Welcome to the North American Subaru Impreza Owners Club Monday September 1, 2014
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 07-30-2005, 07:05 PM   #1
ej20_876
Member#: 39660
2004 AW WRX - Built
2011 Toyota 4Runner White
Default Help!! My car won't go into 2nd
I posted in Tranny forums but not much help. Beginning last night I cannot shift into 2nd gear at all. All other gears shift smooth. I have never had a problem with grinding gears. A couple of months ago my car would not let me shift into 2nd but it quickly fixed itself.....this time it's not. Some have said broken shifter fork and others say synchros. Don't you usually get a warning when synchros go bad i.e. grinding during shifting and such. Mine went out suddenly which makes me think it is something in the linkage which needs some adjustment. I have kartboy bushings which have been in for about 6 months. I could really use some advice because 1st to 3rd is killing me in the city.
Thanks
Tyler
ej20_876 is offline   Reply With Quote
Old 07-30-2005, 07:08 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Take a look at the linkage under the car. If all is well there, then it has to be something internally with the tranny.
wcbjr is offline   Reply With Quote
Old 07-30-2005, 07:19 PM   #3
ej20_876
Member#: 39660
2004 AW WRX - Built
Could improper torque specs on shifter bushings cause this? They were torqued correctly when I installed them but maybe it has changed.....?
Old 07-30-2005, 07:36 PM   #4
HIREN
Member#: 51633
2013 GT-R
That sucks man, aren't you still under warranty?
HIREN is offline   Reply With Quote
Old 07-30-2005, 09:40 PM   #5
ej20_876
Member#: 39660
2004 AW WRX - Built
yeah but i have a feeling the dealership will try to BS about me having a downpipe
Old 07-31-2005, 10:08 AM   #6
ej20_876
Member#: 39660
2004 AW WRX - Built
can someone please explain a broken shifter fork. i have looked at tranny diagrams but still confused
Old 07-31-2005, 10:17 AM   #7
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Have you tried double clutching into 2nd? If the synchro is bad, this will let you into the gear.
1. Let off the throttle, press in the clutch, and shift the "stick" to neutral.
Let out the clutch.
2. Bump the throttle to make the engine "blip". Sometimes in my MG I'll press in the accelerator all the way to the floor for a fraction of a second.
3. Press in the clutch.
4. As the engine speed decreases to match the transmission speed, throw the stick into the next lower gear. Since you actively "matched the revs", it should fall right in!
5. Let out the clutch. The downshift should have been as smooth as butter!
From my old Honda days (it was a real issue in the H22a, or Prelude, transmissions), sometimes the teeth of a gear can "mushroom" out at the dges which will be hardly noticable at all until the gear can no longer engage because the edges are too rolled over.
As for a broken shift fork... I don't know what those symptoms are and I would imagine it would effect more than just second since it is a major component in the tranny.
Texas25RS is offline   Reply With Quote
Old 07-31-2005, 10:45 AM   #8
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
If it's a shift fork, something could have broken and jammed itself between the 1-2 shift fork and the 2nd gear collar, thus not letting you select 2nd. Unless it's a bent shift fork, but that issue is usually with the 3-4 fork. :shrug:
gjhsu is offline   Reply With Quote
Old 07-31-2005, 01:04 PM   #9
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
2007 Muddy FJ Cruiser
PM'd you my digits. Lots of variables and possibilities.
Guru
Hotrodguru is offline   Reply With Quote
Old 07-31-2005, 01:32 PM   #10
ej20_876
Member#: 39660
2004 AW WRX - Built
Ok double clutching is still a no go......so i guess this means my shifter fork needs to be looked at. I guess I can make an appointment with subaru monday.
Old 07-31-2005, 04:49 PM   #11
StealthfishWRX
Member#: 57473
04' REX (RETIRED)
OH NOOOOOOS!!! check your syncros.
StealthfishWRX is offline   Reply With Quote
Old 08-01-2005, 01:06 AM   #12
ej20_876
Member#: 39660
2004 AW WRX - Built
syncros OK.....something else f'ed
Old 08-01-2005, 04:59 AM   #13
BaylorRS
Member#: 48223
2001 2.5 RS
BRP
i had similar problems and all i did was change out the gear oil...but that was the first oil change for that tranny. id say find someone to swap out your downpipe with and get some warranty work done.
good luck.
BaylorRS is offline   Reply With Quote
Old 08-01-2005, 11:22 AM   #14
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
subaru of dallas.
don't go anywhere else.
OneArmedScissor is offline   Reply With Quote
Old 08-01-2005, 11:23 AM   #15
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Originally Posted by Milin
subaru of dallas.
It is a long drive to SoD from Houston...
Old 08-01-2005, 11:51 AM   #16
Tanj!
Member#: 9339
2005 Forester XT
80, 86, 87, and 88 RX-7
But it's all 5th gear.
Tanj! is offline   Reply With Quote
Old 08-01-2005, 12:14 PM   #17
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
True true.... all 5th until you get into the Dallas traffic...
Old 08-01-2005, 12:19 PM   #18
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
Again, I wouldn't trust anyone else other than Kenny in Houston or SoD to TOUCH a transmission. Anyone else seems to be too incompetent to put it all together correctly.
Old 08-01-2005, 12:22 PM   #19
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
so if the the stick won't go into 2nd position, it probably isn't a broken fork, will it go into second with the motor off? if it will, then it probably a syncro issue.
of course, going into reverse at about 100mph will solve all your problems.
Wheeler Bement is offline   Reply With Quote
Old 08-02-2005, 12:30 AM   #20
ej20_876
Member#: 39660
2004 AW WRX - Built
no it will not go into second with the motor off.....as for SoD I can't make that kind of drive. Subaru SW in Houston does good service work....if they don't warranty i am getting FIS gears.
Old 08-02-2005, 12:36 AM   #21
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
I would read this post before thinking about going with FIS, teh suxors.
http://forums.nasioc.com/forums/showthread.php?t=798553
Guru
Blown Reverse and won't go into 2nd? Please Help! bullittman68 Transmission (AT/MT) & Driveline 24 11-28-2008 01:08 PM
Need help!!! Car won't go into test mode wuuusaa Factory 2.5L Turbo Powertrain 5 02-28-2008 04:59 PM
Help (AUTO people like Riftswrx): Car won't shift into 2nd or 4th pleue Transmission (AT/MT) & Driveline 1 04-12-2006 10:28 PM
AP - Car won't go into test mode! Help please. Anihil8r AccessPort 18 03-24-2006 03:39 PM
Help, car won't go into gear with cable clutch! yebokmj Transmission (AT/MT) & Driveline 6 10-04-2004 11:23 AM
