Old 07-31-2005, 01:42 PM   #1
Bud Brown
Member#: 90248
Default if my 97 legacy GT sees boost...
how high can i boost it with what i have, do i have everything or am i mising parts, and if i was to boost more, what would i need to replace with stronger parts? (EJ25)
I currently have...
- T3/T4 Turbo
- 2.5" Up-pipe and Catco Hi-Flow Down-Pipe
- Intake & Charge Pipe
- TMIC Intercooler
- Turbo Mounting Bracket
- Fuel Pressure Regulator
- Oil Pan with pre-tapped oil return
- Oil Lines (braided lines)
- J & S Safegaurd Individual Cylinder Knock Protection
- VC2 Voltage Clamp
- 4 NGK Hi-Performance Iridum Spark Plugs
- Vaccum Lines
thanks in advance!
Bud Brown is offline   Reply With Quote
Old 07-31-2005, 06:50 PM   #2
TrickNipple
moon moon
Member#: 86213
I dont know what kind of compression the EJ25 has but I think that it will be able to handle more bust if you lower the CR with shorter connecting rods. Also go check out the aftermarket forced induction forum. They might be able to help you out too.
TrickNipple is offline   Reply With Quote
Old 07-31-2005, 07:32 PM   #3
LegacyJones
Member#: 48791
02 bugeye
wagon
I think you can run 8- 10 lbs. Not to sure!! Try a safc.
LegacyJones is offline   Reply With Quote
Old 07-31-2005, 07:35 PM   #4
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
go into the aftermarket forced induction section and ask. from my understanding.... 8
Russell Rogers is offline   Reply With Quote
Old 07-31-2005, 07:48 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
You wont last long at 8. If you get an STI ej257 block or an ej22T block, you could go as high as the turbo would spool.
You should look into larger injectors and an ecu to control timing and fuel.
subiekid is offline   Reply With Quote
Old 07-31-2005, 08:18 PM   #6
MitchGT
Member#: 73684
2012 4Runner
From everything that I've read on the forced induction forum you should stay on the low side of 6psi to avoid damage. Bear in mind that this is still enough to give you signifigant HP increase.
MitchGT is offline   Reply With Quote
Old 07-31-2005, 10:09 PM   #7
Bud Brown
Member#: 90248
guestimate?
Old 08-01-2005, 03:26 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I am intercooled, bigger injectors, but no timing control. I get knock at 8 psi plus but I am 9.5-1 compressoin, lower than you (I think).
Old 08-01-2005, 11:30 AM   #9
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
I'd get your VIN# checked by Subaru America before you boost it - I asked about my 98 GT and they told me my compression was 9.7:1
Other discussions about the 97-99 engines said they were all at 9.5:1
In comparison, 99 Impreza RS SOHC ran at 10.2:1
Huffer is offline   Reply With Quote
Old 08-02-2005, 01:42 PM   #10
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Lightbulb
Unless I'm mistaken, the '97 GT had the first-gen 2.5l engine in it. This one runs on premium and makes 155 hp. The '98s+ had a change that let them make 165hp on regular unleaded. So, I think that the limitations may be different on the '97 vs. the later years.
General consensus that I've heard over the years was to run < 7lbs of boost. With that, the numbers are in the 210-220 range.
Bear in mind that none of this is actual experience, just years of fantasizing.
- Eric
Lil' Red '98 2.5 GT Wagon - Pics
Radio Flyer is offline   Reply With Quote
WTB: Whiteline Control Springs for my 97 Legacy GT Sedan BoardRider Private 'Wanted' Classifieds 0 09-28-2005 05:17 PM
STi 6 fitting in MY 97 legacy GT sedan? Teh Legacy Transmission (AT/MT) & Driveline 1 09-27-2002 01:07 AM
Are there really any safe intakes for my 97 Legacy GT? gimpless Normally Aspirated Powertrain 4 01-19-2002 12:56 AM
Are there really any safe intakes for my 97 Legacy GT? gimpless Legacy Forum 4 01-14-2002 02:27 PM
Will a 97-00 Impreza front Strut Tower Bar fit my 98 Legacy GT? jacobhorn Legacy Forum 4 11-14-2001 09:10 AM
