Old 08-02-2005, 12:43 AM   #1
three2seven
Member#: 31757
Default Prodrive p1
I will be going with prodrive p1 17*7 10 spokes and 205/50/17 Mich Pilot Sport A/S for an 05 WRX. Anyone using a similar set up. Any good, any bad comments.
three2seven is offline   Reply With Quote
Old 08-02-2005, 11:41 AM   #2
BlkWRXWag
Member#: 31821
2015 DS WRX
Go with 225/45/17 tires instead.
BlkWRXWag is offline   Reply With Quote
Old 08-02-2005, 12:12 PM   #3
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
...agreed. The 225/45/17 is nearly the same diameter as stock.
Kean is offline   Reply With Quote
Old 08-02-2005, 08:24 PM   #4
three2seven
Member#: 31757
Tha's what I thought however the Discount tire manager found reported for the P1's the 205 would fit more centered on the wheel, he stated a larger tire may bow kinda around the wheel, may look better, but not overal better for performance for an all weather tire
Old 08-02-2005, 08:49 PM   #5
sjl1614
Member#: 56791
06 OBS
I have P1's with 225/45 17 also....works great. I bought the wheels used and they had pilot sport's on them. Was very thrilled when i got rid of them. Once they wear just a little bit, very noise.
sjl1614 is offline   Reply With Quote
Old 08-02-2005, 11:35 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I have P1 with 225/45/17 RE070 tires also... P1 is relatively heavy but it's one of the most durable rims out there.
Old 08-03-2005, 12:30 AM   #7
three2seven
Member#: 31757
I think they are 17.3 lbs for the 17in. Why did the sales manager recommended the 205/50/17 instead of the 225/45/17. Could the offset be that far off fo the p1?
Old 08-03-2005, 10:40 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
I believe the weight is closer to 19.5 lbs for the 17x7.
Here's the application chart for the Michelin Pilot Sport A/S:
http://www.michelinman.com/assets/pd...lotsportas.pdf
Although 205/50's may be fine (5.5 - 7.5"), you'll note that Michelin also lists the 225/45's as an acceptable size for your wheel (7 - 8.5").
I'm not sure I understand the relevance of the offset in relation to the tire fitting on the wheel. ....clearance concern? .....or am I missing the point entirely?
Old 08-03-2005, 04:11 PM   #9
BlkWRXWag
Member#: 31821
2015 DS WRX
Offset has no relevance to fitting the tire on the rim. Ignore the sales manager - listen to the good people who actually own these cars
Old 08-03-2005, 04:20 PM   #10
BryanH
Member#: 993
With the offset of that rim you can run a 225 width tire all day long. I have P1's and have used both 215 and 225 with no ill effect.
But I have heard of somepeople having issues rubbing the 225's if they were really lowered....so keep that in mind.
BryanH is offline   Reply With Quote
Old 08-03-2005, 11:30 PM   #11
three2seven
Member#: 31757
Thanks all, in the future I will probably go with prodrive springs, so it sounds like 225's should be okay.
Old 08-03-2005, 11:36 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
....I'm in the market for Prodrive springs as well (on an '03). ....so if you run across any good deals, please let me know.
WTT: my 18" Prodrive P1 Anthracite for 17" P1 Migo Private 'For Sale' Classifieds 3 10-29-2005 08:52 AM
18's gold Prodrive P1 with Prodrive springs on black 04 sti Rafter666 Member's Car Gallery 3 09-17-2004 03:56 AM
WT Trade (UT) - I want your prodrive gold (P1/P7) for my Prodrive P1 Anthracite 17" Wagon Joe Private 'Wanted' Classifieds 0 12-17-2003 01:21 PM
Prodrive P1 or Prodrive WR Suspension Imprezz25rs Brakes, Steering & Suspension 2 02-05-2003 05:45 PM
Any Diff. in the OZ Prodrive and Prodrive P1? TwinTurbo Brakes, Steering & Suspension 1 05-07-2001 04:42 PM
