reason I'm changing so soon (2000 miles) is because I picked up a screw in the driver side rear and I unknowingly drove on it low so that the inside shoulder was gouged. With slightly over $200.00 to replace it ($300.00 at my benevolent Subaru dealer) I decided to do the change now. Besides, when PDX Tuning gets through with it (GT35R Turbo Kit) I'll need that extra rubber! Thanks to all who helped me spend some more money!
FS : CT: STI Bridgestone RE070's PattyB69 Tri-State Area Private Classifieds 1 06-24-2010 11:21 AM
FS: (4) Bridgestone RE070's - Upstate NY. SeanyC25 Private 'For Sale' Classifieds 6 05-06-2004 01:24 AM
FS: 4 Bridgestone RE070's - Upstate NY SeanyC25 Tri-State Area Forum 3 05-02-2004 12:34 PM
FS: Brand new Bridgestone RE070's (4) avatarr Private 'For Sale' Classifieds 21 03-24-2004 04:53 PM
4 new bridgestone RE070's 225/45/17 vf39hipsi Private 'For Sale' Classifieds 0 03-04-2004 01:35 PM
