Old 07-31-2005, 09:11 PM   #1
Bud Brown
Member#: 90248
Default i am about to boost my '97 legacy GT...
hey guys, i am about to boost the legacy so i was wondering....
do i have everything or am i missing parts, and if i was to boost more, what would i need to replace with stronger parts? (EJ25)
I currently have...
- T3/T4 Turbo
- 2.5" Up-pipe and Catco Hi-Flow Down-Pipe
- Intake & Charge Pipe
- TMIC Intercooler
- Turbo Mounting Bracket
- Fuel Pressure Regulator
- Oil Pan with pre-tapped oil return
- Oil Lines (braided lines)
- J & S Safegaurd Individual Cylinder Knock Protection
- VC2 Voltage Clamp
- 4 NGK Hi-Performance Iridum Spark Plugs
- Vaccum Lines
thanks in advance!
Bud Brown is offline   Reply With Quote
Old 07-31-2005, 09:57 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Changing the fuel pump?
Wedge is offline   Reply With Quote
Old 07-31-2005, 10:10 PM   #3
Bud Brown
Member#: 90248
should i? i mean would it be a needed part, or just if i just wanted to push higher psi than maybe 5-8?
Old 08-01-2005, 02:19 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
An upgraded fuel pump is $100 ish. All I know is the old stock ones suck on corners, which means you might go a tad lean around a corner, bad news for a savings of $100.
Old 08-01-2005, 10:56 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
reddevil,
Actually, that is not so much a function of the pump, but of the single pick up and a saddle bag bladder.
Regardless, a new Walbro runs like $85, and used ones can be found in the classifieds for $50 or less. I would do it if it were my car...
Old 08-01-2005, 12:08 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Matt,
All I know is my old one was bad even with 1/2 a tank. When I upgraded to the Walbro, I used the parts off the old one and havent had a problems since.
Old 08-01-2005, 02:40 PM   #7
Bud Brown
Member#: 90248
ill go for a new one, i thought they were alot more than that, would i need anything else? i guess i'd need a fuel controller of some sort, like a s-afc, correct?
Old 08-01-2005, 03:56 PM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
If your car is MAF based, you shouldn't need to worry about that VC2 clamp. Like you said, just run an SAFC. Also, get the fuel pump, if you can't find a Walbro, then for the amount of boost you are planning on running, get at least a WRX one. Finally, don't worry about 'iridium' plugs, standard NGK copper plugs work excellent, maybe even better than iridium/platinum plugs.
Old 08-01-2005, 04:28 PM   #9
Bud Brown
Member#: 90248
so in the end, how much boost can i safely run on stock internals, with the parts shown above, a stronger fuel pump, and a s-afc? if i was to boost a little higher than what the motor can handle with stock internals, what would i need to replace to do it safely?
Old 08-01-2005, 07:15 PM   #10
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Upgrade the pistons, to something that will net a lower compression.
Old 08-01-2005, 07:45 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Unless you get some sort of EM to pull timing, 4-5 psi is the max you can safely boost with your compression. If you can pull timing and always run 92-93 octane fuel, then add a few boost points. But after that I predict broken ringlands. I have broken my share on a 2.2 motor at 7psi and 9.5-1 compression because I had no EM and ran stock NA timing advance.
Old 08-01-2005, 11:12 PM   #12
Bud Brown
Member#: 90248
whats "EM" stand for?
Old 08-02-2005, 11:25 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
engine managment
+1 for not needing the voltage clamp
+1 for the walbro
+1 for some sort of timing device (ITC)
and i hope you meant rising rate FPR -the 4 to 1 iirc
good choice on the j&s
also consider a boost and fuel pressure gage
Old 08-02-2005, 12:10 PM   #14
Bud Brown
Member#: 90248
So my final laundry list would beeee.........
- T3/T4 Turbo
- TMIC Intercooler
- VC2 Voltage Clamp
- Vaccum Lines
**PLUS**
- Walbro Fuel Pump
- Greddy E-Manage (Corrects Fuel & Timing)
- Boost Gauge
- Fuel Pressure Gauge
- Air/Fuel Ratio Gauge
and then what is the best way to lower compression? pistons? and what injectors should i run?
Old 08-02-2005, 09:10 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
to save you some $$ do not get the voltage clamp plus there is one built in to the emanage
and the air fuel gage (from a narow band sensor) is totaly useless they won't read below 13.2 which is way above what you are going to want to run ...
an innovative lm-1 on he other hand is a great choice but you won't need it after yo get her tuned
Old 08-03-2005, 02:42 PM   #16
Bud Brown
Member#: 90248
so with all these extras i am looking to spend maybe two grand?
Old 08-04-2005, 09:54 PM   #17
Bud Brown
Member#: 90248
bump bump
About to purchase a 2000 Legacy GT... MandTPhotography Newbies & FAQs 3 11-13-2007 12:02 AM
Tempted to trade my '05 Legacy GT Limited for... GodWhomIsMike Off-Topic 37 12-15-2006 02:03 PM
looking to take my 1997 legacy gt to the next level gtlegg Subaru Conversions 2 08-10-2006 11:21 PM
(soCal) Want to trade my 16" Legacy GT whls for your 16" Subaru steelies? FujiHeavyFreak Private 'Wanted' Classifieds 1 12-02-2004 10:45 PM
Need to sell my MY00 Legacy GT LTD Jason Bay Area Impreza Club Forum -- BAIC 2 09-09-2003 01:17 PM
