Old 08-01-2005, 12:36 AM   #1
Mactizen
Member#: 80779
2004 STi WRB/gold
[email protected] stock vf39
Default Anyone run slicks??
I want to run a little taller tire at the track and i was wondering if anyone used slicks. M/T or whatever, not a brand issue here just interested if u think its remotely necessary. Or would a taller set of some DOT R compounds be just as benificial?
PS - the taller thing is that i am hoping to avoid shifting into 5th at the end of the track (1/4M), i figure it works for the Hondas maybe it'll work here.
Mac
Mactizen is offline   Reply With Quote
Old 08-01-2005, 12:52 AM   #2
MinesFaster
Member#: 44503
2006 Evo 840whp/E85
66 Chevelle, 468bbc/600hp
Unfortunately as far as slicks go you are cursed by your brakes. In order to find a drag slick that would work you have to toss the Brembos and go to smaller brakes. M&H makes tires desgined for import applications, though there are also taller M&H slicks available (in the 26" range). Mickey Thompson also makes 26" tall slicks in a 16" wheel.
The real questions is do you actually make enough power to need slicks? There are plenty of AWD cars running R compound tires and running ALOT faster than you are likely to ever go. John Shepherd until very recently had been running 225-50-16 Toyo RA1's and been in the low 9's.
If you want a taller tire to avoid the last shift down the quarter look for some 245-45-17 or similar. BFG also offers a 245-40-18 drag radial which stands 25.6" tall. If you are mostly stock (or minor bolt ons) you probably wont have to shift to 5th anyway.
MinesFaster is offline   Reply With Quote
Old 08-01-2005, 01:29 AM   #3
spooln04
Member#: 85421
92 EG all mota
al evos was running nitto 555r when i saw him at e-town a few weeks ago. he was running 10's....
spooln04 is offline   Reply With Quote
Old 08-01-2005, 08:15 PM   #4
Mactizen
Member#: 80779
2004 STi WRB/gold
i am currently only running a cat back and UTEC. Dp, fuel pump, and injectors all should be in this week. I know thats not even close to heavily modded! But yes i am shifting into 5th i can't avoid it, no matter when i shift on the track or how long i hold 4th i hit the limiter. Maybe i'll try nitto 555r's i can get a deal on those. The only reason i said slicks is B/C a friend of mine just started working at a new shop here and they are getting amazing prices on some really good tires. 555r's included
well good is a relative term for "as compared tothe US."
anyone running slicks/or drag radials on the 04 wrx wheels ? EJ20IMPREZAREX Newbies & FAQs 20 07-20-2013 04:10 PM
Anyone use Slick 50 stu1811 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-02-2008 12:18 PM
I'm Running slicks on my WRX!!! AmirWRX Bay Area Impreza Club Forum -- BAIC 4 10-19-2003 02:24 AM
Anyone running or planning to run water injection? bigbuyer2477 Water/Methanol Injection, Nitrous & Intercooler Cooling 28 06-04-2001 08:46 PM
Anyone Use Slick 50? BrysImpreza Normally Aspirated Powertrain 10 03-28-2001 02:11 PM
