Old 08-02-2005, 02:40 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default Broken Window Switch (URGENT)
My driver's window switch no longer rolls up the windw, but it rolls it down just fine. Lately, I've just been leaving it up, but late tonight, I had a lapse and rolled it down at a McDonalds drive through . Is there a way to get it rolled back up without using the switch? Does someone have a part number for the switch, so I can order a new one? Everything else on the housing works (mirrors, locks, other windows) and it rolls down just fine, so I know it's neither the entire housing, nor the window motor. Thanks in advance!
Teh Legacy is offline   Reply With Quote
Old 08-02-2005, 05:23 AM   #2
JjSwee
Member#: 75880
My passenger window doesnt go down by the passenger control, I have to use the drivers control (only a pain when with friends). Anyways, I have attempted to fix it multiple times. I took the switch part out, and got to the point with the contacts. The one contact wouldnt touch when the switch was pushed (or pulled), so I just got something thin and manually forced it down and bent the metal a little so it connects with the motion of the switch. Free, worth a shot.
JjSwee is online now   Reply With Quote
Old 08-02-2005, 06:29 AM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
My son's '97 model did the same type of thing. His master control switch would open, but not close, the rear passenger window, causing you to have to reach back there to close it using the door switch.
I removed and disassembled his drivers door switch unit, and cleaned the contacts on the switches. They were black with sooty carbon, and not making good contact. I don't remember anything particularly tricky about the whole operation. Once the assembly was out, it seemed like a rather instinctive repair.
Good luck!
Rich
richeich is offline   Reply With Quote
Old 08-02-2005, 08:40 AM   #4
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
97: exact same thing for me. must be a y2k thing . A few weeks ago it became extremly finicky. I have to pull it a certain way for the window to come up. I might try opening + cleaing the contacts. whatever you do, let me know too..
iamrazor is offline   Reply With Quote
Old 08-02-2005, 09:27 AM   #5
Teh Legacy
Member#: 9853
to keep your mouth
shut.
iamrazor - That is EXACTLY what I had to do, but now it won't work at all. I'm going to pull apart the housing and take a look at the contacts like richeich suggested, and I'll let you know how it goes.
Jonathan
Old 08-02-2005, 10:03 AM   #6
Teh Legacy
Member#: 9853
to keep your mouth
shut.
I took the housing apart and cleaned what little carbon there was on the switch, and it still does not work. For anyone else having the same problem, the part number is 83071AE01B and it is $60.92 from www.subaruparts.com
Old 08-02-2005, 10:41 AM   #7
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Originally Posted by 97legacygt
$60.92 f
think i'll suffer with it.
Old 08-02-2005, 05:35 PM   #8
JjSwee
Member#: 75880
Try my solution. Force the metal contact down, push down on the metal a little so it has more of a slope. (I found more success when I held the button the other direction and pushed down, it bent the metal more, but not enough to constantly connect)
Old 08-02-2005, 08:56 PM   #9
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
how do i pop that panel off?
Old 08-02-2005, 10:02 PM   #10
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Carefully, but with force. Start from the top and work your way down. When you have all of it out except for the bottom, you should be able to unplug the mirror-controls from the rear of the panel. After you do this, you should have enough play to either fully take it out or at least have enough to unplug the window controls (then take it fully out.)
After it's out, you'll have to remove the cover surrounding the actual buttons. This is done by removing the four large phillips-type screws from the bottom.
From here, you can pop the individual switches off by pulling out the sides.
Hope this helps,
Jonathan
Old 10-03-2005, 01:41 PM   #11
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Jonathan, did you end up replacing that part? Mine's really bad now. I have to use a screwdriver to force the switch forward a bit before the window will go up. I don't want to buy one new. I'd rather find one from a junkyard.
<<< Is looking around for some...
Old 10-03-2005, 03:15 PM   #12
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Yes, I ended up replacing it through www.subaruparts.com (if memory serves me correctly.) It was a three minute fix, and it's worked ever since.
Cheers,
Jonathan
Old 12-05-2005, 07:58 PM   #13
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I'm fed up and want to order this. its $90 now
Old 12-05-2005, 09:17 PM   #14
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
gtwagon941 is offline   Reply With Quote
Old 12-05-2005, 11:42 PM   #15
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
yeah, thats the best i found too.
That's $texas.
Old 12-06-2005, 03:08 AM   #16
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
That's $texas.
Threeve!
fibuz is offline   Reply With Quote
Old 12-06-2005, 07:17 AM   #17
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Wow! I'm glad mine broke when it did.
Old 12-06-2005, 09:35 AM   #18
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Old 12-06-2005, 09:42 AM   #19
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
no way! think they'll fit?
aren't the WRX ones lighted too?
Old 12-06-2005, 09:43 AM   #20
Teh Legacy
Member#: 9853
to keep your mouth
shut.
It looks exactly like mine.
Old 12-06-2005, 09:44 AM   #21
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
Anyone tried a salvage yard?
There must be a million of those switches in circulation...
iguanamafia is offline   Reply With Quote
Old 12-06-2005, 09:46 AM   #22
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
Umm, I don't think they are, and if there is any illumination it's just the front driver's "auto".
None of the passengers switches are.
Old 12-06-2005, 09:53 AM   #23
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Old 12-06-2005, 11:38 AM   #24
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I actually spoke with F+S auto. they want about what a new one costs. maybe I'll go the ebay route...
broken headlight switch in 2004 Impreza five_turbos Interior & Exterior Modification 3 03-12-2008 05:38 PM
IC spray switch, Headlight Leveling, Master window switch off 04 STi travlindude Interior/Dressup/Audio & Security 0 02-27-2007 06:12 PM
MA wanted!!!! both window switches as well as window glasses needed!!! 99 2.5 RS Yusuke Private 'Wanted' Classifieds 1 02-12-2006 02:18 PM
broken fog switch NateDogg Electrical & Lighting 5 03-29-2003 01:11 AM
Broken window switch myredrs Car Audio, Video & Security 1 01-19-2000 10:44 AM
