Old 08-03-2005, 02:10 PM   #1
doghouse
Member#: 83500
Default P0031 Front O2 Heater Low
I've got the P0031 Code right now and I suspect it's keeping me from passing emmissions. I've tried everything I can think of to solve this and haven't come up with anything. I've got 13.9V at the heater connector when I have my probe on engine ground. With the car running I have 9.7-->9.9V on the connector itself. It's an uncut factory harness but I did check continuity for the ground wire. As well, I checked the ground from D8&D9 which is supposed to ground the whole shibang. I even went so far as to cut the wire at the ecu and put a wire around the car directly to ground. Nothing. I've also tried three other O2 sensors, although I doubt this is the problem as it's a heater low and not a sensor not working.
Any suggestions? Thanks.
-Matt
doghouse is offline   Reply With Quote
Old 08-03-2005, 02:48 PM   #2
AKGC8
Member#: 1305
2000 Impreza
US WRX swap?
D8 and D9 aren't the grounds for the 02 sensor
AKGC8 is offline   Reply With Quote
Old 08-03-2005, 03:12 PM   #3
doghouse
Member#: 83500
yeah, US swap. What are D8 and D9 then? The black with blue stripe that join roughly 6in from the ecu into one wire? Maybe I have the numbers wrong, I'll go check?
They aren't grounds for the O2 per say, If I read correctly they should ground the ECU whatever it's doing to the O2 sensor.
Thanks
Old 08-03-2005, 03:24 PM   #4
doghouse
Member#: 83500
I should be more thorough in my post. I'm just tearing my hair out. I have 6 codes in total. P0183-Fuel Temp Sensor (twice), P0463- Fuel Level Sensor, P0031-O2 Heat low, P1400- fuel tank pressure solenoid low, P0447-Evap Emission Control.
Is it possible that these are cascading and "ghosting" the O2 code?
Anyone have any values to fake the fuel tank stuff for now?
Thanks
Old 08-03-2005, 03:52 PM   #5
Randoramma
Member#: 60649
00RS EJ205 swap
hmmm, that sounds very familiar to what I had when I finished my swap. I still have the 0463 code.. When you wired up the ECU, what set of pinnouts did you use to?
Randy
Randoramma is offline   Reply With Quote
Old 08-03-2005, 03:56 PM   #6
doghouse
Member#: 83500
how did you get rid of the rest of the codes? Did you have the P0031? How did you get rid of it?
Thanks
Old 08-03-2005, 04:01 PM   #7
Randoramma
Member#: 60649
00RS EJ205 swap
Well the pinnout I had used to determine where to place pins had several sensors backwards, so I had to get a real copy of the ECU pinnouts and repin those sensors. I wiped several of my codes when I did that, and P0031 was one of them. I dont have the diagram with me, but I bet its D8 and D9 which wiped that code for me. BUT that doesnt mean it will work for you, thats why I asked where you got your pinnouts from.
Randy
Oh, and before I had done this, I went throught the FSM diagnostic troubleshooting guide and everything was fine... weird.
Old 08-04-2005, 07:48 AM   #8
doghouse
Member#: 83500
Did you get a chance to check your pinout? I'm using a wiring diagram that I got from the Subaru technical site. I also have the procedure for checking out the code and both agree that the D8 and D9 are grounds. Anyway, I've checked nearly everything that I can think of here and could use any help.
Thanks.
Old 08-08-2005, 11:40 AM   #9
doghouse
Member#: 83500
So nobody has any insight on this? Nobody had a similar problem? I really don't know what to do at this point.
Old 08-08-2005, 04:37 PM   #10
Randoramma
Member#: 60649
00RS EJ205 swap
sorry I keep forgeting to bring in my pinnouts to work (where I have i-net access. Will try tommorow.
Randy
Old 08-09-2005, 08:59 AM   #11
doghouse
Member#: 83500
Thanks for trying. Maybe today?
-Matt
Old 08-11-2005, 10:05 AM   #12
doghouse
Member#: 83500
Any chance you remembered today?
Thanks
Old 11-11-2005, 08:50 AM   #13
turboK
Member#: 29689
90 ls1 miata
mariner blue
Doghouse-
Did you ever figure this out? I have the EXACT same problem and code. All wires in the circuit have continuity, and the sensor is good... Even checked out the ecu in a brand new car, and no code... Very weird...
thanks
karl
turboK is offline   Reply With Quote
Old 12-13-2007, 10:42 PM   #14
elsanto
Member#: 34832
1989 M3
bump from the dead, did you guys ever figure this out? I've got the same issue on a 98 outback swap
elsanto is offline   Reply With Quote
Old 09-01-2008, 06:41 PM   #15
tja1618
Member#: 181995
2003 WRX
second bump from the dead. I have been running my 03 WRX on a OTS cobb stage 2 map. It has worked flawlessly up until this week. The first strange thing is that when I tried to have my car inspected there were a few systems that were 'not ready', whatever that means.
Catalyst
Oxygen Sensor
Oxygen Sensor Heater
However, when the guy showed me this, the car wasn't throwing any codes or CELs. A number of miles later I was at WOT accelerating (nothing crazy, merging onto the highway) when a CEL was thrown. Immediately I checked the code: p0031 - HO2S Heater Sensor Circuit Low
I wasn't sure what to make of this, but the car seemed to be running fine. I had to drive the car before I can get it checked out thoroughly (since I am at school), but everything seemed normal until just now when I apparently hit fuel cut in 2nd gear at WOT around 4500 RPM. It was very unsettling to say the least (especially since I went to hell and back getting a center differential replaced).
Does anyone know what the cause of this is? My next course of action is to inspect the sensor however I can and try to check the wiring. The only mods I am running are a TBE, short ram intake, and a cobb stage 2 map.
Please help
tja1618 is offline   Reply With Quote
Old 09-01-2008, 06:45 PM   #16
elsanto
Member#: 34832
1989 M3
^^ with a car that old I'd throw in a new o2 sensor, there isnt much elese that can go wrong with the circuit unless you are doing a swap as i was, which just totally screwed it up.
put a new o2 in, the CEL's may have been hidden by the AP, and thats why your CEL isnt turning on..
good luck
Old 10-23-2008, 04:59 PM   #17
MUscooby
Member#: 86019
2002 WRX Stg 1
World Rally Blue
I just threw a c0031 yesterday while driving, car still ran fine but i was going to check into fixes. I reset the ECU to see if it was a false signal, but the CEL came back immediately. Then i took the car for a brief spin and it was running like the ultimate turd: rough/inconsistent acceleration and, according to my AP, my max boost is 12.0.
what is the deal? why am i only hitting 12.0 when i am running an OTS cobb stage 1 map? Is it all b/c of the damned o2 sensor?
MUscooby is offline   Reply With Quote
Old 10-23-2008, 05:03 PM   #18
elsanto
Member#: 34832
1989 M3
Yes, most likely.
Old 10-24-2008, 10:57 AM   #19
MUscooby
Member#: 86019
2002 WRX Stg 1
World Rally Blue
^^ Good idea/bad idea... going to my economy map (AP) until i get the new o2 sensor installed? Stock map?
Old 10-24-2008, 12:24 PM   #20
elsanto
Member#: 34832
1989 M3
I wouldnt recommend driving at all without a front o2, the car will run pig rich, and you really have no control over AFR...
Old 10-24-2008, 01:07 PM   #21
MUscooby
Member#: 86019
2002 WRX Stg 1
World Rally Blue
^^ yeah that's probably the best idea
should have the new o2 sensor in a couple days, then i just have to drive to my friend's place where i can install it. its gonna suck not being able to get around, though.
CEL P0031 front 02 heater a/f ratio sensor low voltage shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 11-09-2011 09:06 PM
cel code p0031 - front o2 sensor sjs0433 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2007 04:24 PM
P0031 front O2 sensor AliBenn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-05-2006 03:41 AM
P0031-->Front O2 Heater Questions doghouse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-23-2005 02:30 PM
p0031 --> O2 heater problem doghouse Subaru Conversions 2 03-22-2005 07:42 AM
