Old 08-01-2005, 10:49 PM   #1
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Default Next mod
Alrite im just wondering what my next mod should be .
I got.....
Injen CAI
GFB underdriven pulleys
ebc rotors / carbotec pads
iPd rear swaybar and end links
kartboy short shifter and bushings
steering rack bushings
kyb GR2 struts
front strut tower bar
Im also ordering STI motor and transmission mounts and whiteline anti lift kit.... and after these 2 mods im really not sure what to do next .
Also question about rims would Rota Subzero’s… 17” x 7.5” and the tires are Falken Azenis… 225/45/17 fit on my 98 BDno problem ...
Thanx main
EastsideLegacy is offline   Reply With Quote
Old 08-01-2005, 11:32 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
some kind of exhaust or struts/springs.
fibuz is offline   Reply With Quote
Old 08-01-2005, 11:38 PM   #3
Bud Brown
Member#: 90248
header and exhaust if you have extra $
Bud Brown is offline   Reply With Quote
Old 08-01-2005, 11:40 PM   #4
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Definitely exhaust to let the motor breath a little.
Dan Cech is offline   Reply With Quote
Old 08-01-2005, 11:50 PM   #5
EastsideLegacy
Member#: 58806
2.2L legacy wagon
Good idea ... if i got a custom catback made at a exhaust shop what muffler would be good to throw on there ?
Also who has had this done ? how much did it run you about ?
thanx for the replies main
Old 08-01-2005, 11:51 PM   #6
EastsideLegacy
Member#: 58806
2.2L legacy wagon
sry for the double post but also I dont wanna go with stromung because too expensive, thats why i brought up the custom made route..
and anyone about the rims and if thell fit without rubbing....??????
thanx again MAiN
Old 09-11-2005, 11:03 PM   #7
toxicavenger70
Member#: 95767
1997 Gt WGN
white
Default here is my exhaust
hey bro i got a 2.5 catback with a flowmaster lifetime warranty exhaust for 250
toxicavenger70 is offline   Reply With Quote
Old 09-12-2005, 12:19 AM   #8
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
You're going to rub with those 225's on stock fenders, you'll probably need to pull the trim strip or roll them slightly.
sybir is offline   Reply With Quote
Old 09-12-2005, 01:59 AM   #9
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I was just thinking the same thing with the 225's, you're running almost 9" (8.8") of section width goodness. You might be able to squeek by if you went with the ET 45 instead of the ET 48 SubZero, not much I know, but you'll still have to pull the fender trim strip to make it work and possibly roll the fenders.
Dale
Subietonic is offline   Reply With Quote
Old 09-12-2005, 07:27 PM   #10
LegacyJones
Member#: 48791
02 bugeye
wagon
rip the motor out and put in something with balz.LOL
LegacyJones is offline   Reply With Quote
Old 09-12-2005, 08:33 PM   #11
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Dale
There's not a strut clearance problem with that setup as much as a fender problem, a 45 ET would make it worse, pushing the whole assembly 3mm farther out.....
Old 09-12-2005, 09:23 PM   #12
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Positive ET pushes the rim toward the fender. Given that the SubZero's are available in 17x7.5 ET 45 and ET 48, I suggested the 45 instead of the 48 so it wouldn't impinge the fender as much. 3mm reduction AWAY from the fender TOWARD the suspension may or may not impinge the suspension. Likely not.
I've run +38 on my BD with 215-45x17 (OEM RE92a) with no inner suspension nor fender issues but, with Dayton Daytonas in that size on the +38 rims, the tires wanted to rub the fenders occasionally. With the section width and tread width of the 225-45 Azenis on 7.5" rims, I'd recommend a test fit/drive first. YMMV
Dale
Old 09-13-2005, 07:42 PM   #13
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Definitely back you up on the test-fit if they'll do it.
Dale, a 45 ET is closer to the fender than a 48 ET. The higher the offset (ET) the more the rim is pulled in over the center point (towards the suspension).
In your example, your 38 ET is 10mm closer to the fender than an ET48 rim, given the same wheel width.
Sorry, I work at a Suby performance shop and deal with this stuff all day, so I'm a bit pedantic
Old 09-14-2005, 01:04 AM   #14
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Thanks Sybir - I was asking several people, whom I know and trust (really look at them as wheel gurus) and I must have misunderstood. I've always understood that the greater the positive offset, the further the rim/tire was pushed towards the fender. I see now that it's just the opposite... but I had to draw a diagram so I could visually see it. See attached.
In reality what's happening is that the wheel hub is moving internal to the rim itself. As the offset decreases, the hub moves closer to the center line of the rim and that forces the outside rim toward the fender and away from the suspension. The disconnect for me was that I could not see the hub/face moving inside the rim as offset increased or decreased. Once I thought of the hub/face sliding inside the rim, it all made sense.
My apologies if I confused anyone.
Dale
Old 09-14-2005, 10:54 AM   #15
EastsideLegacy
Member#: 58806
2.2L legacy wagon
i got the rims and tires on my car right now no rubbing problems at all ima be lowerin it in the nexe month or ao and ill tell you how it goes
thanx main
Old 09-14-2005, 06:36 PM   #16
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Exactly, Dale, sorry I didn't explain it more clearly. That graphic is one I'll grab for future use
Eastside, let us know how it goes
Were you I, what would be next mod? I have.... gtguy General Forum Archive 8 01-22-2001 09:01 AM
Yes my next mod is complete !!!!!! scoobyruman New England Impreza Club Forum -- NESIC 7 08-18-2000 11:49 AM
next mod..big brakes slide Legacy Forum 11 07-08-2000 06:32 PM
My Next Mod SilverSuby Technical Forum Archive 22 06-27-2000 07:36 PM
Next mod? JC Legacy Forum 7 01-03-2000 10:34 PM
