08-02-2005, 11:03 AM | #1 |
Member#: 47746
Vehicle:2000 Impreza 2.5 RS silverhorn |
nitrous 1/4 mile time drop?
i have a 75 shot on my car. i currently run 13.4's with out the shot. any expectations of time drop off the 1/4 mile time? thanks
08-02-2005, 03:06 PM | #2 |
Member#: 85213
AKIC
Vehicle:2003 WRX VF-22 |
You should run it, and let us know. What type of a kit do you have? Wet or Dry? Who makes it.
08-02-2005, 07:50 PM | #3 |
Member#: 47746
zex dry kit 75 shot, and i will let you know
08-02-2005, 08:24 PM | #4 |
Member#: 52744
W. Canada
Vehicle:2005 Outback Gold |
I want to here your times as well
08-02-2005, 09:33 PM | #5 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
an 80 shot dropped me from 16.8 average to 14.8.
08-02-2005, 09:47 PM | #6 |
Member#: 26368
South East
Vehicle:2001 2.5RS-N BRP |
If you are running 13.4's w/o the gas, I can only assume you are turbo? If this is true, you will need a wet shot or direct port. If you run 13.4 all motor thats awsome!
08-02-2005, 09:57 PM | #7 |
Member#: 85862
I would just like to vote no on 'Dry' kits. Leaking nitrous pressure on the fuel pressure regulator is not my way of having reliable nitrous shots. Have you noticed that ZEX kits dont have filters of any kind!? If that small pin-hole in the ZEX kit clogges, your motor is FUBAR'ed, unless you realize and let off.
Wet systems are always safer, as long as you upgraded your fuel pump (in the tank). DOn't get me wrong, I sell/install ZEX and the rest, Nitrous Express, N.O.S. But nitrous is a cool thing, if you can resist it! Absubtle PA |
08-03-2005, 12:14 AM | #8 |
Member#: 49087
RMIC
Vehicle:1998 RST V8 STi swap '05 R6 '95 BMW V8 hotness |
Haha! Yay! More misconceptions about N20.
*disclaimer* I don't like nitrous. I think it's ricetastic and a way to shortcut good powertrain design. That being said... The zex kit is a very simple system that works remarkably well. It simply increases fuel pressure based on bottle pressure. The regulator of theirs clamps down on the return line to the tank to accomplish this. It has a conventional N20 jet placed wherever you want it. There is no "pin hole" to clog or any "leaking pressure" to speak of. Contamination in the system is always installer error and will simply clog the nitrous jet. This is why filters really aren't needed. Alot of the more popular kits (like the ones you can get at pep-boys/vato zone) include filters because Ray-Ray installing a system with nothing but his favorite set of vice grips just might introduce some contamination. Even if you do get contamination, your motor will run momentarily rich... stumble and die. The nitrous user will simply have to take his sideways hat off and re-start the car. The problem with systems like this is that nitrous distribution will always be slightly un-even between cylinders. With lower power kits this isn't a problem because they run slightly rich on all cylinders to be safe. An 80 shot is really pushing the limits of what you can get away with. You will probably end up burning the #4 cylinder over time. The problem with uneven fuel/nitrous distribution gets more pronounced on turbo cars... and if you're using a RRFPR for the turbo kit... forget about it. I REALLY don't like the idea of wet systems on DIS ignition cars. If you are still on the nitrous and have to snap the throttle shut for some reason you can cause a pretty bad explosion in the manifold. The waste cylinder fires at the top of the exhaust stroke. There is just enough valve overlap there to allow the intake valve to be open when this happens. If you have a nice dense fuel/nitrous mixture hanging out in the manifold... intake valve open... plug fires... *boom*. Have I personally seen this happen? No... but it's a very real possibility and does happen from time to time. Wet systems will cause carbon buildup in the intake runners over time and I have also seen MAP sensors fouled over time from running wet systems. That can be obnoxious to diagnose because they will sometimes give accurate readings on a bench. Let us know how you do at the track. Rember to keep the rev's high before hitting the button |
08-03-2005, 11:16 AM | #9 |
Member#: 47746
thanks for all the info. and ill let you guys know on fri night or sat morning.
(racing is on fri night) |
08-03-2005, 11:34 AM | #10 | |
Member#: 81633
Vehicle:'98 RS-T Blue |
08-03-2005, 08:17 PM | #11 |
Member#: 66310
South East
Vehicle:2015 korean muscle |
wot switch or not the fuel still puddles and the nitrous backs up in the manifold. You can have a nitrous backfire if you need to peddle the car. Wet single fogger systems will have nitrous backfires no if's and's or but's.
This is really common on the GT40 intakes and such with the long runners. If you get off the gas your throttle plate closes and the fuel starts to puddle and then hits that hot cylinder when the intake overlaps. Thus creating a nice explosion that will blow the upper intake apart. |
08-03-2005, 11:43 PM | #12 | |
Member#: 81633
I have seen one engine backfire (SAAB 1/4 miler with a ton of nitrous being shot in). Driver was doing a burnout and needed the spray to turn the tires in the water box. Driver got the tires partly heated and the turbo kicked in. Engine stalled and the driver attempted to restart (oil to the turbo) and BOOM!!!!!!!!! This car did not have a WOT switch. Backfires "usually" happen when an engine goes lean. |
08-04-2005, 03:09 AM | #13 |
Member#: 49087
RMIC
Read how a DIS waste spark ignition system works. The conditions that would cause a backfire are totally different than something with a distributor. Oh wait... everything works like old v8's. Backfires never ever ever happen under lean conditions. A bit of afterfire under the right circumstances maybe... detonation yes.... but no backfire.
08-04-2005, 12:05 PM | #14 | |
Member#: 81633
Oh wait everything works like a new 'Subie'...guess U have never driven a carb car with a misadjusted choke or an accelerator enrichment not working. I must have imagined that "popping" noise coming from the air cleaner. Even an out of tune FI engine will pop thru the intake and not from overly rich condition, but a LEAN condition. Whether it be a flathead lawnmower engine or some exotic pneumatic actuated multivavle engine, there are some basic concepts that both engines have to adhere to. I'm a little familiar with DIS with the waste spark and you sarcastically bring a good point up. Strong work. |
08-04-2005, 03:32 PM | #15 |
Member#: 81633
A question to no-coast-punk
Did a little research on some engines that I degreed. From the cam manufacture's card, a supercharged engine has the intake opening at 5° BTDC and more radically camed engine has the intake opening at 30° BTDC. Since ignition timing will be between 30 to 40° BTDC at the higher RPMs, how is possible that the ignition spark can light off the intake manifold mixture with the intake valve closed? |
08-04-2005, 06:31 PM | #16 |
Member#: 66310
South East
well lets see..... Subaru's are fuel injected with a throttle body. So are GT40 intake manifolds which are for the good old EFI mustang. Carbs are different, very different, the fuel wont puddle like it will on a EFI car. There are no twists, and bends and horozontal passages on Carb manifold. Im sure you were using a plate or a direct port. A plate evenly distributes the nitrous/fuel into 4 runners then they split into 2. A direct port seperates into each cylinder. Now most subaru enthusiasts use a single fogger that sprays the fuel/nitrous from ONE nozzle. This is very prone to fuel puddleing if you have to peddle the car. The boost goes to 0 when the throttle plate closes and the rest is history. But if anyone here has to peddle a subaru then well im not sure what your doing. Its not liek a rwd car that will fishtail or hang the front tires, so no peddleing is needed =).
08-04-2005, 09:23 PM | #17 |
Member#: 64673
NWIC
I have run a wet system and "sprayed" it at least 100 times. no backfire.
08-08-2005, 12:02 AM | #18 |
Member#: 5349
I used two 480 cc injectors in the intake manifold after the throttle body as secondary injection in my old supercharger setup. No backfires, no puddling. Even distribution. That's enought fuel for 160hp additional hp. I don't think anyone here runs a 160hp shot. No puddling, no backfires - not in our intake manifolds.
sti 1/4 mile times for stock turbo and injectors with no nitrous | whitesti04 | Proven Power Bragging | 59 | 05-08-2005 11:51 PM |
My N/A 1/4 mile time no nitrous (11:1 comp 8,000 rpm redline)! | dcoty | Proven Power Bragging | 90 | 10-01-2004 12:46 AM |
Stage 4, 1/4 mile times | SGOSWRX | Proven Power Bragging | 19 | 11-25-2002 02:49 PM |
1/4 mile times with stage 4? | b00st3d | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-25-2002 10:36 AM |
Nitrous 1/4 Mile Times | Kevin Thomas | Normally Aspirated Powertrain | 1 | 08-24-2001 10:43 PM |
