![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 67338
South East
well I've been reading up in my Hyper Rev as well as seeing what others have run.
I notice that alot of the Japanese Tuner companys use a 245/40 on thier Impreza's w/ that Rim size or even 9"wide. I hear that is the Perfect Replacement for Stock Rolling diameter,only a little wider to get use of a 8.5" wide wheel? I have TEIN flex and they are set to the Tein Measurements (Slammed) and still think a 245/40 would fit but someone said NO,..Thats still to wide for a Lowered STi w/ 8.5's? anyway..what size should I go for that would keep rolling stock Diameter w/o a Huge Sidewall but enough to not have to roll fenders? I guess bigger would make the Gears longer and smaller would make quicker gears?
#2 |
Member#: 24447
SWIC
Vehicle:2010 Evo GSR GG |
255/40/17 is the same diamiter as the stock 225/45/17. I would go with that. Since U have an 04 STI U might need to roll the fenders a little.
Ryan |
#3 |
Member#: 49333
SWIC
Vehicle:04 STi java pearl black |
Depends on your wheel's offset, and the particular tire you choose.
I have a couple of sets of +48 17x8.5s. With Eibach springs I've rubbed using shaved 225/45s (Pirelli PZero System Asimmetrico) and not rubbed using 245/40s (Pirelli PZero Nero M&S). I rolled the rear fenders and that solved the rear rubbing issue, though the 225s still rubbed on the front innerfender liner. Raise your height a bit and you shouldn't have problems, depending on offset. |
| Thread Tools | |
| Display Modes | |
| Tire choice for AStock for next year | conevadr | Motorsports | 6 | 10-04-2007 02:18 PM |
| whats the widest tire we could use on 17x8.5 | aceking66 | Tire & Wheel | 16 | 05-02-2005 04:02 PM |
| tire size with SSR comp 17x8.5 and JIC FLTA2 | MattSTi | Brakes, Steering & Suspension | 11 | 11-16-2004 05:26 PM |
| All Season Tire Choice for STI? | Guyver | STi Forum Archive | 10 | 08-11-2003 02:23 PM |
| Tire choices for 92 Legacy (14 inch wheels) | PlainGuy | Newbies & FAQs | 0 | 09-29-2001 12:19 AM |
