Old 08-03-2005, 09:22 PM   #1
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
Default inside tire worn smooth. too much camber? (pic)
got my allignment today and check out my front tires
both are worn on the inside only
vwown3d is offline   Reply With Quote
Old 08-03-2005, 09:59 PM   #2
kcook
Member#: 78074
2005 STi
can we get pics of ur stance... and what suspension u on?
kcook is offline   Reply With Quote
Old 08-03-2005, 10:02 PM   #3
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
im on flex's, rode for 4 weeks on rediculous camber b4 i could get an alignment which i got today. also they ripped up the highway by my house and every day to work i have to ride on the stuff which looked like a cheese grader of pavement just eating my tires.
Old 08-03-2005, 10:44 PM   #4
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
you answered your own question. Your toe was out of whack, and coupled with lots of negative camber, you shredded the tire. should've gotten the alignment earlier.
ChrisDP is offline   Reply With Quote
Old 08-03-2005, 11:03 PM   #5
j-wrx
Member#: 14180
2002 Stg.1 WRX Wagon
Platinum Metalic Silver
exact same thing happened to me last week when I went in for a tire rotation. (posted yesterday on this). I got the alignment redone, they said that the toe was indeed the problem.
Those pics gave me deja vu...
j-wrx
j-wrx is offline   Reply With Quote
Old 08-04-2005, 09:49 AM   #6
not ur avg girl
Member#: 65457
2006 Legacy
Grey
OMG i didn't think it was THAT BAD!!
not ur avg girl is offline   Reply With Quote
Old 08-04-2005, 10:34 AM   #7
KC
Member#: 442
16 SS
00 S2000
Camber doesn't kill tires... it's the toe that does.
KC is online now   Reply With Quote
Old 08-04-2005, 10:51 AM   #8
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Same here. I have a toe problem on my front passenger corner, and my tires look similarly worn down on the inside edges, though not as much. It will soon be time for new tires (good riddance to the RE-92s) and an alignment (more camber up front, please).
If my tire shop (to be determined) doesn't do custom alignments, I ought to get my wheels aligned first (shortly before having new tires installed), correct?
thorongil is offline   Reply With Quote
Old 08-04-2005, 11:49 AM   #9
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
I have four yoko's avid V4's just like this with about 7K miles left on them. But the inside is worn just like that... autox tire I suppose.
Bundyboyz is offline   Reply With Quote
Old 08-04-2005, 11:57 AM   #10
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Toe just does it faster. Camber is a long term killer.
specialev is offline   Reply With Quote
Old 08-04-2005, 01:20 PM   #11
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
Given zero toe, you can run a LOT of camber and have very little effect on tire wear. Any time the alignment gets a little whacked, the wear rate will skyrocket. Long term wear is a relative thing, I got 15k miles or so out of a set of Kumho MXs that saw around 120 autox runs, and 2 track days. Most of that was with between -2.8 and -3.2 camber, while religiously keeping the front toe zeroed. The tires showed very minimal camber-induced wear.
Old 08-04-2005, 02:16 PM   #12
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
now i have zero toe. running plenty of camber, maybe more than needed, do u think theres any hope left in these like for an auto-x or are they going to have to be sent to the grave
thanks for the comments i figured the toe was off
Old 08-04-2005, 02:26 PM   #13
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
On my old Triumph TR6 I was running Dunlop SP5000s and my tires were ruined from too much positive camber, front and rear.
<non-Subaru technical>
On the front I set the toe to be just a degree in, as the manual says to do and it turned ugly as my bad old springs got progressively more saggy. When the springs were replaced camber turned out as it was supposed and I needed new tires.
Rear suspension on those old Triumphs is an interesting story which I won't go into. but suffice it to say, it is an early suspension design and it is a pain to align properly, and I didn't do it right the first time. Not doing it right in the end cost me a pair of expensive tires. Toe in the back was not really an issue, but as the ride height changed the camber became increasingly positive and my tires got ruined.
</non-Subaru technical>
Old 08-04-2005, 06:06 PM   #14
subieworx
Member#: 47769
They're RE92's....there was never any hope for running them at autox.
I take that back, they don't look like RE92's, but they don't look very sticky either.
subieworx is offline   Reply With Quote
Old 08-04-2005, 06:16 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...your tires shouldn't last that long
....and the 'Rumph had bad springs that caused other issues....not just camber....'cuz lowering the car(sagging springs) alters toe, too....replacing the springs brought toe back soooooooo.....
too much camber? skate enjoi Member's Car Gallery 62 08-27-2008 06:09 PM
Too much camber or not enough? zzyzx Motorsports 28 04-13-2007 08:33 PM
Too much camber? kreitz3 Brakes, Steering & Suspension 57 01-23-2007 05:52 PM
Is 7% tire radius decrease too much? Thug Motorsports 5 07-30-2002 10:07 PM
M2 40's = too much camber Akiata Brakes, Steering & Suspension 44 05-09-2002 10:40 AM
