Old 07-31-2005, 02:22 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default HELP!. swap done, and fuel pump wont fire
word. wrapped up my RHD swap. spliced in wire for fuel pump and pump wont fire. relay is plugged in, any ideas?
JDM sti v2 RA into 1993 L manual.
gearbox neutral and rev. plugged in, DCCD lights up, everything else is go
supermoose is offline   Reply With Quote
Old 07-31-2005, 03:04 PM   #2
bbbwrx
Member#: 32734
Just because the relay is plugged in doesn't mean it is working.
There should be a couple other relays that are the same size. Make sure the part they are controling works(ex.if it is the horn relay honk the horn to make sure that relay is good.) Then switch them.
Just a though. It should be either that the wiring or the pump itself
Ben
bbbwrx is offline   Reply With Quote
Old 07-31-2005, 03:22 PM   #3
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
I forget the pin but you should be able to ground the "fuel pump relay wire" at the ecu. When you ground that wire it will click over the pump Realy. If you do not hear the realy click over, something else is wrong. either Relay is broken or something is not hooked up right.
Let me know if you want me to explain it more.
Thanks
Rick
ps. hi ben
scoobydorift is offline   Reply With Quote
Old 07-31-2005, 10:15 PM   #4
supermoose
Member#: 9093
swap starr
fuel pump relay wire... hmm.
the pump is a working unit, was working the day that i pulled the motor (2 weeks ago). how do i ground out the fuel pump relay wire at the ECu?
Old 07-31-2005, 10:17 PM   #5
supermoose
Member#: 9093
swap starr
how do i test relays? all hte fuese are good.
neerrr.. sux. hahah
Old 08-01-2005, 06:39 AM   #6
supermoose
Member#: 9093
swap starr
roar. it runs, just had to wiggle SMJ R1 a bit. its frekin flipping stupendously fast.
trying to swap my stock cluster back in but fuel pump wont stop priming fourage20 Interior & Exterior Modification 1 03-26-2009 11:33 AM
Fuel Pump wont prime!! 02ej257 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2006 03:45 PM
Hydra- Fuel pump wont turn off when hydra is powered up...whats the cause? White 2.5rs Other Engine Management 9 10-17-2006 09:06 PM
Shortblock swapped, injectors 2 & 4 wont fire. dmross Subaru Conversions 6 09-06-2006 09:15 PM
fuel pump wont turn on after motor install. oldbluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-15-2005 11:01 AM
