Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-30-2005, 11:04 PM   #1
tdt3607
Member#: 91156
Default Borla Header + Weapon R= GOOD STUFF
In case there is anybody out there agonizing over the potential of adding A Borla header and Weapon R intake like I was,I can only suggest that you will
Not be disappionted!
I wanted a few simple perf mods,and I think these (somewhat modest) improvements make the simple,modest 2.5 legacy come to life when you ask it to.
And,It doesnt sound Nasty ,or loud,at all,-UNLESS you ask for it-and only then it sounds fantastic (I was afraid or what it might sound like)
Highly Recommended
Sounds great,
Noticable torque improvements across the band
Throttle response improved....................
tdt3607 is offline   Reply With Quote
Old 07-30-2005, 11:21 PM   #2
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
I speak for all Legacy groupies when i say: "bring on the pictures!"
~Mike
pilfflip is offline   Reply With Quote
Old 07-30-2005, 11:22 PM   #3
MitchGT
Member#: 73684
2012 4Runner
Pictures indeed!
MitchGT is offline   Reply With Quote
Old 07-30-2005, 11:27 PM   #4
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
What year/model Subaru Legacy are you running this combination on ?
Borla headers are certainly very nice.
Just add some low-restriction Catalytic Converter(s), and a Complete "Cat-back" performance exhaust system and you should be really happy.
Unfortunately from what I have read on this board is that "Weapon R" intakes sound nice, but add little to no measurable levels of performance. You are probably better off just doing a home-made "snokusectomy" mod to your stock plastic intake sytem, then shelling out bucks for the Weapon-R.
Injen Cold Air Intake systems are suppost to be much better then the Weapon-R, although for now my intake remains "stock" -- so I am only spouting off what others on this board have already posted.
EDIT: Here is a link to the most recent debate on the merits of various intake systems: http://forums.nasioc.com/forums/showthread.php?t=803938 I hope this helps.
Jonathan is offline   Reply With Quote
Old 07-30-2005, 11:30 PM   #5
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
If you really wanted to go the resourceful route you could talk to fibuz and ask him about his "home depot" cold air intake, it didn't look that bad and i think he said he spent less than $60 on it
~Mike
Old 07-30-2005, 11:32 PM   #6
MitchGT
Member#: 73684
2012 4Runner
+1 for the Home Depot Special
Old 07-31-2005, 12:23 AM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
~Mike
**cough**less than 20**cough**
fibuz is offline   Reply With Quote
Old 07-31-2005, 01:06 AM   #8
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
The home depot intake is great on a MAP car, I built a similar setup on my wife's '01 RS, basically a rubber 2" to 3" adaptor stretched over the inlet of the stock airbox, then a 3" 45 degree elbow and a length of 3" ABS pipe to go to the hole in the fender.
I used a 3" rubber coupler on that end of the pipe which will fit perfectly into the hole and makes a decent seal, as well as solidly supporting the whole contraption.
I actually got all the materials for free from a buddy's failed intake idea on his MR2, and as an added bonus he had wrapped the ABS with aluminum backed heat shielding (also from home depot).
Net result (no dyno unfortunately): the torque curve seems broader, the car will pull off from a stop smoothly at lower RPM than it would before, and the top end is much improved. I imagine coupling this mod with a free flowing exhaust there would be even more dramatic gains. The noise is also awesome
On the BD I went with an Injen (the '98 RS model) because the MAF makes a DIY intake a little more challenging (and because it came with the car), and I'm very happy with that.
Dan Cech is offline   Reply With Quote
Old 07-31-2005, 09:49 AM   #9
tdt3607
Member#: 91156
mods were done on an '04 35th anniv edition-non turbo engine type EJ-251
Old 07-31-2005, 01:50 PM   #10
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Okay. This car utilizes a MAP intake instead of a MAF intake so maybe your results were different.
Old 07-31-2005, 03:23 PM   #11
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
originally qouted by fibuz
I stand corrected
~Mike
Old 07-31-2005, 08:22 PM   #12
tdt3607
Member#: 91156
Default Map Or Maf?
Excuse my ignorance,whats the difference?I know my vw was MAF,because the mass air flow sensor was replaced a couple of times in 6 years-But I dont know what they do/how they differ
Thanks
Old 08-01-2005, 12:23 PM   #13
crazex
Member#: 27677
2005 STI
Crystal Gray
I can vouch for the quality of Dan's setup. As the car used to belong to me . The Borla Headers and the Intake definitely bring the EJ25 to life.
-Jon-
crazex is offline   Reply With Quote
borla headers installed in cobb stage 2 wrx wagon. good stuff! garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 08-03-2004 03:23 PM
Borla headers sound mean but not good. problem? Pat L.I. Tri-State Area Forum 13 06-14-2003 06:55 PM
Good source for Borla headers....Low price! Fred Zaplitny Normally Aspirated Powertrain 0 03-14-2003 04:44 PM
Borla Headers good or not? Frakk's2.5 Normally Aspirated Powertrain 6 06-05-2002 01:08 AM
Borla headers / exhaust any good? suberboy Technical Forum Archive 7 06-05-2000 01:53 AM
