Old 08-03-2005, 10:44 AM   #1
LotusDriftx
Member#: 48528
Default Squeaking from rear??
A few months ago I started getting a sqeaking from (I think) the right rear whenever I would turn left.
It started getting worse, and squeaks on not smooth pavement and whenever loading/unloading the suspension...etc, basically a lot of conditions.
I thought it was a blown strut, because when parked, if I bounce on the right rear corner the car will make the same noise. so I replaced the struts, and the noise is still there
Anyone have a guess at this?
LotusDriftx is offline   Reply With Quote
Old 08-03-2005, 11:51 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Swaybar or endlinks? Maybe try putting some some lithium grease on it...
Hank3 is offline   Reply With Quote
Old 08-03-2005, 12:03 PM   #3
LotusDriftx
Member#: 48528
Ya, I am going under the car this weekend to check all the bolts and spray everything down with lithium. Just hoping someone had a similar experience and had a good guess so I might know where to start looking.
Thanks for the tip.
Old 08-03-2005, 01:41 PM   #4
rockt104
Member#: 19111
I would quickly check if it is the sway bar by disconnecting it and driving around. if you are all stock that is 90% likely to be it.
Kevin
rockt104 is offline   Reply With Quote
Old 08-03-2005, 01:53 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
model year? WRX? STi?
if it's a rear swaybar, then you will need teflon tape to wrap around areas between bar and rubber.
If it's rear strut bar, trying replacing the top hat and make sure top strut nut is tightened to spec. Loose nut could also causing clunking...
Old 08-03-2005, 01:58 PM   #6
LotusDriftx
Member#: 48528
Car is a stock 02 wrx. A few months back the rear end was torn down to replace the rear diff (so I suppose a potential source of a loose bolt or something to that effect).
Good idea on simply removing the sway bar and then testing the car.
I just replaced all of the spring/struts/tophat assemblies with those from an 04 wrx and the same noise is there. So it has nothing to do with the struts, tophats, springs or perch mounts.
Squeaking from rear headliner?? Moshpit552 Brakes, Steering & Suspension 1 12-28-2005 06:18 AM
Squeak from rear when going over bumps CletusTheDwarf Brakes, Steering & Suspension 6 01-31-2005 03:57 PM
Squeak from rear suspension Achilles38WRX Warranty Issues & SOA Problems 2 01-16-2002 09:59 AM
Strange squeak from rear end Mike Riegel Technical Forum Archive 1 07-19-2000 08:47 PM
