Old 07-30-2005, 10:26 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default Q's about outback FRONT sway bar, and WTB
Does anyone know the stock diameter of a BD outback front sway bar? I want more stiffness in the rear which means i want some thing in the neighborhood of 16-20mm for the front and if i can get away with an outback sway bar that would be cool, and does anyone have one that they would like to get rid of
~Mike
pilfflip is offline   Reply With Quote
Old 07-31-2005, 12:17 AM   #2
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I too would like to hear the definitive word on the diameter of the BD/BG outback front sway bar.
I have a 20mm rear bar (Whiteline BSR19X) and would like to upgrade the front a little to match (at present the car is a little tail happy). I've heard that the outback front bar is an 18mm item which would be perfect for me I think (based on the assumption that the stock GT bar I have now is a 16mm).
That said I am running rather high spring rates (559f/448r), with stock(ish) spring rates it seems like you may want the front bar larger than the rear to achieve a neutral balance.
Pat? any input on this?
Dan Cech is offline   Reply With Quote
Old 07-31-2005, 10:33 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My guess is that the Outback front is the same as the GT front. I think the GT front is 18mm, not 16mm, but I could be wrong. I might still have mine in my garage at home (I'm visiting family now) so I can try to remember to check next weekend.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-31-2005, 02:26 PM   #4
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
You would even more so be considered "the man" or at least among people I use the adjective for if you sold your OEM one to me
~Mike
Old 08-05-2005, 12:55 PM   #5
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I finally got around to putting a set of calipers on my front swaybar today...and it measured 20mm.
I'm fairly sure that it is a stock bar, so I'm not sure where I got the idea that it was 16mm.
That said, I guess I need to take the car and push it past the limit to see exactly what the handling is doing. Driving it on the street it seems like the rear bar is a little too stiff for the front but I'm not sure how that could be the case if they are both 20mm (whiteline BSR19X in the rear).
Old 08-05-2005, 02:18 PM   #6
Kraziken
Member#: 38629
1999 Legacy GT (STI)
20mm is the stock size.
I asked Subiegal about this when she was clearing out some whiteline products.
I kind of wondered why Whiteline made a 20mm front bar, but depending on the construction, it might be more stout. I remember replacing my stock front bar on my Honda with a same size bar, but I did feel some handling improvement with the better made bar, even though it was the same size.
I got the 22mm front swaybar now, I think it is a worthy upgrade, more so than a front strut tower bar.
I have the 18-20-22 adjustible in the rear, and but have it set to the 20mm setting currently.
Kraziken is offline   Reply With Quote
Old 08-05-2005, 04:25 PM   #7
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Diameter isn't the only factor... the length of the arms from the bolt holes to the centerline of the main shaft makes a difference as well, as is shown in adjustable bars.
LetItSnow is offline   Reply With Quote
Old 08-05-2005, 07:14 PM   #8
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
?!...wait a minute, if the front sway bar on a GT is 20mm that would mean that the rear is the same size if not bigger right? Or is that why we suffer from understeer?
How about the Outback is that 20mm in the front too? What size is the L series, is that 16mm?
~Mike
Old 08-06-2005, 05:59 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The stock GT rear bar is only 15mm (or maybe 16mm, it's been years since I had a stock rear swaybar). So the front swaybar is definitely bigger than stock.
I could have sworn I had done the 20mm Whiteline bar up front and the stock bushings wouldn't fit, but maybe I have the 22mm. Guess I'll have to measure. I did confirm that my stock front swaybar, which is sitting in my garage still, is 20mm.
Pat
WTB: catless down pipe, cobb front sway bar, and sway bar links Chadsti Private 'Wanted' Classifieds 5 03-04-2010 02:51 PM
WTB: 2000 Legacy Outback front sway bar and links. raamaudio Private 'Wanted' Classifieds 0 01-17-2007 09:18 PM
WTB 20mm GC* front sway bar and endlinks Robmat Private 'Wanted' Classifieds 2 05-02-2005 02:07 PM
WRX OEM front sway bar and OBS OEM rear sway bar Rice & Gravy Private 'For Sale' Classifieds 5 11-15-2004 08:25 AM
Something about the front sway bar dooolu Newbies & FAQs 4 05-02-2003 09:06 AM
