Old 07-30-2005, 10:45 PM   #1
Doyle138
Member#: 91920
2007 WRX Ltd Wagon
Garnet Red Pearl
Question Factory Fog Switch w/after market lights
Here's the background: I ordered the JDM garnishes for my 05 so that I can fit some large round fogs instead of the new mini factory fogs. I'm having my bumper beam cut to fit. As everyone knows, the car is pre-wired for fogs. I figured I could fit some Hella FF200s or PIAA 540s in the opening. I also made the assumption that I could use the factory fog switch in the dash to keep it looking stock on the inside. I called the dealer today to order a fog switch for the dash. He told me he won't sell me one because there is no way the factory pre-wired set-up will work for after-market lights. Can this possibly be true?
I thought I would do my splicing in the bumper and use all the pre-wired gear from there. Also, I know there was a forum a while back about wiring fogs so they aren't only on with the high beams. I can't find it now. Does anybody know where that info is?
Doyle138 is offline   Reply With Quote
Old 07-30-2005, 11:39 PM   #2
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
There should be no reason why non standard fogs can not be wired to factory wiring set up. I just fitted standard fogs to my '04, fogs were used, switch and relay bought from Subaru dealer. Basically plug and play.
Difference with non factory fogs will be mounting point and plug connector.
Also my standard set up allows the fogs to be switched on whenever lights are on, that is side light, headlight and main beam OK.
Micky is offline   Reply With Quote
Old 07-31-2005, 12:02 AM   #3
Thingfish
Member#: 91451
03 WRX
Just watch the wattage of the replacement lamps. Keep them @ 55 watts.
I use Hella 500's in my 03 wrx and I did them with the fatcory plug off the stock lamp. They plugged right in and are perfect.
By default the fogs can come on with low beams, and go off with highs.
Thingfish is offline   Reply With Quote
ABS on/off using factory fog switch Motts Electrical & Lighting 9 04-26-2006 11:55 PM
Wiring in factory fog switch sha_zapple Electrical & Lighting 2 01-11-2006 07:46 PM
after market fog lights ScoobyJoe Interior & Exterior Modification 6 12-11-2004 01:58 AM
After market fog lights brunetmj Electrical & Lighting 3 06-26-2003 12:24 AM
After Market Lights Josico Vancouver Impreza Club Forum -- VIC 19 10-11-2001 09:19 PM
