Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 08-02-2005, 11:43 AM   #1
Member#: 78936
2005 WRX
Polar White
Default Is EM upgrade or utec need for Uppipe on 05 WRX 2.0 l
I am confused and have heard lots of conflicting stories on weather or not EM upgrade is needed when changing any pipes on the 2005 WRX. I have heard Subaru changed the pre boost enrichment parameters a bit for emission concerns, on the later 2004's and 2005's vesus the older 2003's. Interested in starting with an uppipe to cut lag but have been told that any decrease in turbo spool up time or reduction of lag, could widen gap of running lean with ECU everytime you go into boost. Bad on engine life. In short, I have heard that Subaru has extended a delay in fuel entry, a little eariler than on 2003's in pre boost condition to lean out emissions and get kudos with EPA. So I was told that the ECU would not immediately change its preboost enrichment. Based on this variance sounds like the faster turbo would create boost too fast for stock ECU on a 2005 to enrich mixture appropriately??? I have heard for a down pipe or stealthback and/or all pipes off stock turbo that EM is needed and can perhaps grasp that due to back pressure and a definitly more open system downstream off turbo. I am looking for an essentially faster than stock car and want to start with an uppipe only, question again is, will I need EM like cobb A/P or UTC or Vishnu and will I burn out the two stock cats down the line and fry rings?? Please help!!!! thanks!!
Boosto is offline   Reply With Quote
Old 08-02-2005, 11:46 AM   #2
Member#: 23676
the up pipe should be done before any power mods on ANY wrx (not 06's )
I have replaced several up pipes/turbos due to the up pipe cat puking its guts into the turbo.
Then EM.
You will be ok without EM at this point with just teh up pipe. Do a downpipe though, and you need EM on 04-05 wrx's
Old 08-02-2005, 11:57 AM   #3
Member#: 78936
2005 WRX
Polar White
Default i have heard of cat crap getting into turbo......
Thanks for you input I hear you Dave on the cat guts nailing turbos, but for an uppipe on an a 2005 is true that this model year is so sensitive to any change in turbo spool with stock EM. I have 7600 miles on car and have done y pipes, crank case catch can, and perrin pannel filter. Will stock ECU code correct for faster turbo entry with all these mods is my main concern. Right now can't afford EM and a stealthback but eventually want it more towards end of factory warranty. This is my first subaru and i come from N/A land. My tendency in tuning up cars is to mod in stages this way from baseline you end up getting what you want without breaking the bank.
Wtb Cobb Or Utec For 05 Wrx 2.0 saroeunhem MAIC Private Classifieds 1 01-03-2010 08:08 PM
Need advice on 03' Wrx 2.0 Limited Edition upgrading rH!n0ch3f Newbies & FAQs 6 11-17-2009 03:47 PM
Fs: (Nc) Cobb Acessport V.2 for 02 - 05 wrx 2.0 (In Box) Kingdlee Engine/Power/Exhaust 10 04-27-2008 01:35 PM
Need for uppipe on 07 wrx Clever23 Newbies & FAQs 20 03-18-2007 11:42 AM
