Old 08-01-2005, 11:59 PM   #1
downeyer
Member#: 10784
Platinum Silver Metallic
Question Hub Ring Fit = Vibration?
Hi all, need some advice from people who know more than I do. I have a set of Enkei RPF-1 rims that came with a non-metal hub ring. It seems like everytime I dismount the tires, my vibration either gets better or worse. I do not rotate the tires, just loosen them and retorque. When torqued with the tires on the ground, the vibration is worse than with the wheels are torqued in the air. My best guess is that this is due to the wheel moving further off-center from the hub center due to the weight of the vehicle. None-the-less, I have vibration in the 70+ mph range with the wheels torqued in the air. At 80mph+, the vibration is ridiculous. I've had the wheel / tire assembly balanced 3 times at 2 different shops. I think the hub ring has too much play and is allowing the wheel to mount off center relative to the hub center. Here is a video showing the hub ring play -> video
Is this amount of play standard or should the hub ring fit tighter? Could this amount of play result in the vibration I am experiencing?
Regards,
Eric
downeyer is offline   Reply With Quote
Old 08-02-2005, 01:04 AM   #2
esteve
Member#: 28716
2006 STI
I can't see the video, but I have a few ideas. First off, did you get part #HR735615? I think the plastic hub rings are designed to be placed in the wheels first. Since you have to tap the rings into the wheels with your palm (snug fit), being in the wheels first might also compress the rings tighter on the hub.
I would also try a 2-step tightening procedure. Just snug the lugs hand tight first, then torque to spec...probably best to do it in the air or lightly touching the ground.
esteve is offline   Reply With Quote
Old 08-02-2005, 01:31 AM   #3
downeyer
Member#: 10784
esteve,
thanks for the response. You'll need Apple Quicktime to see the video. I'm not sure which part number hub ring I have...not sure if there is even a part number on the hub ring to be honest. The hub ring easily falls off of the hub, yet fit snugly into the wheel, but not to the point where it would alter the inner diameter. I'll put it this way...when I pull the wheel off of my car, the hub ring usually falls off and onto the ground. There is no compression fit on either side.
I actually do a 3-step tightening procedure (finger tight using loose socket, snug with torque wrench, then tightened to torque), which is probably over kill, but it's what I've always done.
-Eric
Old 08-02-2005, 01:56 AM   #4
esteve
Member#: 28716
2006 STI
I saw the video now, the hub ring does seem to fit pretty loose. I believe Enkei sourced hub rings don't have the dimensions on the rings, just the packaging. The hub rings I have stay put inside the wheels when I pull them off the car. I think maybe they sent you the wrong ones...I see here that there's a 73 mm wheel/57.10 mm hub size available which is what you might have. It looks like about 1 mm of play in the video.
Old 08-02-2005, 02:08 AM   #5
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
see my rant in this thread
http://forums.nasioc.com/forums/showthread.php?t=812357
....hub-centric is the only way to fly.
scoobtothenoog is offline   Reply With Quote
Old 08-02-2005, 10:30 AM   #6
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
that's my thread above
I'm using metal rings with no issues at all... went 96 mph with no issue...
get different rings
Bundyboyz is offline   Reply With Quote
Old 08-02-2005, 11:21 AM   #7
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
Hey Bundy, where them pix man? lol
Old 08-02-2005, 12:24 PM   #8
downeyer
Member#: 10784
Interesting experience...hopefully I'm not going down the same route. You still have the MSP? I wish I would have bought one when they were heavily discounted due to the arrival of the Mazda3. Of course, I would not have traded the WRX.
Old 08-02-2005, 12:26 PM   #9
downeyer
Member#: 10784
get different rings
Yeah...where's the pics
Where did you get your metal rings from? I'm assuming they came with your new wheels from Discount Tire. Do they fit tighter than what is shown in the movie?
Old 08-02-2005, 12:40 PM   #10
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
downeyer, have we talked on msprotege.com? Nah no more msp, traded it in on a msm this spring, then came to the conclusion I needed more room. And I was tired of drving a car with under 200 ponys, and the rex has som much potential =)
Old 08-02-2005, 02:01 PM   #11
downeyer
Member#: 10784
I've never posted on msprotege.com, but have read several threads there out of interest. I bet the MSM was a sweet car, but I can understand the room issue. I bet you miss the handling and steering response of the Mazdas though. Although, nothing a few aftermarket parts can't cure on the WRX
Old 08-02-2005, 02:21 PM   #12
Tire Rack Moderator
Member#: 1215
ext. 4362
those rings certainly do not fit very well ..... and also to avoid other issues have your wheel and tire load force tested on a GSP9700 .... but, I think it's a ring issue
Old 08-02-2005, 03:28 PM   #13
Bundyboyz
Member#: 32764
2003 WRX with 91K
came with my purchase... I can't compare the fit, as I held on the wheel when mounting. I tighten wheels in the air. Then on the ground I got another half turn on them.
Old 08-02-2005, 09:05 PM   #14
Z1 Performance
Member#: 9327
sounds like you got the wrong rings...any tire place should have the right ones
plastic, metal - makes absolutely zero difference....but you need the right size
Z1 Performance is offline   Reply With Quote
Old 08-03-2005, 09:53 AM   #15
Bundyboyz
Member#: 32764
2003 WRX with 91K
I would run metal... there is a difference why else would they make both? Issues may be minor and rare but it would suck if it happened to you... go metal.
Old 08-03-2005, 10:19 AM   #16
Z1 Performance
Member#: 9327
There is an old addage -just because someone makes something does not mean it is worth having.....
I've been doing this long enough to know it makes no difference. The "metal" rings are nothing more than the cheapest form of aluminum you can get - drop them on the floor, and they will literally nick and chip - so how exactly is that going to be more "sturdy" than plastic? There is no real force exerted on these rings - they are purely designed to sqauare the wheel onto the hub of the car so that the lugs can be torqued evenly without "tweaking" the wheel side to side. 95% of the manufacturers out there provide and/or supply plastic rings - they have been used for years without incident. Even the highest end, non hubcentric wheels use plastic rings in the overwhelming majority of the instances. Regardless of what material you get (it really is splitting hairs), the material, be it aluminum, plastic, titanium or steel, won't compensate for the wrong size, which in this case, sounds like the real culprit.
Have you measured the ID and OD of these rings?
The next thing I would also check into is getting the tire and wheel on a road force machine as Luke suggested. I know its a royal PIA to keep bringing it places, but I have had more than one instance of multiple tire places simply being too lazy to balance the wheel properly, or, in more than one instance, their machine was out of calibration, causing inaccurate weight determinations. If you goto Tire Rack's website, they have a listing of dealers by zip code, with their equipment and the number of years they have been an installer. From there, you can find a place with a road force machine and see if there might be an issue with the rim and/or tire
Old 08-03-2005, 01:17 PM   #17
downeyer
Member#: 10784
I just measured the rings last night. I will post the dimensions tonight.
I'll take your advice and take my car to a TireRack recommended shop and get the road force balance. I've been less than pleased with the Discount Tire shops several times (wheel locks put on finger tight, hub caps not reinstalled properly after tire mounting, etc.). Although, they state that they use the road force balance equipment.
-Eric
Old 08-03-2005, 01:28 PM   #18
Z1 Performance
Member#: 9327
72.62mm-56.1mm is the proper size for that wheel on a Subaru FYI - we have literally sold hundreds of the wheels with the above size spacers (plastic), without incident
Old 08-03-2005, 09:14 PM   #19
esteve
Member#: 28716
2006 STI
73 mm would be a better fit would it not?
Old 08-03-2005, 09:34 PM   #20
downeyer
Member#: 10784
My measurements of one hub ring are shown below. I measured them using a crude set of calipers and rounding to the nearest 0.5mm. It looks like the OD is off by ~0.5mm based on my measurements. Not what I expected because the hub rings seem to fit nicely into the wheel.
Is it common for the hub rings to be so loose that they fall out of the wheel and off of the hub?
Here are a couple videos showing how loose the hub rings fit to the wheel and hub:
--> Wheel / Hub Ring Video
--> Hub / Hub Ring Video
Old 08-03-2005, 09:49 PM   #21
Z1 Performance
Member#: 9327
they should slide on and off the hub with minimal effort, but snap into the wheel
if you need/want to try another set, let me know
Old 08-03-2005, 10:21 PM   #22
downeyer
Member#: 10784
Sent PM...
Old 08-03-2005, 10:47 PM   #23
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
My plastic rings weren't very round after a few track sessions. My aluminum ones still are.
ChrisDP is offline   Reply With Quote
FS IL: Evo X MR BBS Rims, lugs, and hub rings to fit 05+ STI JM530 Wheels/Tires 10 05-14-2010 12:49 PM
66.1mm hub ring on a 66.06mm hub Nowski Tire & Wheel 5 05-10-2009 02:00 AM
Warped front hub/rotor driveline vibration Aprilia Jon Brakes, Steering & Suspension 4 09-27-2002 01:12 PM
not hubcentric rims, w/o hub rings=danger? Endlesshine Brakes, Steering & Suspension 1 09-24-2002 02:25 PM
Hubcentric vs. hub rings AWDconvert Brakes, Steering & Suspension 10 04-03-2002 11:29 AM
