Old 08-03-2005, 01:06 AM   #1
lik
Member#: 36458
2000 2.5RS, 2005 WRX
2011 STI, 2015 WRX
Default need help on the size of wheels
can anyone tell me that pls
will 18"x 7.5 with +42 ( 225/40/18) cause rubbing issue on a 05 WRX??
Thx
Lik
lik is offline   Reply With Quote
Old 08-03-2005, 03:00 AM   #2
lik
Member#: 36458
2011 STI, 2015 WRX
need help .. thx
Lik
Old 08-03-2005, 03:27 AM   #3
ripvw
Member#: 27790
sedan or wagon?
what specific tires?
how much have you dropped the car - what springs are you running?
FWIW, people have successfully run 18x8 ET48 wheels with 225/40x18 on the sedan with moderate drop springs, i.e. Prodrives, SPT, STI - no rubbing
ET42 is going to make it 6mm closer to the fender - can be a problem with rubbing on the rear fenderwell of a sedan depending upon how wide the tire is and how low the car is dropped. rolling the fenders will solve the problem. if you have a wagon you will have to roll the fenders with that offset even at stock suspension height - less room with the wagon - I know...
ripvw is offline   Reply With Quote
Old 08-03-2005, 03:40 AM   #4
lik
Member#: 36458
2011 STI, 2015 WRX
Originally Posted by ripvw
sedan or wagon?
thx for the reply
I have a 05 WRX sedan running stock suspension (no drop at all)
Lik
Old 08-03-2005, 03:56 AM   #5
ripvw
Member#: 27790
Originally Posted by lik
thx for the reply
I have a 05 WRX sedan running stock suspension...
then it may indeed work. still would be nice if you could test size the rear to see how much fender clearance you have. check out this illustration from Jon Bogert may help you to see what you're up against:
Originally Posted by Jon Bogert
This'll give you an idea of relative position on an '04 STI. I put this together when shopping for wheels:
you can see how close that ET46 7.5" wheel is to the fender - and I'm not sure but I think the '04 STI has a little more room than the standard WRX sedans. you might get some more help on this issue a little later in the morning - only insomniacs like me and desperate people like you are up this early in the morning...
Old 08-09-2005, 11:58 PM   #6
lik
Member#: 36458
2011 STI, 2015 WRX
any one have more detail about it?
i have PM some member in the club... and i keep getting different answer. is there anyone actually running with the same setup ? 18x7.5 with 42mm offset using 225/40/18 on a stock height 05 WRX sedan
thx for your help
lik
need to know the size of fifth gear size. hybrid gti 2 Transmission (AT/MT) & Driveline 7 06-12-2006 12:43 AM
where to get stats on the size of the aftermarket car modding industry? Roy Lin Off-Topic 5 10-11-2005 10:40 AM
GUYS need help on the ISSUE OF TRUNK sliding pr0nstar South East Region Forum 13 03-30-2003 10:01 PM
need help on rim sizing SubieNubie Brakes, Steering & Suspension 3 07-01-2002 05:01 PM
