Old 08-02-2005, 02:12 PM   #1
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Default Question re: painting JDM sidemarkers
Ok, so I'll have a can of base coat color matched and a can of clear coat. I know that I need to mask off the lens, which I've already done. But what else prep, finish work do I need to do? Is is necessary to sand the area to be painted first or just use some sort of chemical stripper on it?? I've never really done any of this kind of work before, so...
After it is painted/clear coated what next? Do I need some sort of buffing compound or anything?
Thanks
Jared
PS: I have some JDM amber sidemarkers available if anyone is interested.
gtwagon941 is offline   Reply With Quote
Old 08-02-2005, 04:27 PM   #2
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Lightbulb
I did mine with light sanding and then a couple coats of Testor's red paint. Then a couple coats with touch-up paint to color match. Sanded, then applied a couple coats of clear coat. They've been on my car for a year now and look great still.
You might want to do a coat of primer first, but o.w. what you have sounds like the right stuff. And, it'll come out much nicer, much more quickly than my brush was able to do. But those are the tools I had...
The side winker isn't exactly a high-wear area anyway.
- Eric
Lil' Red '98 2.5 GT Wagon - Pics
Sorry. No pics of the side winkers.
Radio Flyer is offline   Reply With Quote
Old 08-02-2005, 09:25 PM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
yeah, I thought about primer, but I don't think it will be an issue in that spot, especially since I'm not even painting much at all. What grit sandpaper did you use?? Any special polishing after is was all done??
thanks
Jared
Old 08-02-2005, 09:34 PM   #4
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
use a scrotch brite pad to scuff the surface. then use a plastic primer.
Russell Rogers is offline   Reply With Quote
Old 08-05-2005, 12:30 AM   #5
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Question
Not sure of the grit I had. Just used some modeling sandpaper that I had. The brushstrokes were still pretty visible - the touch-up paint isn't really intended to cover much area. I'd have much rather had spray.
Speaking of which, how is it that you "have a can of base coat color matched"? I've got some other project ideas that that'll be perfect for...
- Eric
Old 08-05-2005, 02:42 AM   #6
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
well, there is www.paintscratch.com or a local paint shop. I was going to do the online route as I've heard good things about them, but then I checked locally and got the same thing for about the same money, but I had it the next day.
Under the hood there is a metal plaque that has your paint code on it. Any competent auto paint shop should be able to make you a spray can to that color code. I got a can of base coat and clear coat for 40 bucks. Kinda spendy, but what can you do??
I've done the coat of primer and the first base coat. I sanded the base coat layer with 600 grit, wet. Hopefully it will only take 1 more coat and then on to the clear. Wait several days and then some rubbing compound to make it shine.
Jared
Old 08-05-2005, 12:18 PM   #7
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
good to see that you wet sanded with 600 grit between paint coats... but did you sand with a 400 grit BEFORE you applied any paint? you want the use the sandpaper to scuff up the surface just enough for the paint to grab hold, not too much so you can see a bunch of deep scratches, though. and primer is VERY important for the longevity of your painting project. primer is kind of like the glue between your car part and the paint. it helps provide a better surface for the paint to stick to and also stops stains or bleeds from coming through... always use primer first!!!
janikphoto is offline   Reply With Quote
Old 08-05-2005, 12:31 PM   #8
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
I did scuff the surface before the primer. I applied the first coat of clear coat before I left for work this morning. I bit more wet sanding and then another coat of clear and I will be done with the first one, at least until I can rub it out.
Jared
Old 08-07-2005, 09:47 PM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Jared
Thats some serious attention to detail. I would have suggested some plastic primer like Russell said.
ss
subysouth is offline   Reply With Quote
Old 08-08-2005, 01:25 AM   #10
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
yeah, I guess. But I mean the wet sanding took literally 15 seconds. I think I spent more actual time masking the lens off. Anyways, if I can get some rubbing compound tomorrow they will be all ready to go. I have some wire and will sauder them in sometime soon.
Jared
Old 08-08-2005, 01:38 AM   #11
janikphoto
Member#: 10471
2000 BMW Z3
solder not sauder, but who's really worried about grammar these days... it is good that you are taking your time and doing it right. it's the quality in the details that will make the difference!!!
Old 08-08-2005, 01:56 AM   #12
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
yep, I was pretty sure it was wrong but didn't care enough to check on what was right.
Jared
fs(socal):Bugeye EDM headlights, PSM jdm fog cover, sti skirts, jdm sidemarker ubi_scoobi Exterior/Styling 15 05-24-2010 12:15 AM
Question re: Touch-up paint and detailing invisiblecity Car Care & Detailing 2 05-07-2009 10:49 AM
JDM sidemarker question carrman Interior & Exterior Modification 9 11-30-2005 05:19 PM
Question for Those That Have Done JDM Sidemarkers STI 2 NV Interior & Exterior Modification 24 04-24-2005 08:21 PM
JDM Sidemarkers... a few questions- Handsdown Electrical & Lighting 9 04-20-2005 11:10 PM
