#1 |
Vendor Sales Rating: (508)
Member#: 82767
NWIC
Sale prices expire Aug. 31st 2005
NEW!! Pink STi Strut and Spring Kit from Subaru - full kit!! - - $1350.00 ![]() Technical information from Subaru: Struts: Q.What is the compression Rate? A.Front 840N, Rear 620N at 0.3m/sec. Q.What is the Rebound Rate? A.Front 1580N, Rear 1150N at 0.3m/sec. Springs: Q.What is the "Progressive Rate"? A.Front 60N/mm, Rear 50N/mm. (converts to approx: 342 Front and 286 Rear) Q.What color are they? A.STI Cherry-red. Q.Are they re-buildable? A.No, they are not re-buildable. Q.Are they adjustable? A.No, they are not adjustable. Q.Who is the manufacturer? A.STI. Q.What are the component sizes compared to stock? A.Strut cylinder diameter 39mm (STI parts-STI ver.) vs. 22mm (WRX & RS). Q.What process is done on them that make them better than the others? A.The specifications for performance were derived from WRC Subaru Rally Car experience. Q.Will they work on other models? A.They are designed for 04-05 WRX SEDAN. They can also be used for 04-05 RS SEDAN & 04 STi. (not for 05 STi models) 50% stiffer than stock STi 100% stiffer than stock WRX 130% stiffer than stock 2.5RS View and/or Order this kit here: *click for Suspension kit* ****************************************** Also on sale again this month: WRX SPT Pink Springs for Sedan/Wagon - $225.00 ![]() *set of springs + new washers/nuts for suspension bolts *lowers the car approx 1" *spring rates: 223 front/ 195 rear *can be used with OEM struts *sedan and WAGON specific!!! *for 2004/2005 model Impreza - - **Not for STi** **click here for SPT Pink spring kit for Wagon or Sedan ------------------------------------------------------ Any questions? email or pm me. Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com
#3 |
Member#: 82767
NWIC
they are not available separate from the "kit"
struts/springs are sold as "one" order a strut, a spring comes with it. subaru will not allow the 2 to be separated. Jamie |
#4 |
Member#: 4115
VIC
Vehicle:2002 Impreza WRX White |
Ordered the Springs for the Sedan online, thanks Jamie!
And that strut/spring package is a screaming deal for the performance you get. Have you had a chance to try it out, Jamie? Dunny |
#7 |
Member#: 84114
Vehicle:05 Impreza/STI Black |
will the pink springs improve stock 05 sti handling and looks? what kinda install hassle? im in need of springs, cusco front and rear sway bars, full bushing kit, have any of that? thanks
#9 | |
Member#: 82767
NWIC
strut spring KIT is JDM spec spring kit is USDM SPT Pink springs Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#10 |
Member#: 42303
NESIC
Vehicle:2004 WRX Rally Blue |
Some dumb questions here:
1) Does the strut/spring kit lower the WRX? 2) Does the drop on the SPT pinks provide an even wheel gap? |
#11 |
Member Sales Rating: (9)
Member#: 5583
BAIC
Vehicle:96' Ver.2 Wagon White |
Yikes, I have been waiting for these! Basicaly a non adjustible version of the "Arai"/STi V-limited suspension. I hope these are still available by the end of the year, cause I'll be buying!
#12 | |
Member#: 82767
NWIC
they should still be available, I dont think that Subaru will be discontinuing them ![]() Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#13 | |
Member#: 82767
NWIC
2) no strut spring kit is 100% even front to rear. fronts need a tick more clearance so that the wheels can rotate/turn here are some customer cars with SPT Spring kits installed: ![]() ![]() shout with other questions ![]() Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#16 | |
Member#: 82767
NWIC
You mean as far as installing the 2004 springs? you'll need the spring kit + 2 , 2004 style rear strut tops. these can be OEM or Group N shout with other questions Jamie www.subarugenuineparts.com |
#18 | |
Member Sales Rating: (11)
Member#: 63294
E. Canada
Vehicle:2002 WRX Wagon Blue |
How much are OEM or Group N strut tops? Thanks, alwrxwu |
#19 | |
Member#: 82767
NWIC
I have sold many sets to 92x owners discuss this further maybe at: www.saab92x.com i know a couple of the guys there are running them ![]() Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#20 | |
Member#: 82767
NWIC
group n mounts *click here* OEM are approx $40ish each you can look them up in our OEM store here: https://www.subarugenuineparts.com/oe_parts_cat.html Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#22 | |
Member#: 82767
NWIC
no idea on the JDM spring rates but i gather they are 300-something front & 200-something rear SPT STi pinks are 223 front/ 195 rear Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
#23 |
Member#: 76211
Jamie, I've got a 2005 2.5RS sedan, I bought the pink springs from you back when you were at your old job. Anyways, I want to change the pinks and thinking about either the Eibachs or the SPT. Does SPT have any for my car?
Thanks. |
#24 | |
Member#: 82767
NWIC
the pink springs we have here are exactly what you need for your car. THEY ARE MADE specifically for the non Sti Sedan. drop the car just about 1"..... which pink springs do you have now? pm me and we will continue to discuss/hammer this out for you! -------------------------------------------------- this sale is over! springs are still on our site, but now regular priced: see: https://www.subarugenuineparts.com/a...ds=spring+pink contact me with questions we will have a new sale for the month of Sept soon!! Jamie Thomas Jamie@chaplins.com www.subarugenuineparts.com ![]() *************************** www.subiegal.com |
| Thread Tools | |
| Display Modes | |
| 04 05 wrx sti wide body front kit, wing and other neat stuff too | blackrod punishment | SCIC Private Classifieds | 13 | 02-21-2010 12:09 PM |
| WTB- 04-05 WRX/STI HEADLIGHTS Stock/Painted or JDM | NutWagon | Mid Atlantic Impreza Club -- MAIC | 0 | 02-04-2010 05:12 PM |
| FS: (CO) 04-05 WRX/STi GT35R/APS Turbo kit-COMPLETE setup | Scuba Steve | RMIC Private Classifieds | 7 | 02-16-2009 12:37 AM |
| FS: 04-05 wrx/sti FRONT STRUT BAR | SlouWRX | TXIC Private Classifieds | 0 | 03-29-2008 06:03 PM |
| So Cal: 04-05 WRX/STi Progress springs & Kartboy Short shifter for sale | sjrhee | Private 'For Sale' Classifieds | 8 | 08-20-2005 03:54 AM |
