Old 07-30-2005, 04:25 PM   #1
moosebs09
Member#: 92466
Default battery disconnected, starting problems
I recently purchased a 96 legacy LSi Sedan but cannot get the thing to start. It has the alarm system installed on it and when I attempt to start the car it will not. The engine just turns over and will not start. Dash lights will flash and the radio flashes as well and the fans will turn on and off while the key is in the run position and trying to turn it over. Seems like it might be a security issue, is there anyway to resolve this I have tried the reset button on the security but that does not work it continues to do this, remote works fine as well, and I am questioning now what is causing the problem. If anyone knows of why this would happen please let me know. Ive had it running once or twice but it always goes back to the same problem. Anyone know where I might be able to get a wiring diagram or schematic of the security box, or if its something else that is causing this problem please help me out. Thanks.
moosebs09 is offline   Reply With Quote
Old 07-30-2005, 04:50 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
It sounds like you have the black or green connectors hooked together. Look under the dash on the drivers side, there is a set of either black or green connectors that are used to test relays and stuff when they are connected.
subiekid is offline   Reply With Quote
Old 07-30-2005, 05:16 PM   #3
moosebs09
Member#: 92466
OK I will try to do that, if I can figure out which connectors you are talking about, is there any mention of these connectors in a service manual or an easy way to determine which ones you are talking about?
Note on alarm after battery disconnect jblaine Car Audio, Video & Security 14 09-30-2013 08:10 PM
Starting problem maybe battery???? 06njsti Electrical & Lighting 4 08-18-2008 04:27 PM
Will Apex'i AVC-R and Power FC lose settings if battery disconnected? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-07-2002 10:42 AM
Capacitor Question - Re: Battery disconnect WRSport Car Audio, Video & Security 6 03-05-2002 12:57 PM
Help! Lights won't stop flashing after battery disconnected. Richard A. General Forum Archive 7 02-19-2001 07:07 AM
