Old 08-01-2005, 12:53 AM   #1
mcu81
Member#: 5796
2007 11 F150, 2004
WRX-dont get married!
Default Currently swapping 04 sti 6spd into 02 wrx, some short notes on the swap
This is a USDM sti 6spd going into my 2002 wrx.
Somewhere i read, or there was an arguement on different mounts for the transmission would be needed. the rear sti tranny mount went right into the crossmember from the wrx fine. Both the front and rear cross members are wrx original and fit the sti box fine
My forgetfulness neglected the starter. Im using the sti clutch and flyhweel that came w/the 6spd and the wrx starter wont even go into the bellhousing, im assuming the sti flyhwheel was bigger than the wrx flywheel.
other than that, all went well. I dont have the dccd computer either, im assuming its going to be 35/65 all the time? can u dyno like that?
-mikey
p.s. holy crap the stock 5spd is light, and like half as wide as the 6spd!
mcu81 is offline   Reply With Quote
Old 08-01-2005, 12:57 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...tried putting the exhaust on yet???
Old 08-01-2005, 12:57 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Old 08-01-2005, 11:41 AM   #4
mcu81
Member#: 5796
2007 11 F150, 2004
no why.........oh and i have a bpm turboback........ but its not fo sale
-mikey
Old 08-02-2005, 03:39 PM   #5
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Me too...the TD38 with the GT muffler
Out of curiosity, where did you get all your components for the swap? I'm looking for a good vendor to get a complete swap set from.
Conduit is offline   Reply With Quote
Old 08-02-2005, 03:42 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
-mikey
The crossmembers and the mounts on the Impreza are pretty much interchangeable since 1993.
The 5spd is around 130 lbs, the 6MT is around 205 or so.
The starter for the STI is identical to the WRX one, the flywheels are identical in width and tooth count. Sooo... there is something else happening there.
Old 08-03-2005, 03:33 AM   #7
bugeyes
Member#: 64494
2001 V7 sti
I'm going to be attempting the same swap this weekend. Do you mind telling me-
What did you do to get over the tailshaft length difference?
Did the sti front axles slip straight into the wrx hubs ok?
Thanks,
bugeyes is offline   Reply With Quote
Old 02-02-2006, 03:02 PM   #8
phatfil
Member#: 15956
2013 XV Crosstrek
Ice Silver
Default My swap in progress
I am swaping a 04 6MT with female axles and the fronts slide right into my 02 WRX hubs, actually easier than the WRX axles did.
And BTW, the 5MT downpipe will not fit the 6MT unless you modify it.....hello dremel....goodbye brackets.
phatfil is offline   Reply With Quote
04 sti motor into 02 wrx swap... help el tekk-O Subaru Conversions 6 01-20-2008 02:55 PM
how to swap 04 STi motor into 05 WRX? whateverwrx Newbies & FAQs 4 05-22-2006 12:48 AM
Swapping 04 sti engine into 03 wrx? Spooled Subaru Conversions 2 09-04-2005 05:58 AM
04 USDM 6spd into 02 wrx, do i need any new crossmembers/tranny mounts? mcu81 Transmission (AT/MT) & Driveline 1 07-18-2005 12:23 PM
what are the exact parts needed to swap 04 STi trans into 03 WRX? M32WRXin3seconds Transmission (AT/MT) & Driveline 7 01-29-2004 01:25 PM
Message Board Statistics All times are GMT -4. The time now is 02:25 PM.
