Old 08-03-2005, 10:01 PM   #1
ewright
Member#: 68803
2004 WRX STi
Default New tires mounted...alignment totally off, whats going on?
Hi everyone,
I just got a set of Goodyear F1 GS-D3s mounted. My alignment was perfect before I got them mounted, driving with the new tires on I immediately noticed the car pulling hard to the right. I have to hold the steering wheel about 20 degrees to the left to get the car to go straight. Can anyone explain this? Can new tires throw off the alignment by this much?Did the tire place somehow damage my STi when mounting my tires? Any help would be really appreciated
Ernie
ewright is offline   Reply With Quote
Old 08-03-2005, 11:12 PM   #2
kcook
Member#: 78074
2005 STi
tire place?? did they balance them??
kcook is offline   Reply With Quote
Old 08-03-2005, 11:43 PM   #3
ewright
Member#: 68803
2004 WRX STi
kcook,
yes they did.
ernie
Old 08-03-2005, 11:50 PM   #4
esteve
Member#: 28716
2006 STI
You might have a tire pull issue. You could try switching the 2 front wheels and go for a test drive. The tire rotation will be backwards but it's ok for testing purposes.
I would take it back to the shop if that's where you bought the tires from. They should replace the defective tire(s) for you.
esteve is offline   Reply With Quote
Old 08-03-2005, 11:50 PM   #5
Newest
Member#: 88949
your best bet is to bring it back to the shop and tell them that the alignment is off and to correct it.
Newest is offline   Reply With Quote
Old 08-03-2005, 11:53 PM   #6
ewright
Member#: 68803
2004 WRX STi
thanks for all of your advice guys. i found a decent tech article on tirerack.com and will ask tire rack for a refund for the tires
ernie
Old 08-04-2005, 11:47 AM   #7
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
whoa whoa... at least try a couple things before you go sending tires back; I would say a defective tire is the least likely culprit.
A) check the tire pressure. First thing to check if you have a pull, if one is low it will make a huge difference.
B) go back to the shop that mounted them, have them look at it. (you ordered the tires from Tirerack, and had them mounted somewhere else? Or did you order a tire/rim combo premounted?) If the problem is that obvious and they messed something up w/the alignment the shop should have no problem fixing it. Or swap wheels yourself like esteve said to see if the pull changes.
austinpike is offline   Reply With Quote
Get alignment now or get new tires & alignment (pics inside) kevin2.5rs Tire & Wheel 21 09-09-2006 11:59 PM
New tires mounted...now my alignment is totally off, whats going on? ewright Brakes, Steering & Suspension 8 08-04-2005 11:04 AM
New tires, need alignment. Where to go? chyisan Texas Impreza Club Forum -- TXIC 10 01-31-2002 12:49 AM
So whats going on with New Years? M.Coffman New England Impreza Club Forum -- NESIC 16 12-31-2001 05:29 PM
Whats going on yall New Member here Optimus_P General Forum Archive 6 03-29-2001 01:46 PM
