Old 07-30-2005, 06:10 PM   #1
melchoir
Member#: 92472
Default 93 Legacy Touring Wagon Hesitates
I don't quite know if "hesitates" is the proper wording for my particular problem, But here goes.
Every now and then, around 30mph 2-3krpm (not sure which gear, 2/3 I'd guess) I will attempt to accelerate, and the car won't respond, infact, the rpm's will drop some, and I'll have to give it more gas to keep it from losing more power, then abruptly the car will raise rpms very quickly (like it should have in the first place) and go. I do not notice the car downshifting before the rpms go back up. Any ideas?
melchoir is offline   Reply With Quote
Old 08-01-2005, 10:43 PM   #2
midlifecrisis
Member#: 3958
2008 Impreza STi
+ '93 & '98 Impreza L(s)
I've had this happen in another car (non-Subaru) and it turned out to be the Throttle Position Sensor. It seems that it had worn a dead spot where the throttle sat at normal cruise speeds. You can probably test this theory with an ohmeter.
Good luck and let us know what you find.
Paul
midlifecrisis is offline   Reply With Quote
Old 08-01-2005, 10:59 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
And check/replace both your plugs and plug wires.
Old 08-02-2005, 09:34 PM   #4
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Your injectors might be dirty as well. I had similar problems in my RS. Got the fuel system cleaned out and no more hesistation!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-03-2005, 11:52 AM   #5
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I had this problem in my 93 legacy turbo sedan automatic but I never figured it out. Is it intermittent or every time? Mine was intermittent.
Samirr76 is offline   Reply With Quote
Old 08-05-2005, 01:58 PM   #6
melchoir
Member#: 92472
Thanks for the replies, I haven't had a chance to have anyone take any look at it yet. The problem is intermittent. I swear it happens at random, and I cannot reproduce it when I want to. It also makes a sound when this happens now, I'd call it a "knock" since that word has a different meaning to it (I think). But it sounds something like that. The sound happens a few times, then goes away as the rpms jump back up. (usually 2-4 times)
FS: 93 Subaru Legacy Touring Wagon DLC Legacy Forum 1 09-15-2004 08:12 PM
AWD fuse in my Legacy Touring Wagon ort5 Legacy Forum 6 05-18-2001 06:48 PM
Anybody getting >17 mpg. in Legacy Touring Wagon? ort5 Legacy Forum 13 02-17-2001 12:35 AM
Wanted: Any and all info about 94 Legacy Touring Wagon ort5 Legacy Forum 0 01-29-2001 04:06 PM
Legacy Touring Wagon "Turbo" 93 Performance cdanders Legacy Forum 5 09-09-2000 04:09 PM
